POV-Ray : Newsgroups : povray.general : Toroidal warp Server Time
20 Nov 2025 15:25:44 EST (-0500)
  Toroidal warp (Message 1 to 10 of 11)
Subject: Toroidal warp
Date: 27 Jun 2008 19:45:00
Message: <web.48657b48df8531631d9045be0@news.povray.org>
I'm having trouble mapping an image to a torus. The patter seems to be mirrored
above and below the torus's "equator". Is there a way to get this to stop?
-Mike
torus
 #local Width = 64;
 #local Height = 64;
 #local Radius = Width/2/acos(pi/4);
 Width, Radius
// clipped_by {cylinder {0,y*Height,Width}}
 texture
  pigment
   image_map {png "texture_bowels_test.png"}
   warp
    toroidal
    orientation y
    dist_exp 0
    major_radius Width
  scale Width
 translate y*Height/2
 translate Left_Vector*+1/2
Subject: Re: Toroidal warp
Date: 27 Jun 2008 20:35:00
Message: <web.4865871da2e11e9c1d9045be0@news.povray.org>
> -Mike
I managed to fix it. However, I would like to apply a toroidal warp to the
"lemon" portion of torus whose minor radius is greater than its major radius. I
am wondering how the mapping is applied in this case? Since the torus intersects
itself, there are two possible versions of the pigment that could get applied.
How does POV-Ray behave in this case? Here's what I've got so far and am having
trouble making sense of it:
torus
 #local Width = 64;
 #local Height = 64;
 #local Radius = Width/2/cos(pi/4);
 Width/2, Radius
// rotate x * 90
 clipped_by {cylinder {-y*Height/2,y*Height/2,Width}}
 texture
  pigment
   translate y * 1/2
   rotate x * 180
   scale 1/4
   warp
    toroidal
    orientation z
    dist_exp 0
    major_radius -Width
Date: 28 Jun 2008 05:38:59
Message: <486606b3@news.povray.org>
  The torus warp doesn't "know" which object you are applying it to
(it doesn't really care). It always does the same thing, regardless of
which object you are using (it could be a box or a julia fractal for all
that it cares).
  Thus it probably won't do what you want if the torus is not a "pure"
torus.
Date: 28 Jun 2008 06:54:31
Message: <48661867$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.4865871da2e11e9c1d9045be0@news.povray.org...
> radius. I
> intersects
> applied.
In this case with the overlapping bit of the torus I think it just merges
the two possible pigments onto the interior surface.
I tried an image map and a brick pattern with your code and both worked,
after a fashion, but were obviously quite distorted as I think one would
expect. Would I be right in thinking that your image file
"texture_bowels_test.png" is quite a random sort of texture? If so you may
be able to 'see' the distortion easier with a more regular image or pattern.
In any case it may be easier to get what you seek using a simple cylindrical
or spherical warp.
Indeed, if it's an image map then just using map_type 2 or 1 should deliver
a result with far less distortion.
Chris B.
Date: 28 Jun 2008 10:25:00
Message: <web.486648aaa2e11e9cb891a1db0@news.povray.org>
Just as I suspected. I will try a more regular pattern to see how it is
affected. And, yes, the texture is a tiling, repeating texture made using
TexRD.
> or spherical warp.
I have to use a toroidal warp because the particular piece (actually a
difference object) is being adjoined to other pieces that use regular toroidal
warps as well as cylindrical warps. Since the pieces are smoothly adjoining, a
seam in the texture between the different pieces would be noticable.
-Mike
Date: 28 Jun 2008 17:45:00
Message: <web.4866afd9a2e11e9cfa138a830@news.povray.org>
Can I create the pigment from scratch using a function, and then clip it to the
desired region?
-Mike
Date: 6 Jul 2008 00:10:01
Message: <web.48704526a2e11e9c1a157cba0@news.povray.org>
I'm having a separate problem now with the same warp. This problem applies to a
regular toruse, not the "lemon" I was having problems with earlier. I can't
figure out how to put the seam of the texture at the outside (farthest from the
origin) of the torus as opposed to the inside (closest to the origin). Even if I
reverse the orientation the seam is still on the inside.
Here's an example:
 #local Orient_Direct = 1; // 0 or 1
 #local Torus_Radius = 64;
 texture
  pigment
   image_map {png "GSprites_Tech_Texture_Test.png"}
   translate x/2
   #if (Orient_Direct = 1)
    translate y*0.7
   #else
    translate y*0.5
   rotate x * 180
   scale 1/3.2
   warp
    toroidal
     orientation -z
    #else
     orientation z
    dist_exp 0
    major_radius Torus_Radius
I would appreciate any help.
-Mike
Date: 6 Jul 2008 04:06:43
Message: <48707d13$1@news.povray.org>
news:web.48704526a2e11e9c1a157cba0@news.povray.org...
> to a
> can't
> from the
> Even if I
The code below should place the horizontal seam on the outside. The warps
take the image from the square <0,0,0> to <1,1,0>, so moving it up by 0.5*y
causes the seam to be positioned where the middle of the image was before.
The bottom half is filled in because the image_map generates an infinite
number of copies butted end to end, so you end up seeing the top half of one
copy and the bottom half of the original.
I don't think the orientation setting does what you think it does. When you
change it from z to -z, I think it just makes it look at the image from the
other side. You also seemed to have a lot more translations and rotations
than you need. Just by translating the image you can move both the
horizontal and vertical seams around the torus.
Chris B.
camera {location <0,28,-204> look_at 0 }
light_source {<-1,30 ,-400>, rgb 3}
torus {Torus_Radius,20
    image_map {png "yourimage.png"}
    translate y*0.5
    warp { toroidal
Date: 6 Jul 2008 14:45:00
Message: <web.4871128da2e11e9c8c88ff560@news.povray.org>
> Regards,
> Chris B.
>   pigment {
>     translate y*0.5
>     warp { toroidal
Sorry, I wasn't clear enough in my previous post. I meant the seam of the warp
itself, not the texture. Consider the case where the image map is scaled first
by a non-integer value. The result is that the image gets wrapped around the
torus in such a way that it doesn't repeat by an amount equal to a whole
number. There will be portions where the texture is "split" and meets at points
other than the image's edges. Using the example you gave, consider this:
    // integer scaling
    // scale 1/3
    // non-integer scaling
    scale 1/3.1
    warp { toroidal
If you'll notice along the inner edge of the torus, you'll see that the "edge"
of the image appears twice in close proximity, accounting for the 0.1
difference in the scaling factor. What I would like to do is move this edge
where the image meets itself to the outside of the torus. I haven't yet figured
out a way of doing this.
-Mike
Date: 6 Jul 2008 17:45:53
Message: <48713d11$1@news.povray.org>
news:web.4871128da2e11e9c8c88ff560@news.povray.org...
> I meant the seam of the warp itself, not the texture.
Ah. Slightly more tricky :-).
I don't see any control on the warp itself that would do that for you
(unless I'm wrong about the meaning of the orientation attribute), so I
think you'll need a workaround.
The only thing that I can think of that will do this is to use a pigment_map
with two copies of the pigment. One where the repeating scaled image_map is
aligned to the origin (the default) and one where it's aligned to y=1. You
can then use the pigment_map to join them wherever you want. In the example
below I've placed the half-cut image at y=0.5 so that it appears around the
outer rim of the torus. In this example I've cut a corner out of the torus
just so that the inner rim and outer rim are both visible at the same time.
Chris B.
camera {location <0,0,-124> look_at 0 }
#local Scale_Factor = 1/10.5;
#declare MyPigment = pigment {
  image_map {png "YourImage.png"}
  scale Scale_Factor
difference {
      gradient y
      pigment_map {
        [0.0 MyPigment]
        [0.5 MyPigment]
        [0.5 MyPigment translate -y*Scale_Factor/2]
        [1.0 MyPigment translate -y*Scale_Factor/2]
      warp { toroidal
  box {-y*30,<90,30,-90> pigment {rgbt 1}}
