POV-Ray : Newsgroups : povray.general : Shadow artifacts in converted Daz models Server Time
13 Apr 2026 00:18:59 EDT (-0400)
  Shadow artifacts in converted Daz models (Message 1 to 10 of 17)
Subject: Shadow artifacts in converted Daz models
Date: 1 Nov 2006 06:40:01
Message: <web.454886817b19ba87731f01d10@news.povray.org>
I have a problem; I don't have an image to hand to illustrate it but it's
easy to describe.
When rendering a Daz figure, converted from .obj with PoseRay, I've noticed
some shadow artifacts in the vicinity of the head that I don't understand.
Basically, the shadow of the head contains unlit areas which correspond to
the shadows of the eyes, eyelashes and eyebrows. I don't see how these
areas can be showing up because a) they should be opaque themselves, and b)
the rest of the head should also block this region.
I've had a hunt around in POV-Ray and PoseRay's docs but I can't find any
probable causes. Has anybody else noticed this, and if so, what's going
on!?
I'll try to post an example later this evening or tomorrow.
Bill
Subject: Re: Shadow artifacts in converted Daz models
Date: 1 Nov 2006 15:45:01
Message: <web.45490693da88e9cb113e81f30@news.povray.org>
Right. The problem definitely lies with transparency-mapped areas of the
mesh. The hair object exhibits the same behaviour. I still don't know what
to do about it though... :-(
Perplexed Bill
Date: 1 Nov 2006 16:48:52
Message: <45491644@news.povray.org>
  An image showing the problem could be of help.
Date: 1 Nov 2006 17:30:01
Message: <web.45491eadda88e9cb113e81f30@news.povray.org>
Yes, sorry, of course!
http://www.infradead.org/~wmp/shadow_eg.jpg
Mind the nudity! (That'll get it some attention :-) )
Bill
Date: 1 Nov 2006 23:54:35
Message: <45497a0b$1@news.povray.org>
Bill,
I quickly created a similar scene and could not reproduce.
See this image:
http://mysite.verizon.net/sfg0000/files/DAZ_test.png
Can you tell me what type of lights did you use?
Does this problem occur with the default free Aiko skin?
What skin did you use? I may have it so I can test it here.
regards,
FlyerX
Date: 2 Nov 2006 05:05:01
Message: <web.4549c224da88e9cb731f01d10@news.povray.org>
With my scene that would produce artifacts. I've had a little play and it
seems only to occur at certain angles, when the light is shining partly
across the face.
A normal point-light.
I've seen it happen with the default skin too.
I can't remember where I got it, but I think the character's called
Daniella.
I should also mention that I've seen this occur in both POV-Ray 3.6 and
MegaPov 1.21. I think it must be something I'm doing (or not doing) during
the export / conversion process... what did you use to convert the mesh? I
used PoseRay.
Thanks
Bill
Date: 2 Nov 2006 05:20:39
Message: <4549c677@news.povray.org>
web.454886817b19ba87731f01d10@news.povray.org...
> easy to describe.
> noticed
For what it's worth this drove me crazy when I worked on the "Reach for the
stars" image. It's even mentioned in the "Making of". See the artifact under
the kid's left eye: http://www.oyonale.com/iss/english/makingof_3.htm
I never found a solution, that's why the kid isn't facing the viewer in the
final image... It's definitely related to a mixture of transparent and
non-transparent zones in certain meshes, under certain lighting conditions.
G.
> b)
> on!?
> Bill
Date: 2 Nov 2006 06:20:00
Message: <web.4549d342da88e9cb731f01d10@news.povray.org>
That is helpful, actually. It proves (at least to my satisfaction) that it's
not something really obvious I'm doing wrong!
Is there anything special about how POV-Ray calculates shadows for triangles
in mesh2s? In particular, are the triangles' inside/outside directions
important? Aside from the transparency mapping, these regions are also
unique because they are non-closed areas floating over the rest of the body
mesh. Just a thought.
Could it also be relevant that my Aiko is actually in a union? I must
experiment with the CSG aspect tonight.
I shall ruminate further
Bill
Date: 2 Nov 2006 08:41:11
Message: <4549f577@news.povray.org>
Once I had similar artifacts (especially with the hair) when using DAZ figures.
As far as I remember (well, had no time for 'poving' since years) it had to do
with floating point (in)accuracy when using meshes with a scale like
1 PoV-unit = 1 m.
By scaling the mesh-figures (and of course the whole scene) in a way that
1 POV-unit equals 1 cm the artifacts went away.
Maybe you have the same problem...
regards
-Ive
Date: 2 Nov 2006 10:13:05
Message: <454a0b01@news.povray.org>
  I don't know if it has any effect on the rendering result, but if
you make it a mesh it will take less memory (and perhaps be a bit
faster to render).
  As someone suggested in another answer, try scaling the mesh (eg. 10 times
larger if the vertex values are very small, or 10 times smaller if the
vertex values are very large) to see if it helps. You'll have to do this
scaling in the modeller program. I'm not talking about the 'scale' keyword
in povray.
