On 7/2/2016 6:10 AM, Anthony D. Baye wrote:
> On closer inspection, I think this is the wrong kind of Flocking. I'm looking
> for a flocking texture technique.
Well it was quite early in the morning for me.
Do you remember Rune's Fur texture from about the same time?
Last entry on the page.
Regards
On 7/2/2016 8:09 AM, Thomas de Groot wrote:
> damascene texture
Not often you slip up with your English.
Damask. :-P
I wonder if your texture can be combined with Rune's Fur Texture.
Regards
>> damascene texture
> Damask. :-P
It is confusing. Damask is certainly right, but damascene is also used
in this context. See: https://en.wikipedia.org/wiki/Damascening and
especially 'Damascene in Toledo, Spain'.
I should revisit Rune's texture to be sure, but I suppose it should be
possible one way or another. I was thinking in the line of a contrast of
strong and weak (micro-) normals controlled by the pigment_pattern.
>>> damascene texture
>> Damask. :-P
True, true and true. But for cloth... ;)
My first thought on damascene is related to, "on the road to Damascus"
Checking up on my memory. I found the meaning of "damask cheek" as used
by Shakespeare. Rosy cheeked.
I like Rune's macro (attached). It is simple. :)
I took a look at your code but since Bishop3d does not support
pigment_pattern. I tied myself in knots with the syntax in Ver 3·62.
I'll try again when I am not doing six things at the same time. Soon
come. :)
Regards
Download 'furtex.zip' (1 KB)
>>>> damascene texture
>>> Damask. :-P
You are absolutely right of course. 'Damask' should be used for cloth,
damascene for inlay work, but do we know what Anthony intends to do? ;-)
> come. :)
I am busy with something else now but I shall want to have a try too.
>>>>> damascene texture
>>>> Damask. :-P
Flock wallpaper is my guess.
>> come. :)
It is time to move on from Bishop3D. Bye bye old scenes.
Back to learning Blender.
Regards
That is not a bad idea at all.
I have recently discovered, though not yet had enough free, round tuits, to try
Breeze designer:
http://www.breezedesigner.com/breeze/download.aspx
Lionsnake modeler:
http://evilsnack.byethost22.com/lionsnake.htm?ckattempt=2
(just to throw this in here)
Arabeske:
http://www.wozzeck.net/arabeske/manual-export/povray-export.html
Plus there's the recently posted Infinity 3D modeler.
Maybe we ought to start a new thread to post links to POV-Ray compatible
utilities, as I am sure there are quite a few broken links, and always new
things to be discovered!
{Embrace the command-line, Stephen ;) }
On 05/07/16 14:23, Bald Eagle wrote:
<snip>
Whilst I agree with your sentiment, I have to say that that is not going
to happen until Microsoft releases its source code.
John
It's not about bravery.
It's about doing what I need to do to win
Thanks for taking the time to look them up.
I had a quick look but they all came out of the Ark. Bishop3D is good
but it is not maintained any more. It only has 3.6 syntax but it can
import a large subset of it.
I think Blender is the best open source modeller about.
There are two plugins that export SDL so it is not all meshes and you
can use PovRay textures. It just takes a long time to get competent with it.
> Breeze designer:
I think that this is a bit old. It talks about PovRay Ver 3
> Lionsnake modeler:
Again this is old about 2010.
> Arabeske:
Last updated Jan 2004
Made me think that one. :)
Is that a volunteer?
One pace forward!
Away and play on a busy road. :-P
You will be telling me to get a computer that you boot up by stepping
through switch registers.
Viva tomorrow! :)
Regards
