POV-Ray : Newsgroups : povray.general : Foot Ideas Server Time
31 Mar 2026 11:38:03 EDT (-0400)
  Foot Ideas (Message 1 to 10 of 11)
Subject: Foot Ideas
Date: 19 Aug 2003 10:27:33
Message: <slrnbk4cse.42b.povfan@corky.voltar-confed.org>
The people in this group are so helpful I can hardly stand
it.  So, before I start, thanks!
I'm trying to make something like this:
    http://samarkand.net/Web_store/Html/Images/20F_foot.jpg
I tried to make a sphere and cut it with toroids... I got
this and this:
    http://www.voltar.org/tmp/goban2.snaps/colorballs.png
    http://www.voltar.org/tmp/goban2.snaps/wronglegs.png
It's rough, obviously, but clearly isn't the shape I was
going for. :) In fact, CSG may be the wrong approach
entirely.  Though, I have made some complicated things with
CSG:
    http://www.voltar.org/povray/lightsaber-030321160919.png
    http://www.voltar.org/povray/warhammer-0302281425.png
What I can't figure is how to do those little ridges on the
20F_foot.
1) Any suggestions to get to my 20F_foot welcome --
especially CSG methods?
2) What mesh editors are popular for this sort of thing?  I
got both wings3d and pygmalion working, but I don't appear
to be any good at all with 3d (totally incompetant actually)
modeling UIs.
If riding in an airplane is flying, then riding in a boat is swimming.
41 jumps, 8.9 minutes of freefall, 19.2 ff vertical miles.
Subject: Re: Foot Ideas
Date: 19 Aug 2003 10:47:09
Message: <jud4kv8h9f4k714mq2m1e86e9a6dioaril@4ax.com>
On 19 Aug 2003 10:27:33 -0400, Jettero Heller <pov### [at] voltar-confedorg>
This reminds me this image:
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/sample09.jpg
I you think it looks similar jump to:
http://www.tu-bs.de/~y0013390/pov/ic/
ABX
Date: 19 Aug 2003 11:14:31
Message: <slrnbk4fkg.mgk.povfan@corky.voltar-confed.org>
Yes, this looks very promising.  I'm going to try some of
this stuff out later for sure.
Date: 19 Aug 2003 12:02:16
Message: <3f424a08@news.povray.org>
"Jettero Heller" <pov### [at] voltar-confedorg> wrote in message
news:slr### [at] corkyvoltar-confedorg...
<snip>
As ABX suggested, iso-wotsits are certainly one way to go, but may be slow.
Your original idea of a CSG of torii and sphere looks like the right way to go.
For example,
#declare myTorus = torus{1, 0.5}
difference{
  sphere{0,1.25}
  #declare YRot = 0;
  #while(YRot < 180)
    object{myTorus rotate z*90 scale<1,1.5,1> rotate y*YRot translate y*1}
    #declare YRot = YRot + 15;
  pigment{Yellow}
shows possibilities....
Date: 19 Aug 2003 12:27:58
Message: <3f424fce.203316904@news.povray.org>
On 19 Aug 2003 10:27:33 -0400, Jettero Heller <pov### [at] voltar-confedorg> wrote:
You could try Moray
http://www.stmuc.com/moray/index.html
Moray is a shareware program and must be registered after a trial period of 30
days. It costs EUR 80 and it is well worth it as it is made specifically for
PovRay.
Regards
Date: 19 Aug 2003 12:45:04
Message: <slrnbk4ku8.nq0.povfan@corky.voltar-confed.org>
> For example,
Doh!  Ok, I'm not going to look at mesh objects much then,
this is probably what I wanted.  I did this while I was on
lunch...  Clearly wrong, but later on I can make my legs
with it.
http://www.voltar.org/tmp/goban2.snaps/wrongleg2.png
I had considered scaling my colored torii, but didnt think I
could get that to work right. Did you just guess on the
ratio?  Or do you know some sphericaltorid math properties
that I don't?
Anyway, thanks. :)
Date: 19 Aug 2003 12:49:23
Message: <slrnbk4l6c.skn.povfan@corky.voltar-confed.org>
> You could try Moray
Oooo, that _is_ neat.
It definitely looks like it's worth trying.  If I work up
the energy to install something on my windows machine I
might check that out too.
Any idea if the user interface is easier to figure out than
wings3d and pygmalion?  Moray looks like it might be beyond
my skill level too.
So far I've done all my pov images in vim.
Date: 19 Aug 2003 13:11:00
Message: <3f4259f1.205911725@news.povray.org>
On 19 Aug 2003 12:49:23 -0400, Jettero Heller <pov### [at] voltar-confedorg> wrote:
I've tried wings3d and IMO Moray is much easier to use. It's quite intuitive,
uses a lot of the standard PovRay primitives, sweeps, lights etc. It exports a
PovRay file that can be tweaked and animated. It is supported by many plugins,
including an animation one, if your interests lie in that direction. There is a
new version in Beta test just now which should be even better. This server has
news groups dedicated to it.
>my skill level too.
After looking at you Light Sabre and war hammer, I doubt it is beyond you.
Regards
Date: 19 Aug 2003 13:16:51
Message: <3f425b83$1@news.povray.org>
For gobans I made, I used isosurface objects:
Two half of sine a sphere for the foot:
  function {sqrt( x*x + y*y + z*z ) - .9 + abs(sin( 4*atan2(x, z) )*0.1)}
(the two half spheres are on top of each other and top one is scaled
down along y).
One sine-cylinder for the leg:
  function {sqrt(x*x + z*z) - 0.9 + abs(sin(4*atan2(x, z))*0.1)}
I will post the image in p.b.i so you can see the result.
Nicolas
> this and this:
> CSG:
> 20F_foot.
> modeling UIs.
Date: 19 Aug 2003 14:39:02
Message: <3f426ec6@news.povray.org>
> that I don't?
Pure guesswork and a dozen or more different rotation/scaling/radius
settings, plus a general hunch that it was possible. To be honest, I'm still
not entirely sure what's happening in my code (but I haven't looked to
closely).
I know from experience that very ornate shapes are easy to conjure out of
CSG if you just let things happen and wrap some generation code in a loop or
two.
