POV-Ray : Newsgroups : povray.general : Stars, sizes, and antialiasing. (Was: Re: Starfields...) Server Time
25 Nov 2025 15:09:51 EST (-0500)
  Stars, sizes, and antialiasing. (Was: Re: Starfields...) (Message 1 to 10 of 10)
Subject: Stars, sizes, and antialiasing. (Was: Re: Starfields...)
Date: 27 Aug 2002 14:25:17
Message: <web.3d6bc301b4c1e988cd0d0b840@news.povray.org>
On the subject of stars and starfields, how do you make little stars show
up?
Ideally in my mind I think (a) all stars should take up no more than one
pixel (unless using focal blur :-)), and (b) all stars in a pixel would
contribute to to the intensity of that pixel.
Yeah, I know that's not now raytracing works, but it seems it's almost
exactly like what goes on making Vista Buffers so I'm guessing it's
implementable.
Yeah, I also know this won't work with reflections, etc. but I don't see too
many reflective enough items to show stars anyway.
Or am I thinking about this in the wrong way?
Subject: Re: Stars, sizes, and antialiasing. (Was: Re: Starfields...)
Date: 27 Aug 2002 16:23:59
Message: <3d6bdfdf@news.povray.org>
there are two "correct" solutions coming into my mind:
1) Render the image in a very (I said VERY!) high resolution and scale down,
   wich is of course the same as render many rays to the same pixel.
2) Do forward raytracing and hope that you didn't set a to low recursion level...
Date: 27 Aug 2002 17:20:44
Message: <Xns9277ECD4D8FBEraf256com@204.213.191.226>
"ron_ivi" <nomail@nomail> wrote in
news:web.3d6bc301b4c1e988cd0d0b840@news.povray.org
> show up?
I was alsow thinking about this problem.
Imho - primitive "pivel" would be very useful.
syntax :
pixel {
  CENTER
  color
  TRANSFORMS
i.e.
pixel { <1e5,0,0>  <.1, .1, 1>*.8  rotate y*24 rotate z*143 }
will give nice star.
How to implement it ? quite simple.
1. take coordinates after all transforms, i.e. A=<100,250,380>
2. project it into screen, to get i.e. P=<12.0001, 10.05> pixel. So this
point is almost at center of pixel <12,10> in output image.
3. round screen cordinates (P), to P'=<12.0,10.0>
4. reverse-project it - find point more close to A, that projected on
screen gives A'. i.e. P'=<101,245,380>
The intersection test of 'pixel' is same as sphere with radius==epsilon (or
some tolerance value)
There are 2 problems :
- pixel will disapera when strong AA is on
- too many small pixels without AA will make strange effect
Date: 27 Aug 2002 22:50:11
Message: <3d6c3a63$1@news.povray.org>
Here's a starfield I just used.  I shoudda increased the number of stars....
background{rgb 0}
#declare RRR=seed(123);
#declare n=0;
#while(n<3000)
sphere{500000*<
        sgn(rand(RRR)-0.5)*(0.15+rand(RRR)),
        sgn(rand(RRR)-.5)*(0.15+rand(RRR))+.5,
        sgn(rand(RRR)-0.5)*(0.15+rand(RRR))>
        ,1000 pigment{rgb 1} finish{diffuse 0 ambient 1}}
#declare n=n+1;
Date: 28 Aug 2002 01:44:31
Message: <pcoomu0h81fboa4quc4p3biollbbipt8rs@4ax.com>
On 27 Aug 2002 17:20:44 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> pixel {
>   CENTER
>   color
>   TRANSFORMS
If this is the same as sphere then why to implememnt it at all ?
It should be very simple to write macro where according to camera location,
transformation and imagesizes you can create sphere with correct finish and
location to be considered as "point" object. You can use for calculations
macros posted by me at http://news.povray.org/povray.text.scene-files/23663/
ABX
Date: 28 Aug 2002 06:35:03
Message: <web.3d6ca6a71435c76e541c87100@news.povray.org>
>up?
>implementable.
I would have thought that (especially for animation) the stars should be
sampled by at least two pixels across the diameter. Since the angular
resolution of the image will be known (for a particular field of view and
linear resolution) it's trivial to work out what the diameter of a
spherical or circular star should be to cover two pixels if the distance
from the star to the camera is known.
I have made many scenes where reflection of a starfield is involved. I'm
still puzzled as to what's wrong with just placing a lot of
spheres/discs/triangles a very great distance from the camera. I find it
looks good whilst preserving speed and simplicity.
Date: 28 Aug 2002 19:28:40
Message: <chrishuff-C826A0.19275628082002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
Oh, yes, very simple...why don't you explain how to project it onto all
the different camera types? Taking camera normals into account?
What is the point of this? What do you do with this reverse-projected
point? Treat it as an intersection? Or some kind of atmospheric effect,
like a glow?
Why even bother? The chances of a ray hitting the sphere are vanishingly
slow, so might as well not intersect with it at all. It would just slow
things down.
I really don't see how this is a good idea. POV is a raytracer, and this
isn't a raytracing primitive. And why just pixels? Why not lines,
circles, polygons, etc...and what about antialiasing? If everything is
unantialiased, it won't be very useful.
It might make sense as a post-process filter working in image space,
since it is really 2D drawing on top of the image.
Really, the best thing I can think of would be:
Somehow tell POV to use a higher minimum antialiasing sampling on parts
of the image that hit a certain object (the sky object).
Use "super-bright" colors (with components > 1) for the stars, make the
stars about the size of a pixel.
Clip colors after doing the antialiasing filter, as some kind of flag or
render option if you prefer it that way.
The minimum supersampling makes it more likely a pixel gets hit, the
clipping change allows the star to contribute the proper amount to the
pixel.
http://tag.povray.org/
Date: 29 Aug 2002 02:26:43
Message: <Xns9279553DF7A4Craf256com@204.213.191.226>
Christopher James Huff <chr### [at] maccom> wrote in
news:chr### [at] netplexaussieorg
> all the different camera types? Taking camera normals into account?
it will use same alghoritm as vista buffer - to project 'pixels' on
view-plane
> effect, like a glow?
> vanishingly slow, so might as well not intersect with it at all. It
> would just slow things down.
the point of finding P' is that RAY will hit this very small sphere,
because one of rays (for point A') will go straight throug center of sphere
> this isn't a raytracing primitive. And why just pixels? Why not lines,
> circles, polygons,
'pixels' will be very useful for stars. This name mabe isn't good.
In short - this would be primitive simmilar to sphere, _but_ it will act
diffrent in anti-aliasing.
While using typical sphere { } generatet with macro that will make it i.e.
1 pixel wide - this sphere will disapear when strong AA is used.
only stars
the point is to draw it behind image, but You are right - this alsow can be
drawn in post-process.
This is one of reasons while im trying to develop output file
(.programming) that will contain many informations like i.e. Z/distance of
point - to determinate is this point a background.
> parts of the image that hit a certain object (the sky object).
> the stars about the size of a pixel.
> or render option if you prefer it that way.
btw. after all - I think that post-processing is WRONG for starts - think
about simple plane + statrs scene - it will render ok, but add
  sphere { 0 10 finish { reflection .7 } pigment { color rgb 1 } }
the sphere will NOT reflect stars at it should
Date: 29 Aug 2002 02:35:30
Message: <npfrmuk9t4dlhj9gr55k1scdblc26knpi4@4ax.com>
On 29 Aug 2002 02:26:43 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> view-plane
"The vista buffer can only be used with perspective and orthographic cameras"
why ?
If you make sphere one pixel size it will not disapear.
> only stars
why to make primitive to only one purpose while you can for example make
spherical mapping of enviroment on sky_sphere
ABX
Date: 29 Aug 2002 22:14:56
Message: <chrishuff-92DF8D.22141829082002@netplex.aussie.org>
> view-plane
The vista buffer only works with 2 camera types. And with those, I don't
think it works with camera normals or certain camera transformations.
If you already know the adjusted location of the point, why bother
testing for an intersection with a tiny sphere at that location?
How will it reflect your "pixel" primitive? That isn't any improvement.
Adjusting the antialiasing algorithm and using high-brightness spheres
or textures (or something like glows) seems like a better idea to me.
