POV-Ray : Newsgroups : povray.general : rgb color looks dark Server Time
25 Dec 2025 17:36:47 EST (-0500)
  rgb color looks dark (Message 1 to 10 of 13)
Subject: rgb color looks dark
Date: 11 Jul 2009 06:15:00
Message: <web.4a5865409e9a3ab0e4e47a1b0@news.povray.org>
this line works
pigment { rgbf <146,218,164,>//255 filter 0.5 transmit 0.6}}
for transparent, glasslike objects.
But when I want solid colors defined by rgb values, actual color rendered is too
dark in comparison to what I see in Paint's color picker.
the code I use is this, I tried variations without success.
pigment {color rgb <146,218,164>/255}}
146,218,164 is alight green color, but it comes out as dark green.
Could you please tel me what is wrong? Thanks
PS: Last week I had it working, by adding /255 to the end but that is no good
now
Subject: Re: rgb color looks dark
Date: 11 Jul 2009 07:18:38
Message: <4a58750e@news.povray.org>
mysdn wrote:
> this line works
but it certainly looks a bit corrupted by itself.
The end color of course also depends on lighting, so if you
wish to compare with ms paint you should probably set your
texture to use "finish {ambient 1 diffuse 0}".
Furthermore, there may be issues with gamma correction.
Date: 11 Jul 2009 08:15:00
Message: <web.4a588173fb16eafe4e47a1b0@news.povray.org>
Christian , thank you for your reply but there is nothing wrong with povray or
gamma values, something's wrong with this code
it just doesn't render the rgb color as it should. As I said I had it working
last week, So I know Povray can render rgb just as they look in ms paint color
picker. Why is it so hard to simply assign objects rgb colors in povray, thanks
a million?
Date: 11 Jul 2009 08:30:00
Message: <web.4a58857efb16eafe4e47a1b0@news.povray.org>
> mysdn wrote:
> > this line works
I got it,
pigment {color rgbf <146,218,164>/255} finish{phong 1 ambient 0.8}}
this works, I hope this is the correct way to do rgb colors in pov, thank you.
Date: 11 Jul 2009 13:10:01
Message: <web.4a58c68cfb16eafe555c1690@news.povray.org>
This is a Gamma problem: Paint shows you the actual values stored in the image
file, which are typically gamma-corrected for a display gamma of ~2.2, while
POV-Ray works with linear color values.
You need to gamma-"un-correct" the values from Paint before using them in
POV-Ray; the following code should do the job:
  color rgb <pow(R/255,GAMMA),pow(G/255,GAMMA),pow(B/255,GAMMA)>
Don't know by heart whether you need to use GAMMA=2.2 or GAMMA=1/2.2 though.
Date: 11 Jul 2009 13:15:00
Message: <web.4a58c86cfb16eafe555c1690@news.povray.org>
> picker.
I wouldn't bank on that. Maybe you changed the gamma handling in your scene, by
using assumed_gamma or changing Display_Gamma or the like?
Your code to set the object's color looks perfect, except for possible Gamma
issues, and - like someone already pointed out - maybe issues with the
(default) finish or lighting.
> a million?
Because simply assigning colors to an object is not a typical use-case in
POV-Ray these days; typically, you'll also want to set other material
properties such as specularity or the like.
Date: 11 Jul 2009 13:25:00
Message: <web.4a58ca74fb16eafe555c1690@news.povray.org>
It's a bit... uncommon; but depending on what you want to do, it may indeed give
you what you want.
Typically, you'll use a much different finish, such as:
    finish { diffuse 0.7 specular 0.5 ambient 0.1 }
or something like that; in case of radiosity scenes, you'll virtually always use
ambient 0.
Note that you can define a default finish in your scene, using:
    default {
       finish { diffuse 0.7 specular 0.2 ambient 0.0 }
(for instance) at scene level, before defining your objects.
Date: 11 Jul 2009 16:20:00
Message: <web.4a58f31bfb16eafe4e47a1b0@news.povray.org>
clipka, thank you for all the info, I'm impressed with the depth of details  you
provided. People like you make this whole thing more pleasurable.
Date: 11 Jul 2009 22:17:09
Message: <4a5947a5$1@news.povray.org>
> Christian Froeschlin <chr### [at] chrfrde> wrote:
>> mysdn wrote:
>>> this line works
> I got it,
If there is NO light shining on your texture, it will look very dark
with the default ambient of 0.1.
This is a glowing finish. If you use that in a radiosity scene, it will
shed a light green light on everything around it.
It can easily get oversaturated if there is also a light shining on it.
The default ambient is 0.6. With a light of intensity 1, it will combine
with the ambient to potentialy give you a brightness of 0.6 + 0.8 = 1.4
and a resulting colour of <146,218,164>/255 * 1.4
<0.5725, 0.8549, 0.6431>*1.4 = <0.8015, 1.1969, 0.9003> that get clipped
to: <0.8015, 1.0000, 0.9003>
Not the same tint, the saturation is diminished.
Defining rgbf with a 3 component colour is legal if unusual. The filter
value is then set to zero.
Defining a colour this way is also legal:
rgb<Red_value, Green_value, Blue_value, Filter_value, Transmit_value>
and the filter and transmit values WILL be used. (found that by accident)
Date: 13 Jul 2009 10:09:24
Message: <4a5b4014@news.povray.org>
Yes, you need to do this for any image files you use as textures too.
Check the attached image I made a while ago, the circles in the middle are
RGB values chosen in PowerPoint, the top row of spheres is without the gamma
correction trick, the bottom row is with the trick mentioned above.  Note
that however much you try to adjust the lighting or shading in the top scene
the colours will always be wrong because you have the wrong ratio of RGB
values.
Download 'comparison.png' (65 KB)
Preview of image 'comparison.png'
