POV-Ray : Newsgroups : povray.general : New mesh type Server Time
22 Mar 2026 23:12:34 EDT (-0400)
  New mesh type (Message 1 to 10 of 14)
Subject: New mesh type
Date: 9 Oct 2002 23:20:05
Message: <web.3da4f198f1acbd18ccf4f70@news.povray.org>
Could it be possible to add a new and easier to use mesh type to povray 4?
From what I've seen elsewhere, it looks quite cumbersome and confusing to
write a mesh using smooth triangles.
How about a syntax like this:
mesh3{
  triangle{p1,p2,p3
    pigment{rgb1, rgb2,rgb3} // blended colours
    // or
    pigment{uv1,uv2,uv3} // using image texture, only from mesh
    // or
    pigment{rgb} // solid colour triangle
    smooth_vect{v1,v2,v3} // only used if smooth turned on in mesh
  image{filename} // used to specify texture
  smooth on // uses smooth_vect values for individual triangeles
            // works like in heightfield for any non-smoothed triangles
  tesselate on // uses tesselation to create curved surfaces, curve would
               // probably be based on smoothvect, and verticies from nearby
               // triangles
This looks like it would be more understandable when writing meshes by hand.
It would probably take longer to parse though.
What do you think?
Rohan _e_ii
Subject: Re: New mesh type
Date: 10 Oct 2002 03:36:00
Message: <3DA52DEF.8060009@free.fr>
[SNIP, I leave it to the others...]
Interesting (with irony!): How do you create the smoothness information
? By magic of the code, I presume ?
You might want to have a look at my tesselation patch which has a
'smooth' primitive (input a mesh, output a smooth mesh). There is too
many way to compute a smooth normal at a vertex for a collection of
triangle. see http://jgrimbert.free.fr/pov/patch/tessel/smooth.html
(beware, it's in french, so babelfish might help you too!)
>                // triangles
First that's not 'tesselate', it is 'surface subdivision' in your case.
Tesselation is when you have a finite solid object and end up with a mesh.
Subdivision is when you have a raw mesh and end up with a finer mesh
(with far more triangle, obviously intelligently placed...).
You should probably have a look at the bicubic patch object in Povray.
> What do you think?
There is more than mesh in native Pov.
Date: 10 Oct 2002 10:08:23
Message: <3da589d7@news.povray.org>
  I don't understand why it would be necessary to extend the pigment syntax
just to make writing a mesh "easier".
  Why do you want the 'pigment' keyword there anyways?
  Besides, meshes take textures, not just pigments.
  The other things were commented already in another post...
Date: 11 Oct 2002 12:57:29
Message: <chrishuff-C38579.12540911102002@netplex.aussie.org>
In article <web.3da4f198f1acbd18ccf4f70@news.povray.org>,
It really looks like you've misunderstood the entire texture syntax.
Your "pigment {blah1, blah2, blah3}" syntax would break consistency with
every other use of pigments, and would take a lot of work to implement.
And I don't know why you want some kind of "image{}" block that is
nothing like any other texture syntax in POV.
Your "smooth_vect" should say what it is: "normals", and the braces are
unnecessary clutter there. Your "tesselate" is really subdivision, and
would need a lot more parameters than just on/off. Similar for
smoothing: there are several possible algorithms to choose from.
Aside from all that, your proposed syntax really looks more cumbersome
to me, and it doesn't add anything that couldn't be added to the current
syntaxes and retain backwards compatibility.
Here is my proposal:
mesh {MESH_IDENT //add ability to deep-copy existing mesh.
    //these are supported just like they are now, with a few
    //restrictions loosened...no need for declared textures, for example.
    //The syntax would be exactly the same as for triangles outside a
    //mesh.
    smooth_triangle ...
    triangle ...
    //new syntax for smooth triangles:
    //If 6 vectors are specified, it is smooth
    triangle {p1, n1, p2, n2, p3, n3 ...}
    //Any shape can be tesselated into the mesh. The new triangles are
    //simply added to the mesh. Each shape can have its own specialized
    //tesselation methods...no need to re-tesselate height fields or
    //triangle primitives.
    tesselate {SHAPE TESSELATION_PARAMETERS}
    auto_smooth {SMOOTH_PARAMS}
    displace {DISPLACEMENT_ITEMS}
    subdivide {SUBDIVISION_PARAMS}
http://tag.povray.org/
Date: 11 Oct 2002 20:24:48
Message: <3da76bd0@news.povray.org>
  Perhaps better:
    function { FUNCTION } // each vertex is transformed according to this
  This function would be given extra information besides the x, y and z
of the vertex point (eg. the normal vector at the vertex, for example
named nx, ny and nz).
  Of course transforming vertices usually invalidates previously existing
normal vectors, so they must be either recalculated or entered otherwise
by the user. This is a bit problematic.
Date: 11 Oct 2002 20:43:40
Message: <chrishuff-FA3854.20385011102002@netplex.aussie.org>
In article <3da76bd0@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   Perhaps better:
That would be one possible displacement type. I wouldn't want it to be
the only one, and just "function {}" seems like a very bad syntax
decision, it says nothing about what the function is for.
Date: 13 Oct 2002 21:55:04
Message: <web.3daa233e7d95834218ccf4f70@news.povray.org>
What about using the center of the object as a reference point to calculate
the smooth vectors?
Then why is it somtimes referred to as tesselation?
Rohan _e_ii
Date: 13 Oct 2002 22:00:08
Message: <web.3daa246b7d95834218ccf4f70@news.povray.org>
It's meant to be a way of specifying different colours to each vertex.
Apologies for the confusion, as I hardly ever use textures, and am not used
to using them.
And just in case you were wondering, I haven't tried writing a mesh by hand
yet. Come to think of it, I haven't used a mesh in any of my scenes yet, no
idea why.
Rohan _e_ii
Date: 13 Oct 2002 22:20:03
Message: <web.3daa28bc7d95834218ccf4f70@news.povray.org>
There are pigments with more than one rgb, such as the checker and hexagon
patterns.
After all the telling off for my ignorance and stupidity regarding meshes,
I'm sorry I made the post in the first place. :-(
Rohan _e_ii
Date: 13 Oct 2002 23:23:32
Message: <chrishuff-C912E9.23183213102002@netplex.aussie.org>
In article <web.3daa28bc7d95834218ccf4f70@news.povray.org>,
> patterns.
But that is an entirely different case: one pigment with one pattern
that takes several solid colors instead of a blend of colors. This is 3
pigment items in a place where there should only be 1.
A triangle_blend pattern would at least be consistent, but wouldn't be
very useful.
