POV-Ray : Newsgroups : povray.general : recovering from a power outage Server Time
19 May 2024 21:57:30 EDT (-0400)
  recovering from a power outage (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: recovering from a power outage
Date: 3 Jun 2017 19:50:01
Message: <web.59334a7bf571564da705d4cc0@news.povray.org>
"clipka" <nomail@nomail> wrote:
> The procedure is the same as for an intentional abort: Unless you specify the
> `-CC` command-line switch, POV-Ray automatically saves all the Rendering
> Progress in the infamous "state file", allowing it to pick up on it later with
> the `+C` abort-continue command-line switch.
> Progress is saved not at specific time intervals, but each time a render block
> is completed.
> If the power outage strikes at a time where POV-Ray is just updating the state
> file, there might be a possibility that the state file gets corrupted; I've
> never had a look how robust POV-Ray's abort-continue mechanism would be with
> respect to a truncated state file.
This is very helpful, thank you. If it matters, I use POVRay 3.7 under Linux
Mint with Mate 64-bit. So, if the power goes out, I should return to the
directory I was running from, and execute the same command line with the +C
option added, and it SHOULD pick up from the latest automatic save, yes?
If the latest save got corrupted, would an earlier save still be accessible?
Date: 3 Jun 2017 22:55:33
Message: <593376a5$1@news.povray.org>
Le 17-06-01 à 02:34, peyrol a écrit :
> I could not find a command line switch for, nor any mention of, periodically
> saving the image to a file while rendering it. Is this done automatically? I'm
> not talking about animation. I'm talking about rendering a single very high
> resolution image.
> I see how to initiate a controlled abort, and how to resume where you left off
> later. What I'm not sure about is how to resume from a power outage, which would
> effectively be an uncontrolled abort. If POVray provides no way to periodically
> and automatically save what has been rendered so far to a file, that does not
> bode well. Please tell me I am wrong about this. Thanks for any clue.
Unless you disabled the .povstate file, then, you are covered.
Using +c on the command line will always resume your render, no mather
how it was interupted. At most, you'll loose the last render block that
the was worked upon.
If you are rendering a photon using scene and you choose to save the
photons to a file, they are saved before the first render block is even
started. So, you can load them back, saving you the time required to
shoot them.
Date: 3 Jun 2017 22:58:43
Message: <59337763$1@news.povray.org>
Le 17-06-01 à 04:47, Stephen a écrit :
> On 6/1/2017 8:30 AM, Mr wrote:
>> and not be deleted until image is
>> fully rendered, (or the whole animation?). that way, if you turn off your
>> computer and start rendering again from empty pov editor with "+C" the
>> scene
>> will just go on rendering.
>> Am I correct so far guys?
> On all of the Windoze machines I've had. The state file is not always
> deleted.
It's always deleted once the render finishes normally.
Date: 4 Jun 2017 05:35:25
Message: <5933d45d@news.povray.org>
>>> your
>>> the scene
>> deleted.
It was only an observation not a complaint. I've noticed it when I clean
up my hard drives. I've not formally tested this.
Regards
Date: 5 Jun 2017 06:07:47
Message: <59352d73$1@news.povray.org>
Am 03.06.2017 um 02:58 schrieb omniverse:
> clipka <ano### [at] anonymousorg> wrote:
>> Am 02.06.2017 um 00:20 schrieb omniverse:
>>> However, I thought maybe I could remove the last portion of the state file and
>>> still be able to continue a render that way. Idea being that if all it does is
>>> append each render block info, and the last one was incomplete or corrupt, maybe
>>> deleting back to the last complete good block would let it be usable again.
>>> Well, no good. At least if simply editing in Notepad. Yet it is obvious, or so I
>>> believe, where the blocks seem to begin and end. This is something like the end
>>> of a good state file:
>> Notepad is not a good choice to try this. The data is binary, and I'd be
>> surprised if Notepad kept any binary data intact.
> Figured it was a bad idea. Way back when I used Windows Write to change text
> within programs that was usually okay, but only if I didn't touch anything else
> not ever having learned C programming.
> I installed a file code editor and got same result anyway when deleting back to
> prior ViIdINT4, which is what I'm seeing a good state file always ends with.
What exactly do you mean by "file code editor"? A text editor you'd use
for writing program code?
That would generally be of no use either.
You should really use a hex editor for such manipulations.
I've had a look at the relevant source code by now, and judging from it
there should be no problem reading a truncated file: The code is
designed to just read the state file up to the first location that
doesn't seem to make sense.
Date: 5 Jun 2017 07:20:01
Message: <web.59353e28f571564d9c5d6c810@news.povray.org>
Code Writer from Actipro.
Been without a hex editor for years, and years. Thanks for pointing me in the
right direction!
Tried that now using HxD (https://mh-nexus.de/en/), and that does work okay if
deleting back from end of file to the prior ViIdINT4.
Or more precisely, as seen in the Hex editor:
56 69 49 64 49 4E 54 34 00 00 00 04 00 00 00 03
 or
ViIdINT4........
No luck here when I deleted back to a midway point between the ViIdINT4's.
POV-Ray just acts like the render was done without opening a render window and
doesn't show any errors in the message pane.
Date: 5 Jun 2017 15:48:14
Message: <5935b57e$1@news.povray.org>
Am 05.06.2017 um 13:19 schrieb omniverse:
>  or
> ViIdINT4........
Yes, those "00", "04" and "03" are characters you're typically losing if
you use any odd text editor.
Does that hold true even if you do the truncation in a hex editor?
Because the file is full of "00" and other non-printable characters, and
text editors tend to not treat them nicely.
Also, the file is likely to include some "0D" here and there, which a
Windows-based text editor might interpret as a Unix-style line ending
and replace it with the Windows-style "0D 0A" line ending when saving;
while a Unix-based text editor might do just the opposite, replacing any
occurrence of "0D 0A" with "0D". Either modification will invariably
break the file from that point onward.
Date: 5 Jun 2017 18:45:01
Message: <web.5935dd5df571564d9c5d6c810@news.povray.org>
> >  or
> > ViIdINT4........
No changes like that showing up in hex editor.
Could be my mistake about the messages POV-Ray shows, I guess. I might have
overlooked a regular kind of message because I had been thinking it would be
highlighted or look more obvious.
I was trying the same thing as before by removing the last good block of code
back to ViIdINT4 (plus extraneous code afterward as I already told of). Got the
same no render window again.
However this time I noticed the message pane tells me it was "skipped" because
it already existed (shows message near end of all other info). Sure enough, the
completed render was there so I deleted it.
Next I removed code back to a midway point of end to ViIdINT4.....
Successful with continue trace (without existing image), it draws up the
partially done render window and goes on to finish it.
Only difference this time is the 03's are now 02's, which I couldn't explain.
Maybe relates to different day?? Only conjecture I'm sure.
Date: 5 Jun 2017 19:55:03
Message: <5935ef57$1@news.povray.org>
Am 06.06.2017 um 00:41 schrieb omniverse:
I'd expect the value to depend directly on how many renders you've run
earlier during the same POV-Ray session.
Date: 10 Jun 2017 19:15:01
Message: <web.593c7d17f571564d194284cc0@news.povray.org>
In all systems, it's possible to write a script that periodically saves the
state file periodically.
