POV-Ray : Newsgroups : povray.newusers : Repeated objects and Memory Server Time
21 Nov 2025 21:21:38 EST (-0500)
  Repeated objects and Memory (Message 1 to 7 of 7)
Subject: Repeated objects and Memory
Date: 28 Mar 2002 13:08:03
Message: <3ca35c03$1@news.povray.org>
In a scene I have a rather complex object (aka tree) that I want to repeat
several times. The tree consists of about 40 branches all of which are the
same object. Now, does POV-Ray optimize in that if I use the same object
(like with #declare blah = object{ or union{) it will only create one of
those in memory and just transform and texture it?
Currently, for one tree POV-Ray states 250,000 objects, 330megs peak to
render. If I have some many repeated objects, shouldn't it be much much
less? Or I am declaring the stuff wrong?
Thanks in advance!
Subject: Re: Repeated objects and Memory
Date: 28 Mar 2002 13:11:42
Message: <k2n6augfrg9ter7dvmgs39jumui12m3hq6@4ax.com>
On Thu, 28 Mar 2002 13:10:08 -0500, "Chris Becker" <cmb### [at] ritedu> wrote:
You can simple check this comparing memory usage reported in output after
rendering of one instance and two insttances of your object. But short answer
is: in general it is omptimized only for meshes.
ABX
Date: 28 Mar 2002 13:26:46
Message: <3ca36066$1@news.povray.org>
This is why I ask, while looking for a tree macro I came upon this page:
http://www.netaxs.com/~ptdawson/ptdtree3.htm
which has a picture with a thousand trees and says that it only takes up the
same amount of memory as one tree. Is this because they're made up of
triangles and not other objects?
news:k2n6augfrg9ter7dvmgs39jumui12m3hq6@4ax.com...
repeat
the
answer
> ABX
Date: 28 Mar 2002 13:39:12
Message: <slo6au4sgfeaem9t3ii7eo8afn7q949maf@4ax.com>
On Thu, 28 Mar 2002 13:28:50 -0500, "Chris Becker" <cmb### [at] ritedu> wrote:
Yes, but I suppose author of this page/macro was inaccurate. Next mesh instance
reuires at least memory for transformation and pointer to original mesh
structure.
ABX
Date: 28 Mar 2002 14:37:53
Message: <3ca37111@news.povray.org>
> structure.
  I think that in 3.5 it also requires memory for the textures in the mesh.
(This was necessary to fix the bug about textures not being transformed
with meshes.)
Date: 29 Mar 2002 13:20:21
Message: <3CA4B171.7BCA9765@hotmail.com>
Make a tree into a mesh.   Copy that object 40 times.
In the Petrified Orchard Valley (where all of the Rusty animations
take place), I have several hundred trees.  They are meshes built
from a fractal pattern.  There are only three different ones, scaled
and rotated.  Not much memory used.
Rusty is rendering!
Date: 2 Apr 2002 08:26:58
Message: <3ca9b1a2$1@news.povray.org>
"John VanSickle" <evi### [at] hotmailcom> wrote in message
news:3CA4B171.7BCA9765@hotmail.com...
15,000 in my latest irtc image.... (4 flavours, and w/ different rotations and
scales for each copy).
