POV-Ray : Newsgroups : povray.newusers : reading configuration file not permitted Server Time
21 Mar 2026 06:21:47 EDT (-0400)
  reading configuration file not permitted (Message 1 to 10 of 14)
Subject: reading configuration file not permitted
Date: 7 May 2004 05:45:16
Message: <409b5aac$1@news.povray.org>
Hello,
I'm trying to run POV-Ray on a Linux machine where I don't have root
privileges. This means that I can't place a proper povray.conf file in
the directory /usr/local/etc/ . Unfortunately, no matter what else I
specify for povray either on the command line or in the POVINI
environment variable, it complains that reading the specified file is
not permitted. Since directory access permissions can be specified in
configuration files, how am I supposed to tell povray that it is
permitted to read its config file? Will I have to recompile povray with
a different default config file location (to which I have write
permission), or is there some other possibility?
thx
mortee
Subject: Re: reading configuration file not permitted
Date: 7 May 2004 05:51:10
Message: <409b5c0e@news.povray.org>
~/.povray.conf
Date: 7 May 2004 06:06:45
Message: <409b5fb5$1@news.povray.org>
Warp wrote:
> ~/.povray.conf
I already tried that:
[/home/morton]$ ~/povray-3.5/povray ~/.povray.conf +Itest.pov
Possible INI File Error: Could not open INI file
'/usr/local/etc/povray.ini'.
Command Line Error: Reading from /home/morton/.povray.conf is not permitted.
[/home/morton]$
mortee
Date: 7 May 2004 06:11:17
Message: <409b60c5@news.povray.org>
  You don't give povray its configuration file in the command line. It
reads it all by itself.
Date: 7 May 2004 07:28:55
Message: <409b72f7@news.povray.org>
Strangely, if I don't specify it on the command line, then it just seems
to skip it, and complains about that reading test.pov is not permitted.
I think it skips ~/.povray.conf because its contents are:
[Permitted Paths]
read+write*=.
which should allow full access to the current directory and its subdirs.
Povray complains nevertheless, so seemingly it doesn't read that config
file.
The other possibiliy I can imagine is that since there is no global
(system-wide) config file, povray thinks the system-wide permitted paths
list is empty (of which I can't be sure). And since the user config
files can only further constrain the global settings, my ~/.povray.conf
's settings have no effect. Does this mean that I have to recompile
povray anyway, with specifying a system-wide config file path to which I
have access?
thx
mortee
Date: 7 May 2004 07:50:02
Message: <c7fsup$ni0$1@chho.imagico.de>
> [Permitted Paths]
> read+write*=.
How did you assume this being valid syntax for the ~/.povray.conf of
POV-Ray 3.5?  The Documentation describes the format of the povray.conf
file in the platform specific part.  Also note the POV-Ray installation
package (both source and binary) come with a povray.conf that should
work without problems.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 7 May 2004 08:14:45
Message: <409b7db5$1@news.povray.org>
> POV-Ray 3.5?
I'll tell you: since I just tried to solve my problem any way I could, I
tried this thing also. Googling aroud revealed a documentation page
regarding this permission stuff - and despite it was the docs of 3.6
beta, I thought I'd give it a try. After all, why should I have assumed
that *anything* I find in the beta docs wouldn't apply to 3.5?
Additionally, this syntax can be found in the stock povray.conf which
comes with 3.5, so I guess I wasn't that really wrong with my assumption.
Yes. And what good is it if I don't have the privilege to install it
where it's due, and thus povray thinks the list of permitted paths is
empty (which I'm free to constrain further through user-specific
configfiles)?
Anyway, thanks for the valuable input.
mortee
Date: 7 May 2004 08:30:01
Message: <c7fv87$64n$1@chho.imagico.de>
No, both the source package and the linux binary version of POV-Ray 3.5
  come with a valid povray.conf.  How could it be different - the syntax
you mention was not even invented when POV-Ray 3.5 was published...
>> The Documentation describes the format of the povray.conf file in the
>> platform specific part.  Also note the POV-Ray installation package
>> (both source and binary) come with a povray.conf that should work
>> without problems.
> empty
Read what i wrote, you can simply copy the povray.conf in the package at
the appropriate place and it will work.  I never said you should use the
install script.
Date: 7 May 2004 12:06:18
Message: <409bb3fa$1@news.povray.org>
I haven't denied that either.
Now I dounle-checked it, and indeed, the syntax is similar but
different. And then what? It was a failed attempt to somehow work around
my problem. Do you think I should be burned for trying, and hoping that
it would work?
>> empty
> install script.
Please read the whole thread before being so smart. I already mentioned
that I have no root privileges on the machine in question, so I can't in
any way install a config file to /usr/local/etc, where povray looks for
it. I don't give a sh*t about the install script.
mortee
Date: 7 May 2004 12:30:02
Message: <c7gdfv$37j$1@chho.imagico.de>
> it would work?
I have the impression you are slightly loosing perspective here, if you
want to solve your problem you should follow the suggestions Warp and
myself gave.  If you just want to argue about your assumptions how
POV-Ray works and how it should work this is not the right place.
