POV-Ray : Newsgroups : povray.general : Q: POV RAY 2D Server Time
11 Apr 2026 10:55:19 EDT (-0400)
  Q: POV RAY 2D (Message 1 to 10 of 21)
Subject: Q: POV RAY 2D
Date: 9 Nov 2009 08:05:00
Message: <web.4af8133e717d7fb2130ab9690@news.povray.org>
I'd like to ask, if it is possible to be using the POVRAY also for rendering 2D
pictures, such like 2D charts and color maps. Could you give me some
recommendation, if the POVRAY is useful for such the purpose o if there exists
an alternative program for 2D which you know..
Thanks a lot,
D
Subject: Re: Q: POV RAY 2D
Date: 9 Nov 2009 08:21:23
Message: <4af81752@news.povray.org>
> rendering 2D pictures, such like 2D charts and color maps. Could you give
> me some recommendation, if the POVRAY is useful for such the purpose o if
> there exists an alternative program for 2D which you know..
> Thanks a lot,
> D
Isn't this wat "ortho" (orthographic) in a camera{} statement is for?
Blender's got an orthographic mode too, if I'm not mistaken, that seems to
work just fine. It's a completely different horse from PovRay though, and
will be quite strange to get used to if you've never seen it before.
http://blender3d.org
Stefan Viljoen
Subject: Re: POV RAY 2D
Date: 9 Nov 2009 09:40:27
Message: <4af829db$1@news.povray.org>
"Dudo" <nomail@nomail> wrote in message
news:web.4af8133e717d7fb2130ab9690@news.povray.org...
> rendering 2D
> exists
> Thanks a lot,
> D
I use it as a quick way to do function plots all the time. I set up an
orthographic camera on the Z axis pointing at the origin, make a couple of
thin cylinders for the X and Y axes, then I loop through some X values to do
the plot. For each point, I draw a sphere at the point, and a cylinder back
to the previous point to give a more or less smooth curve.
There might be better software for this purpose, but POV is just so darn
flexible and solid that it's too much trouble to pick up other software.
Jack
Date: 9 Nov 2009 10:04:33
Message: <4af82f81@news.povray.org>
>> rendering 2D
>> exists
For more smoothness, you can also use sphere_sweep to plot.
... plus, it is definitely capable of creating animated charts and stuff.
And, as the icing on the cake, there's probably not much software out
there that can add as much a variety of 3D effects to a chart, graph or
whatever to liven it up :-)
@Dudo: Yes, the "orthographic" camera is probably what you want.
Date: 9 Nov 2009 11:19:34
Message: <4af84116@news.povray.org>
> rendering 2D
As already mentioned the answer is Yes. It's possible!
I'd recommend thinking carefully before doing that though.
It depends what sort of charts and pictures you wish to create and whether
you plan to use POV-Ray for anything else. If you're planning to generate 3D
images and want to incorporate the same objects into some sort of 2D
representations, and if you are already planning to learn (or already know)
POV-Ray, then it may be appropriate to use it for 2D images. Some folk have
used it in the past with high ambient levels to create cartoon-like effects.
I'm currently doing some 2D style elevation maps of the Earth using an
Orthographic camera, with only ambient lighting and with a color map to give
different elevations different colors, but then I'm also planning to use the
same POV-Ray objects for separate 3D representations.
> o if there exists an alternative program for 2D which you know..
There are lots of 2D graphics programs available that are very easy to
learn. There are different types of application, with each type of
application being best suited to a particular type of use. There are free
examples of most of those types of application.  OpenOffice incorporates two
applications that may be of particular interest to you for generating 2D (or
fake 3D) charts:
OpenOffice Draw is what's known as a vector graphics application that
enables you to draw boxes, lines, circles and randomly shaped 2D objects
with the mouse and to add text with the keyboard. You can add shading to
each object and 3D effects, such as shadows to objects text. This is a free
equivalent to commercial presentation packages such as Freelance Graphics
and Microsoft PowerPoint and enables you to do multi-slide presentations
with some animation and transitional effects.
OpenOffice Calc is a spreadsheet, mainly for doing calculations, but also
has a 2D charting function so that you can plot graphs of data held in the
spreadsheet or calculated using mathematical formulae. This makes it very
easy to make bar charts, pie charts, line charts and other 2D
representations of data. You can also very easily switch between different
representations if you change your mind. Commercial equivalents are Lotus
123 and MS Excel. You can cut and paste charts from any of these into other
2D graphics software such as OpenOffice Draw, enabling you to use the best
features from each application.
Two other free 2D applications you might find handy (depending on exactly
what you want to do) are Gimp (for photo editing) and Inkscape for 2D
Scalable Vector Graphics (SVG) editing.  Inkscape falls into a similar
category to OpenOffice Draw, but works with SVG files which are freely
editable text files (a bit like POV-Ray scene files in concept). There are
quite a lot of free SVG graphics and charts already available on the
Internet that may avoid you having to start from scratch.
Sorry if I'm telling you stuff you already know, but it's hard to judge the
level to aim a response at from the question :-)
Chris B.
Date: 9 Nov 2009 12:09:06
Message: <4af84cb2$1@news.povray.org>
>> rendering 2D
> whether you plan to use POV-Ray for anything else. If you're planning to
> generate 3D images and want to incorporate the same objects into some
> sort of 2D representations, and if you are already planning to learn (or
> already know) POV-Ray, then it may be appropriate to use it for 2D
> images. Some folk have used it in the past with high ambient levels to
> create cartoon-like effects. I'm currently doing some 2D style elevation
> maps of the Earth using an Orthographic camera, with only ambient
> lighting and with a color map to give different elevations different
> colors, but then I'm also planning to use the same POV-Ray objects for
> free examples of most of those types of application.  OpenOffice
> incorporates two applications that may be of particular interest to you
> for generating 2D (or fake 3D) charts:
> free equivalent to commercial presentation packages such as Freelance
> Graphics and Microsoft PowerPoint and enables you to do multi-slide
> presentations with some animation and transitional effects.
> also has a 2D charting function so that you can plot graphs of data held
> in the spreadsheet or calculated using mathematical formulae. This makes
> it very easy to make bar charts, pie charts, line charts and other 2D
> different representations if you change your mind. Commercial
> equivalents are Lotus 123 and MS Excel. You can cut and paste charts
> from any of these into other 2D graphics software such as OpenOffice
> Draw, enabling you to use the best features from each application.
> exactly what you want to do) are Gimp (for photo editing) and Inkscape
> for 2D Scalable Vector Graphics (SVG) editing.  Inkscape falls into a
> similar category to OpenOffice Draw, but works with SVG files which are
> freely editable text files (a bit like POV-Ray scene files in concept).
> There are quite a lot of free SVG graphics and charts already available
> on the Internet that may avoid you having to start from scratch.
> the level to aim a response at from the question :-)
> Regards,
> Chris B.
gnuplot is very suitable to generate charts.
Paolo
Date: 9 Nov 2009 19:10:59
Message: <4af8af93$1@news.povray.org>
> Jack
It would be great if POV-Ray supported more 2D primitives, like the ones
used in SVG. You can of course intersect a 3D primitive with two planes,
but this requires more work.
Mike
Date: 9 Nov 2009 19:59:33
Message: <4af8baf5$1@news.povray.org>
Like, for instance?
I guess you're talking about extruded 2D shapes, right?
Date: 9 Nov 2009 20:05:23
Message: <4af8bc53$1@news.povray.org>
On 11/9/2009 7:59 PM, clipka wrote:
> Like, for instance?
That, or treat them like patch primitives.
Mike
Date: 9 Nov 2009 20:25:11
Message: <4af8c0f7@news.povray.org>
>> Like, for instance?
Well, how about cylinder and box for circles, ellipses and rectangles,
text for text, and linear prisms for polygons.
Lines and polylines don't seem to make much sense in a solid 3D world.
What's left?
