POV-Ray : Newsgroups : povray.general : Best way to simulate a sun Server Time
13 Oct 2025 09:17:14 EDT (-0400)
  Best way to simulate a sun (Message 1 to 9 of 9)
Subject: Best way to simulate a sun
Date: 8 Feb 2008 04:35:00
Message: <web.47ac21fd7876da1cce83de880@news.povray.org>
I considered using an area light, but an area light is flat and doesn't luminate
equally in all directions. Should I use a point light that looks like a sphere,
or a sphere with high ambient values?
Thanks!
Mike
Subject: Re: Best way to simulate a sun
Date: 8 Feb 2008 05:04:21
Message: <47ac2925@news.povray.org>
SharkD napsal(a):
> Thanks!
> Mike
use circular orient.
If you want to use an ambient sphere then you have to use radiosity. If
time.
Date: 8 Feb 2008 17:45:01
Message: <web.47acda45cc87f9a1ce83de880@news.povray.org>
> time.
Well, a circlular area light would be just as flat as a rectangular one. Also,
radiosity wouldn't make sense in outer space.
Is there a good way to get the sun object to emit light?
Date: 8 Feb 2008 18:14:30
Message: <47ace256$1@news.povray.org>
>> time.
Search the documentation on 'orient'. A circular area light with
'orient' on it will look as if it was a spherical area light.
 > Also, radiosity wouldn't make sense in outer space.
Why not? The light effect doesn't happen only in presence of air or gravity.
Date: 8 Feb 2008 18:15:16
Message: <47ace284$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.47acda45cc87f9a1ce83de880@news.povray.org...
>> time.
> Also,
but if you add the orient keyword, it should behave like a spherical
area_light... I think...
or is orient a MegaPOV feature?
cu!
Date: 8 Feb 2008 19:28:36
Message: <47acf3b4$1@news.povray.org>
SharkD nous apporta ses lumieres en ce 2008/02/08 04:33:
> Thanks!
> Mike
Typicaly, the Sun is at a very large distance from your scene objects. It have
an aparant radius.
You use the "parallel" keyword and point it to the center of your scene. This
simulate a light source that is very far away.
You use an area_light with circular. You can also use "orient" to make sure the
light aray is always perpendicular to the location tested.
circular with orient create a "spherical" area_light.
If you can see your sun, directly or trough reflection(s), add a looks_like to
make it visible.
To define recursion, we must first define recursion.
Date: 8 Feb 2008 19:50:15
Message: <47acf8c7@news.povray.org>
  Not if you add 'orient'.
  Why not? Light reflecting from surface does not depend on air.
(In fact, raytracing always happens in "vacuum".)
  Yes: Use a light source.
Date: 8 Feb 2008 21:50:00
Message: <web.47ad13afcc87f9a14cdeac580@news.povray.org>
> an aparant radius.
> make it visible.
> Alain
The problem with this method is that objects that don't lie along this vector
are not lit properly. I would prefer a method that lights objects properly
regardless of their position relative to the sun.
Date: 9 Feb 2008 12:12:00
Message: <47addee0$1@news.povray.org>
SharkD nous apporta ses lumieres en ce 2008/02/08 21:45:
>> an aparant radius.
>> make it visible.
>> Alain
Unless your scene cover an extremely whide area, parallel is not a problem.
If your scene extend in an area large enough for that to be a problem, then you
will have more problems with floating point precision: your objects will become
to small relative to the distances separating them.
In real life, and using a scale equivalent to the earth-moon distance, the
direction difference for the sun will be effectively negligeable, at around a
degree of angle. The earth travel less than a degree per day, and that's much
more than it's diameter, or the orbital diameter of any artificial satellites.
If your scale is such that you have several planets showing, then, using any
kind of area_light is overkill exept for close objects in the foreground, as the
bigest planets, like Jupiter and Saturn, will only show as single pixel, or
sub-pixels dots.
Never underestimate the power of stupid people in large groups.
