POV-Ray : Newsgroups : povray.general : ripples with actual height Server Time
29 Sep 2024 21:26:03 EDT (-0400)
  ripples with actual height (Message 1 to 10 of 10)
Subject: ripples with actual height
Date: 13 Mar 2007 14:20:01
Message: <web.45f6f88d935f00a3577619e90@news.povray.org>
There are many ways I've seen to simulate water, but all are really
illusions on a uniform surface.  So if you have a vertical surface coming
straight up out of the 'water', you get a perfectly straight line at the
intersection.  What options are there that will form actual height-ripples
in a surface?  I know of bump_map and height_field, all of which require an
image for the height field, but I'd rather not go that way.
Thanks!
-Eric
Subject: Re: ripples with actual height
Date: 13 Mar 2007 14:30:33
Message: <45f6fbd9$1@news.povray.org>
> Thanks!
> -Eric
Bump mapping isn't really implemented in POV-Ray, at least not the way
you're probably thinking from the above.
Most people use isosurfaces, which are surfaces defined by equations.
Here's a simple scene using one:
  location <0,10,-15>
  look_at 0
isosurface {
  function { cos( sqrt(x*x+z*z) ) +y }
  threshold 0
  max_gradient 1.5
  contained_by {box {<-100,-2,-100>,<100,2,100>}}
  pigment {color rgb 1/2+z/2}
  finish {specular 1/2}
light_source {<1,1,-1>*100 color rgb 1}
...Chambers
Date: 13 Mar 2007 15:28:54
Message: <45f70986@news.povray.org>
  Heightfields can be generated from user-defined functions.
Date: 13 Mar 2007 15:29:20
Message: <45f709a0@news.povray.org>
Chambers <ben### [at] pacificwebguycom> wrote:
> isosurface {
  A heighfield would be faster to render than an isosurface.
Date: 13 Mar 2007 16:02:49
Message: <ib4ev21r8ho07nopdqmfa2or4up8p1bd4f@4ax.com>
On Tue, 13 Mar 2007 14:16:29 EST, "Eric" <[firstname]@theothersideofthenet.com>
>Thanks!
>-Eric
Tim Nikias wrote a good animation system for water. I just looked at his new
site (http://www.nolights.de/main.html) but I cant see it for download. I'm sure
that if you contact him he will be pleased to give you a copy.
JUS### [at] gmxnetWARE
Regards
Date: 13 Mar 2007 18:25:01
Message: <web.45f7319727ae231e577619e90@news.povray.org>
Thanks for all the good advice.  I've found a very nice looking solution
with isosurface (code example 1 below) but I'm having trouble getting a
function to work right for a height_field alternative (non-working code
example 2 below).  I did find a posting that gives some info on how to use
function for height_field, but still could use further advice to get a
ripple or 'sloshing' appearance.  (f_noise3d gives a nice 'sloshing' with
an underlying rippled appearance when the x and z parameters are scaled
differently)
Thanks!
EXAMPLE 1:
isosurface {
  function { y + f_noise3d(x/10,0,z/2) }  // f_noise3d requires
'functions.inc'
  threshold 0
  max_gradient 0.5
  contained_by {box {<-1000,-1,-1000>,<1000,1,1000>}}
  pigment {color rgbft <0.1,0.4,0.3,0.9,0.1> }
  finish { ambient 0 diffuse 0 specular 0.9 roughness 0.001 reflection 0.2 }
  interior { ior 1.3 caustics 1 fade_distance 2 fade_power 1 }
  translate <0,3,0>
  scale 0.1
// finish and interior need a little work
// shouldn't need to scale... may need to alter function a bit instead
EXAMPLE 2:
height_field {
  function 200, 200 { y + f_noise3d(x/10,0,z/2) }   // f_noise3d requires
'functions.inc'
  smooth
  translate<-0.5,0,-0.5>
  scale <100,1,100>
Date: 13 Mar 2007 19:57:22
Message: <45f74872$1@news.povray.org>
> differently)
> Thanks!
The problem with height fields is that they are limited to the cube from
<0,0,0> to <1,1,1>.  The functions for them take, as arguments, X and Y
rather than X and Z, and the height must never be <0 or >1 (actually it
can, but it wraps around, which is visually... disturbing).
I find isofurfaces easier because you can define their domain to be
anything you want; however, it is certainly true that HFs render
faster*.  If you can scale your function well in a HF, then it would
probably be a better solution.
...Chambers
*It is conceivable that, in the future, isosurfaces will render faster
than HFs simply due to the fact that the parse stage remains single
threaded while the trace stage runs in parallel.  Since isosurfaces
parse almost instantly, if you have enough cores on hand it the savings
in parse time could more than pay for the cost of trace time.
Date: 13 Mar 2007 21:35:15
Message: <45f75f63$1@news.povray.org>
news:45f70986@news.povray.org...
>> height-ripples
>> an
>                                                          - Warp
http://news.povray.org/povray.binaries.images/thread/%3Cweb.45d9a3a3e460fb2bc150d4c10%40news.povray.org%3E/
The water I use here is made in such a way.  The advantage of this too is
that I can dynamically change the resolution of the heightfield whe I want,
so I can give a low resolution to renfder faster while I'm testing other
stuff in the scene and bump the resolution up high for a quality render.  If
you'd like, I can post some example code for this tomorrow.
-tgq
Date: 14 Mar 2007 12:20:42
Message: <45f82eea$1@news.povray.org>
> his new site (http://www.nolights.de/main.html) but I cant see it for
> download. I'm sure that if you contact him he will be pleased to give
> you a copy. JUS### [at] gmxnetWARE
It's available for download on this page:
http://www.nolights.de/rnd/development.html#LSSM
Rune
http://runevision.com
Date: 15 Mar 2007 03:15:02
Message: <web.45f9003027ae231ef1cb1e660@news.povray.org>
> Rune
