POV-Ray : Newsgroups : povray.general : Text objects orientation problem Server Time
16 Apr 2026 09:33:56 EDT (-0400)
  Text objects orientation problem (Message 1 to 6 of 6)
Subject: Text objects orientation problem
Date: 19 Apr 2005 08:10:00
Message: <web.4264f3a2a28cc1e4601668100@news.povray.org>
Hello,
I use the following camera settings, which I derive from an OpenGL
projection matrix:
  perspective
  direction <0.0, 0.0, -1.0>
  right 1.40381791483 * x
  angle 83.0
  transform {
    matrix <
    0.19447261314,  0.767765769065, 0.610504812914,
    0.671023477777,  0.349843198668, -0.653710355293,
    -0.715477410038,  0.536791803748, -0.447153927808,
    -57.7085227966,  -52.2379188538, 28.1092147827
  inverse }
My problem is, that I cant find a transformation matrix for my text objects
to render in direction of the x-axis, like they normaly would.
Can anyone please help me with this?
Thanks
Andreas Moll
Subject: Re: Text objects orientation problem
Date: 19 Apr 2005 09:01:59
Message: <42650147@news.povray.org>
kerosin wrote:
> Hello,
> projection matrix:
> camera {
>   perspective
>   angle 83.0
>   transform {
>     matrix <
>   inverse }
i.e. apply no transformation?
simple, just use the identity matrix:
matrix
<1,0,0,0,
  0,1,0,0,
  0,0,1,0,
  0,0,0,1>
Otherwise, I'm not sure what you're asking....
~Mike
Things! Billions of them!
Date: 19 Apr 2005 09:03:05
Message: <42650189$1@news.povray.org>
Mike Raiford wrote:
> kerosin wrote:
>> Hello,
>> projection matrix:
>> camera {
>>   perspective
>>   angle 83.0
>>   transform {
>>     matrix <
>>   inverse }
>> objects
> matrix
> <1,0,0,0,
>  0,1,0,0,
>  0,0,1,0,
>  0,0,0,1>
Err.
<1,0,0,
  0,1,0,
  0,0,1,
  0,0,0>
~Mike
Date: 24 Apr 2005 15:50:00
Message: <web.426bf73f7e34b395c4fdd5a30@news.povray.org>
sorry bit this wont work, first I have to translate the label to the
position I want it to appear. If I dont use a transformation matrix, the
text has a very strange direction, e.g. try the POVRay file below. I would
be delighted if someone could help me out...
// To render this scene, call povray (available from www.povray.org) like
this:
// povray +I1.pov +FN +O1.png +Q9 +W659 +H524 -UV +A0.3
  perspective
  right 1.25763358779 * x
  angle 83.0
  transform {
    matrix <
    0,  1, 0,
    -0.00787083446969,  0, 0.999969024503,
    0.999969024503,  0, 0.00787083446969,
    -0.0784517526627,  0.145133942366, -6.29094362259
  inverse }
light_source { <2.1, 24.35, 0.27>, <0.8, 0.8, 0.8, 0., 0.>}
global_settings { radiosity { brightness 0.6 } }
background { <1., 1., 0.49, 0., 0.> }
// enter the path to your desired font here:
#declare BALLLabelFont              =
"/usr/share/fonts/wine/wine_marlett.ttf"
union {
text{ ttf BALLLabelFont, "test label",0.2, 0
  texture{ pigment{color rgb<0.33, 0., 0., 0., 0.> }
  finish{ambient 0.15 diffuse 0.85} }
  translate <-0.145134, 0.333343, 0.0810779 >
Date: 24 Apr 2005 16:02:13
Message: <426bfb45$1@news.povray.org>
objects
When you say "x-axis," do you really mean in the direction of the x-axis, or
are you saying that you want your text to face *towards the camera*? Because
by default, text always *will* be along the x-axis.
If you want it to face towards the camera, here's what I think you can do.
Your camera starts off facing in the negative z-direction, and then you use
a matrix (which I assume keeps the camera vectors perpendicular) to reorient
it and translate it. If we remove the translation part (fourth line of the
matrix), we'll get just the orientation of the camera. If we apply this to
the text, it should face the same way. Since your camera direction starts
off as <0,0,-1>, we'll also have to rotate the text around 180 degrees first
so that it's facing the right way.
So here's what I think you should try:
#include "transforms.inc"
text {
    rotate 180*y
    matrix <
    0,0,0>
    translate <...> // move into position
This is untested but it should be a good start, anyway.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 24 Apr 2005 18:55:01
Message: <web.426c23047e34b395c4fdd5a30@news.povray.org>
I found the correct way now:
First apply the inverse camera matrix, than rotate 180*y and x,
than apply the translation. Maybe someone else will have the same problem...
text{ ttf "font", "asdasd",0.2, 0
  matrix < 0, 1, 0, -0.860148, 0, 0.510045, 0.510045, 0, 0.860148, 0, 0, 0 >
rotate 180*y rotate 180*x
  translate < 13.1507, 88.4991, 9.21197  > }
