POV-Ray : Newsgroups : povray.general : Reflections/Highlights: 1. Facettes on a Cylinder? 2. Angle-Dependent Color= Server Time
15 Jan 2026 07:14:02 EST (-0500)
  Reflections/Highlights: 1. Facettes on a Cylinder? 2. Angle-Dependent Color= (Message 1 to 9 of 9)
Subject: Reflections/Highlights: 1. Facettes on a Cylinder? 2. Angle-Dependent Color=
Date: 4 Feb 2013 13:40:01
Message: <web.510fffa8f6eb584032076fd10@news.povray.org>
Hi.
1
I have a cylinder and would like to know, if it is possible to make that
cylinder appear like made of thousands of hexagonal facets, in the way the
cylinder reflects light or how its shaded areas are.
2
Some materials in nature or our environment appear being in one color when seen
from one angle, but when the viewer's angle changes, they appear in another
color. Does POV-Ray allow such an effect, and if, how?
Subject: Re: Reflections/Highlights: 1. Facettes on a Cylinder? 2. Angle-Dependent Color=
Date: 4 Feb 2013 16:21:55
Message: <51102673$1@news.povray.org>
Am 04.02.2013 19:36, schrieb Sven Littkowski:
> 1
Depends on what exactly you want to achieve. How about the hexagon
pattern with a cylindrical warp?
> 2
That's a definite yes: The aoi pattern (new in POV-Ray 3.7) was added
with exactly such effects in mind.
You might also want to try the irid keyword, although it only caters to
one particular angle-dependent physical effect (thin film interference).
Its implementation in 3.6 was crappy, but it has been reworked for 3.7.
Date: 5 Feb 2013 05:15:42
Message: <5110dbce@news.povray.org>
the facets pattern will do something like this but without exact
control over the shape of the facets.
Subject: Re: Reflections/Highlights: 1. Facettes on a Cylinder? 2. Angle-Dependent C=
Date: 5 Feb 2013 09:30:01
Message: <web.511116a046db16e032076fd10@news.povray.org>
Thanks to both of you, I will try out these features.   :-)
Date: 5 Feb 2013 10:30:00
Message: <web.5111251dcd08438e32076fd10@news.povray.org>
Hmmm.......
Problem 1:
I want to wrap the hexagons around a cylinder shape. But the hexagon pattern is
just along the x and z axis. Honestly, at the moment I am out of ideas. Hoped it
would have been three-dimensional.
Problem 2:
Hexagon is a pigment pattern, but my intention is to fill the hexagons with a
texture. One with a dark texture, one with a lighter texture. And then, using
both of them in a texture map.
Problem 3:
I need thin outline (borders) between the hexagons. Those will be filled with a
non-reflective texture.
Oh, oh, oh...
Date: 5 Feb 2013 11:40:01
Message: <web.511135a1cd08438e81c811d20@news.povray.org>
"Sven Littkowski" <nomail@nomail> wrote:
> Hmmm.......
> Problem 1:
> Problem 2:
> Problem 3:
> Oh, oh, oh...
Problem 1: use a cylindrical warp on the pattern (3.5.12.6.5 Mapping using
warps)
Problem 2: Hexagon can be used a a textire pattern, check the 4th example under
3.5.11.21 Hexagon
Problem 3: A little more difficult, but could be done.  Best way may be with a
function pattern, but coul also be done by manipulating gradient patterns
-tgq
Date: 5 Feb 2013 11:50:00
Message: <web.5111371fcd08438e81c811d20@news.povray.org>
> > Hmmm.......
> > Problem 1:
> > Problem 2:
> > Problem 3:
> > Oh, oh, oh...
> warps)
> 3.5.11.21 Hexagon
> -tgq
For 3 I forgot about tiling patterns: (3.5.11.39 Tiling) looks like pattern #8
is hexagonal.
-tgq
Date: 5 Feb 2013 12:51:00
Message: <51114684$1@news.povray.org>
>>> Hmmm.......
>>> Problem 1:
>>> Problem 2:
>>> Problem 3:
>>> Oh, oh, oh...
>> warps)
>> 3.5.11.21 Hexagon
>> -tgq
> is hexagonal.
> -tgq
Hexagonal tiling pattern:
Pattern 2 (pure hexagon, all identical)
It can have a transparent center and be layered over the hexagon
pattern. You need to provide a color_map. It's transition point will
determine the thickness of the edges. It may need some scalling to make
the 2 patterns match.
Date: 5 Feb 2013 22:47:47
Message: <5111d263@news.povray.org>
Am 05.02.2013 16:28, schrieb Sven Littkowski:
> Hmmm.......
> Problem 1:
That's why I mentioned the cylindrical warp.
> Problem 2:
There's nothing stopping you from using the hexagon pattern with
textures; quote from the docs:
     hexagon
     texture { T_Gold_3A },
     texture { T_Wood_3A },
     texture { Stone12 }
As for using two textures, that won't fly: To color a hexagonal tiling
in such a way that no two adjacent hexagons have the same color, you
need at least 3 colors.
> Problem 3:
Have a look at the new "tiling" pattern.
