POV-Ray : Newsgroups : povray.general : Vector functions AAARRRRGGHH!!!!! Server Time
22 Mar 2026 18:15:26 EDT (-0400)
  Vector functions AAARRRRGGHH!!!!! (Message 1 to 10 of 10)
Subject: Vector functions AAARRRRGGHH!!!!!
Date: 18 Dec 2002 17:10:05
Message: <web.3e00ef7bd58b93e5332079d0@news.povray.org>
I've been trying to write some macros that need to analyze vectors and
perform operations on them, but, having absolutely no math background
whatsoever, I am getting way lost in the function explanations in the docs.
Is there somewhere I can find explanations and/or examples of them that are
understandable by us regular folk?
Along the same lines, it's obvious that a little trig could go a long way in
POV. Can someone recommend a beginning book or reference on trigonometric
functions that can be handled by a non-mathmatical sub-genious? Something
that at least explains all the terms used in the docs?
RG - Dammit Jim, I'm an artist not a mathmetician!
Subject: Re: Vector functions AAARRRRGGHH!!!!!
Date: 18 Dec 2002 23:36:35
Message: <3e014cd3$1@news.povray.org>
well, the vector functions I use a lot are as follows:
th = TAN-1(y / x)
  x = r * COS(th)
  y = r * SIN(th)
  r = SQRT(x^2 + y^2)
  y = x * TAN(th)
  y = COS-1(x / r)
sin(th) = y / r
cos(th) = x / r
tan(th) = y / x
th is the angle, r is the radius or magnitude, x and y are...x and y
the last 4 formulae I had to use for the scene I'm working on right now
(had to research some of 'em out 'cuz I didn't have them in my notes
before)
Hope this helps.
Tim Cook
Version: 3.12
Date: 19 Dec 2002 08:59:36
Message: <3e01d0c7@news.povray.org>
> in POV. Can someone recommend a beginning book or reference on
> trigonometric functions that can be handled by a non-mathmatical
> sub-genious? Something that at least explains all the terms used in the
> docs?
Well, I learnt trigonometry in the high school, where everyone had to learn
it: artist as well as mathematicians ;)
You could start here:
http://aleph0.clarku.edu/~djoyce/java/trig/ (uses java)
or here:
http://www.colorado-research.com/~gourlay/trig-tutorial/
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 19 Dec 2002 10:21:14
Message: <3e01e3ea@news.povray.org>
"gonzo" <rgo### [at] lansetcom> wrote in message
news:web.3e00ef7bd58b93e5332079d0@news.povray.org...
docs.
Perhaps the way to go here would be one at a time. If you post the function
with which you are having the most trouble, then someone can give you a less
overwhelming explanation. Try looking at the PoV code for the various vector
macros as well.
 -Shay
Date: 19 Dec 2002 13:25:04
Message: <web.3e020de32a8640e6d843c24b0@news.povray.org>
>macros as well.
> -Shay
Well, here's a good mouthful...
vcross(A,B) Cross product of A and B. Returns a vector that is the vector
cross product of the two vectors. The resulting vector is perpendicular to
the two original vectors and its length is equal to the area of the
parallelogram defined by them. Or to put in an other way, the cross product
can also be formulated as: AxB = |A| * |B| * sin(angle(A,B)) *
perpendicular_unit_vector(A,B) So the length of the resulting vector is
proportional to the sine of the angle between A and B.
1. what's a cross product?
2. what's a parallelogram?
3. AxB = |A| * |B| * sin(angle(A,B)) * perpendicular_unit_vector(A,B)????
4. what's a sine?
5. If a vector is just point in space, how can it have length & direction?
Thanks, this looks helpful.
RG - like I said, NO math backgound. When I went to high school, trig hadn't
been invented yet, and algebra was something they warned you about if you
*might* go on to college (and only then if you were a math or physics
major, computers hadn't been invented yet either).
Date: 19 Dec 2002 13:36:05
Message: <mv340vkqp3bcievj7j1d7f75b01ic978gi@4ax.com>
http://mathworld.wolfram.com/CrossProduct.html
http://mathworld.wolfram.com/Parallelogram.html
I nearly thought you are asking about ABX. This nearly the same question ad
first.
> 4. what's a sine?
http://mathworld.wolfram.com/Sine.html
If you are in the center of space and you want move yourself to that
vector/point you have to move yourself about some _length_ in some _direction_
You can follow links in mathworld if you don't understand terms listed there.
ABX
Date: 19 Dec 2002 14:24:34
Message: <3e021cf2@news.povray.org>
Well, a vector is not just a point. You can think of vectors as of arrows,
they have both length and direction. But if you know where the tail of the
arrow is, then the head of the arrow gives you a point in space; when it's
not specified otherwise, the tail is at the origin (the point <0,0,0>), so
a vector is an arrow with length and direction, but it's a point too. And
it can be used for quite a lot of things, sometimes with no meaning, it can
be used, for example, to store 3 numbers (like in colour vectors), or to
store a direction in space and a number (the lenght of the vector, which
doesn't need to have a meaning related to the direction)
Date: 19 Dec 2002 14:35:50
Message: <3E021FAE.BCF9CA43@att.net>
Sounds like you and I are in about the same place on the POV vs.
math-I-never-thought-I'd-use-so-I-didn't-pay-attention learning curve.
Just try & tackle isosurfaces! <g>
--Library Man
P.S. and since I do call myself LibraryMan on this list, I'd be remiss
if I didn't
also recommend you go to your local library and see if they have intro.
trig & geom. books!
Date: 19 Dec 2002 15:55:09
Message: <web.3e02304d2a8640e6d843c24b0@news.povray.org>
Heh heh, yeah I took a quick look at isosurfaces... the bruises are mostly
healed and my therapist says the twitch will be gone in another week or
so...
Ah, thanks, that's a helpful visualization.
And thanks ABX, for the mathworld links.  A LOT of info there! Probably
mostly over my head at this point but I can see it as a site that will be
more useful over time.
RG - finagle's 1st law: the perversity of the universe tends towards the
maximum
Date: 19 Dec 2002 17:07:10
Message: <3E02430D.8D5AB375@att.net>
> so...
lol!
