POV-Ray : Newsgroups : povray.general : Light_group & no_shadow Server Time
28 Feb 2026 02:00:41 EST (-0500)
  Light_group & no_shadow (Message 1 to 9 of 9)
Subject: Light_group & no_shadow
Date: 27 Sep 2006 19:25:00
Message: <web.451b07e2acea95bfa0c272b50@news.povray.org>
Is there a problem with using no_shadow in a light_group? (PovRay 3.5 Linux)
I have modelled as lamp and placed it in a light_group with 2 point lights.
The light bulb texture has a high ambient value, yet it kept rendering very
dark.  After playing with it I discovered the dark is because of shadowing
from the point lights.  But the bulb has no_shadow on it, and the lights
are both shadowless!
If I render the lamp separately it is fine. I only get the problem in the
light_group.  And I need the light group because I don't want the point
lights in the rest of the scene.
Anyone seen this before or know how to get around it?
RG
Subject: Re: Light_group & no_shadow
Date: 28 Sep 2006 07:05:19
Message: <451bac6f$1@news.povray.org>
i think you cant use no_shadow in a light group ..
no_shadow can be use on a specific item on which you dont want to cast
shadows
if you need a light source which dont cast shadows ..you must use an
ambient_light, or reajust your assumed_gamma ...
news:web.451b07e2acea95bfa0c272b50@news.povray.org...
Linux)
lights.
very
> RG
Date: 28 Sep 2006 07:19:33
Message: <451bafc5$1@news.povray.org>
but ..there is some particularity
a light group looks like
light_group {
  light_source source and color
  sphere {position,radius /*no_shadows*/ }
  //global_lights off
if you add
global_lights on  in the light group then the light comming from others
sources will or will not illuminate your sphere, means that shadows will be
or not cast ..
Linux)
lights.
very
> RG
Date: 28 Sep 2006 07:23:01
Message: <451bb095$1@news.povray.org>
you should aware that a light_group dont contribute to light a scene ..it
only lights the objects in the light group without contributing in the
overall amouth of light of you scene ..
Linux)
lights.
very
> RG
Date: 28 Sep 2006 08:40:33
Message: <451bc2c1$1@news.povray.org>
"Penelope20k" <pen### [at] caramailfr> wrote in message
news:451bac6f$1@news.povray.org...
imho that makes no sense...
if you need a lightsource that doesn't cast shadows, you need to add
"shadowless" to your light_source
oh, and gonzo: if your texture has an ambient of 1 and still looks dark,
then either your pigment is dark or your global ambient light is set too
low (just leave that at 1, no need to change it)
cu!
Date: 29 Sep 2006 17:45:00
Message: <web.451d93b2c9fb1073a0c272b50@news.povray.org>
Doh!  That was it, thank you, just needed a prompt to look at the obvious...
Forgot I had dropped the global ambient level when I was playing around with
radiosity... and that's why I connected the problem to the light_group,
because I only needed the light_group for fill & highlights when not using
the radiosity.
Although still not clear on why it was darker where the shadows would be,
since I was using both shadowless on the lights and no_shadow on the bulb.
But it definitely followed the shadow area. I could change the darker areas
by turning one or the other of the lights off.
No matter, its working now.
RG
Date: 30 Sep 2006 12:18:17
Message: <451e98c9$1@news.povray.org>
gonzo nous apporta ses lumieres en ce 29/09/2006 17:44:
> the radiosity.
> RG
When doing radiosity, it's beter to use "default{finish{ambient 0}}" than
ambient_lights 0.
The first way, you can still use ambient lights. I only change the
global_settings ambient if I want to tint the ambient of the scene. Acording to
the documentations, it's the primary reason you have that.
Feel good?  Don't worry; you'll get over it!
Date: 30 Sep 2006 21:55:40
Message: <451f201c$1@news.povray.org>
Alain wrote:
>  I only change the
> Acording to the documentations, it's the primary reason you have that.
That's what I was doing... I had it at rgb <.438,.212,.098>.  Actually,
I probably should have seen the problem sooner but I never got far
enough with radiosity to see the lamp :-/  Radiosity + area lights was
waaaay too slow. It ran all night and was only on line 16.
Without the radiosity it just finished rendering after 19hrs 21min 32sec.
RG
Date: 1 Oct 2006 13:27:22
Message: <451ffa7a$1@news.povray.org>
gonzo nous apporta ses lumieres en ce 30/09/2006 21:46:
> Alain wrote:
>>  I only change the global_settings ambient if I want to tint the
>> ambient of the scene. Acording to the documentations, it's the primary
> RG
Do you use adaptive for your area_light? It can realy speed up things.
