Anyone know where I can find Povray code for a tent object - a large event tent
with or without embellishments. Alternatively, any quick and simple ideas for
code to make one would be helpful. I could do the basic shapes easily enough,
but I'm looking for a ready object because I'd prefer to have something with
folds in the canvas etc., so that it is a bit more realistic. I would spend
some time doing this myself, but deadline is looming and I spent a long time
making some building renders for the same project (thank you Pov-stairs!).
Thanks.
"Cerambycideh" <nomail@nomail> wrote in message
news:web.47e6e96dfe4726f18ace12d10@news.povray.org...
> tent
> for
> enough,
> with
> spend
> time
> Thanks.
I don't recall ever having seen anything quite resembling a POV-Ray event
tent. How realistic do you need it to be?
When you say 'folds in the canvas', do you mean the rounded edges where it
folds around the tent poles, some sort of grid of folds from where it was
previously folded up, or the loose folds of cloth around the openings?
Is there a google image you could point to that illustrates what you mean?
Although it's not designed for this, the Labeller macros at
http://lib.povray.org/ include a polyhedron shape with rounded edges. This
generates a thin CSG object that you can easily punch holes in. I did a
quick and simple test with one 4 sided polyhedron for the roof, one for the
rim around the edge of the roof and a third for the main sides of the tent
and it looked sort of ok (not brilliant, but ok).
How good/quick do you need it to be?
Chris B.
Thanks for the reply, Chris. I don't need the event tent to be too realistic,
but would like it to be better than a stacked cube and pyramid. I don't need
folds around the openings, I'll just difference out a doorway. The folds I was
thinking of are just the 'waves' in the canvas near the bottom of tents. I'll
have a look at the tool you mention to see if it can generate this. I figured
somone must have seen or used a large-tent object before. If I can't find
anything and end up creating this from scratch I'll be sure to post it for
future users.
Thanks.
On Tue, 25 Mar 2008 10:52:29 EST, "Cerambycideh" <nomail@nomail>
>future users.
> Thanks.
If that is all you want then "normals" in the texture might be a quick
and easy way for you to do it. In the docs look at the phase,
tutorial. It is for an animation but the principle can be applied to
stills.
Regards
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:44aiu31dkn8dj4lb0mmk16vs02qge2lobu@4ax.com...
>>realistic,
Glad you said that :-)
>>need
>>was
>>I'll
I've posted a couple of images that I did by quickly playing around with the
Labeller macro on povray.binaries.images (See 'Event' Tent Ideas). If they
come anywhere close to what you want I can post the settings and the design
file so you can play about with them (you'll also need the Labeller download
I mentioned before).
>> I figured
>>future users.
>> Thanks.
> stills.
> Regards
> Stephen
The images I posted use a simple 'wrinkles' normal, but, as Stephen says,
you should be able to adjust that to achieve the sort of folds you're after.
Chris B.
Thanks Chris and Steven,
These are good ideas. Chris, the tents you posted look great and I could
definitely use this! The reason I thought the waving canvas effect would be
more complicated than I wanted to tackle was that this would occur at the
bottom while the canvas at the top would be taught. So the waves would dampen
with height. In any case, the event tents images you posted look like what I'm
looking for. Thanks to both of you for your help!
- Cerambycideh
news:web.47e938cf496570ec800e16f70@news.povray.org...
> could
> be
> dampen
> what I'm
> - Cerambycideh
I've posted a scene file and the corresponding 'design' file on
povray.binaries.scene-files.
The 'design' file contains the pattern embossed on the different surfaces.
You could simplify this down to a single colour if you want. If you want a
different pattern on each of the 3 polyhedrons you can use 3 copies of the
file and include the appropriate file before each 'Labeller' call. You can
apply a different normal to each of the 3 objects too. To get waves that
dampen with height you may want to define a normal_map for the sides of the
tent.
To use this object in a scene you're likely to have to scale it up a fair
bit. At the moment the object goes from y=0 to y=0.023, with a base centred
at the origin. I'd guess you'll probably have to scale it by about 140 if
you're working to a scale of 1 unit = 1 metre.
Chris B.
> tent.
> Regards,
> Chris B.
Chris,
That macro of yours is very impressive! I tweaked your code a bit by playing
with the size of the rendered event tent and fiddled with the wrinkles in the
canvas. I came out really well. :) Thanks very much for you help. I'm in awe of
how quickly and elegantly you wrote that code!
- Cerambycideh
