POV-Ray : Newsgroups : povray.general : Can I bake UV textures with Povray? Server Time
11 Sep 2025 17:22:52 EDT (-0400)
  Can I bake UV textures with Povray? (Message 1 to 10 of 27)
Subject: Can I bake UV textures with Povray?
Date: 19 Aug 2004 23:05:01
Message: <web.412569f73137e9f1406ebe00@news.povray.org>
I know there's a trick in Renderman to get the renderer to "bake" UV
textures from procedural textures, but is there a way to do the same in
Povray?
Thanks!
Subject: Re: Can I bake UV textures with Povray?
Date: 20 Aug 2004 07:53:15
Message: <4125e62b$1@news.povray.org>
> Povray?
> Thanks!
I'm not as familiar with baking textures as I am with cakes... Perhaps a
bit more detail will make this term less err-- esoteric.
I'm thinking that if you heat the UV Map to 350F, and leave it there
fore about 20 minutes, you'll have a nice fluffy sphere... ;)
~Mike
Date: 20 Aug 2004 08:03:29
Message: <4125e891$1@news.povray.org>
news:web.412569f73137e9f1406ebe00@news.povray.org...
> Povray?
A typical uv map takes its coordinates from <0,0> to <1,1>, so rendering an
orthographic view of the <0,0,0>,<1,1,0> area of plane{z,0}  textured with
the desired procedural pigment or normal should create a bitmap version of
that pigment or normal, usable for uv mapping. Totally untested...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 20 Aug 2004 09:41:49
Message: <4125ff9d$1@news.povray.org>
"Gilles Tran" <gitran_nospam_@wanadoo.fr> wrote in message
news:4125e891$1@news.povray.org...
> > Povray?
but that's baking a uv texture from a uv texture, pretty pointless if you ask me
I think ekolis wants an uv-map of a non-uv-map procedural texture, for example
an image that would, uv-mapped on a sphere, give the same result as sphere {0,1
pigment {bozo}}
But as far as I know, that's not possible with pov-ray, not for every type of
object anyway...
cu!
Date: 20 Aug 2004 10:25:47
Message: <412609eb$1@news.povray.org>
message de news:4125ff9d$1@news.povray.org...
> but that's backing a uv texture from a uv texture, pretty pointless if you
ask me
Hmm well that's the usual meaning of baking textures (at least in C4D). The
point is to turn a complex, computer-intensive procedural texture into a
fast-rendering bitmap. A typical use for instance is to bake procedural
dirt.
example
{0,1
> pigment {bozo}}
of
> object anyway...
For spheres it's almost straightforward : render a sky_sphere using the
pigment and a spherical camera in the center. The resulting map can then be
used on a sphere as an image map identical to the pigment, at the price of
some rotation and mirroring. For other primitives it's surely tougher and
probably requires a lot of maths...
G.
- Posters
Date: 20 Aug 2004 10:42:15
Message: <41260dc7$1@news.povray.org>
> Povray?
Is this what you are looking for:
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.6;
torus {
   4, 1
     uv_mapping
       marble
//      gradient <1, 0, 0>
       turbulence 0.4
       color_map {
         [0.2 color rgb  <1, 0.8, 0>*1.2 ]
         [0.8 color rgb <0.1, 0.3, 0.4>*1.5 ]
       scale <3, 1, 3>/4
   location <1, 1, -2>*4
   look_at <0, -1, 0>
light_source {
   100*<1, 1, -1>
   color rgb <1, 1, 1>
   shadowless
background { color rgb <1, 1, 1>/2 }
This code takes the procedural texture "residing"
in the region from <0, 0, 0> to <1, 1, 0> and
maps it onto a torus. It can of course be mapped
onto any primitive that has support for UV-mapping
in POV-Ray.
By applying some more math you can remove the
visible seams in the texture.
In this thread you will find an image of a shape
with a texture that is UV-mapped that way:
http://news.povray.org/povray.binaries.images/thread/%3CXns934A8B380763Dtorolavkhotmailcom%40204.213.191.226%3E/?ttop=197385&toff=1650
http://tinyurl.com/6ovqy
Tor Olav
http://subcube.net
http://subcube.com
Date: 20 Aug 2004 10:56:15
Message: <4126110f$1@news.povray.org>
> in POV-Ray.
Here's another exapmple
#declare MyTexture =
       marble
       color_map {
         [ 0.2 color rgb <1.0, 0.8, 0.0> ]
         [ 0.7 color rgb <1.0, 1.0, 1.0> ]
       turbulence 0.7
       scale <1, 3, 1>/6
     normal {
       marble 0.3
       turbulence 0.7
       scale <1, 3, 1>/6
     finish {
       ambient 0.2
       specular 0.8
sphere {
   -y, 4
   texture { uv_mapping MyTexture }
Tor Olav
http://subcube.net
http://subcube.com
Date: 20 Aug 2004 14:25:00
Message: <web.412641a68e935ceebad14a680@news.povray.org>
Well, Tor Olav, your first example gives me a nice textured torus, albeit
with some seams, and the second gives me a sphere that looks like a planet,
but what I really want to do it actually save the UV-mapped texture itself,
not the 3D render. Is there any way to do that? (I'm trying to make models
for a game and I want to make the models in Wings, export to Povray, put in
some procedural textures, generate UV textures in Povray, convert my Wings
models to the game's .X format, and add the UV textures back in, because
the game doesn't support procedural textures. I'd use Renderman but the
current Wings->Renderman exporter won't let me have different textures on
different faces of an object, while the Povray exporter will, and that's
something I'd like to use if at all possible ;-)
Date: 20 Aug 2004 14:59:05
Message: <412649f9$1@news.povray.org>
You can do something similar to what Gilles Tran suggested:
// Sample command line settings: +w1024 +h1024
#version 3.6;
global_settings {
   ambient_light color White
#declare Texture =
//      gradient y
       bozo
       color_map {
         [ 0.0 color rgb <0.4, 0.2, 0.4> ]
         [ 1.0 color rgb <1.0, 0.6, 0.0> ]
       turbulence 0.8
       omega 1.1
       lambda 0.9
       octaves 8
       scale <1, 1, 1>/18
     normal {
       bozo 0.4
       turbulence 0.8
       omega 1.1
       lambda 0.9
       octaves 8
       scale <1, 1, 1>/18
     finish {
       ambient color White
//      specular 0.4
box {
   <0, 0, 0>, <1, 1, 1>
   texture { Texture }
   translate -<1, 1, 0>/2
light_source {
   <1, 2, -1>*100
   color White
   orthographic
   right x
   up y
background { color Gray40 }
Tor Olav
http://subcube.net
http://subcube.com
Date: 20 Aug 2004 15:38:58
Message: <41265352@news.povray.org>
> box {
>    texture { Texture }
> camera {
>    orthographic
>    right x
>    up y
This would render a flat section of the texture. This is not what ekolis is
looking for.
I believe what he wants is this: consider a complex mesh floating in space,
with a procedural texture applied.
He wants to sample the procedural texture on the surface of the mesh in
order to create a 2D image, which, when applied with proper UV coordinates
on the mesh, will cause the mesh to look exactly as it did with the
procedural texture.
To answer his question, POV-Ray cannot do this on its own. I'm not even sure
if it can be done with SDL.
It would certainly be a useful feature for times when you want to animate a
mesh and have the texture remain static on it, yet still have textured it
procedurally.
 - Slime
 [ http://www.slimeland.com/ ]
