POV-Ray : Newsgroups : povray.general : Show Button with a memory Server Time
21 Feb 2026 17:06:56 EST (-0500)
  Show Button with a memory (Message 1 to 10 of 11)
Subject: Show Button with a memory
Date: 12 Mar 2004 07:58:34
Message: <opr4q2e0eqp4ukzs@news.povray.org>
I was wary of posting this to p.programming as although it is to do with
POV-Ray the program it's something that may already exist that I've missed.
I have two files open File1 and File2 I render them both in that order, I
switch to edit File1 and hit show and of course the File2 image appears,
is there any way that POV-Ray can retain a memory that File1 has been
rendered and display *that* image as opposed to the last one. I wouldn't
expect it to last beyond the session, but a temporary memory would be nice
IMHO instead of having to open an external imager to see the image or
re-render.
I'm well prepared to be slapped down on this if the implementation is
horrendous or if it's some switch I've missed, but it was just a thought.
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Subject: Re: Show Button with a memory
Date: 12 Mar 2004 08:12:10
Message: <4051b72a$1@news.povray.org>
Program ended abnormally on 12/03/2004 08:00, Due to a catastrophic Phil Cook error:
p.programming is for discussing the actual source code.  Feature requests should
go here.
> I switch to edit File1 and hit show and of course the File2 image
> appears, is there any way that POV-Ray can retain a memory that File1
> has been rendered and display *that* image as opposed to the last one. I
> wouldn't expect it to last beyond the session, but a temporary memory
> would be nice IMHO instead of having to open an external imager to see
> the image or re-render.
No it isn't a switch you've missed.  The "show" button will only display the
last image you've rendered.
I agree with you that having a more versatile "show" button (or having a menu
item that allowed to display recently rendered images) could be a nice addition
that wouldn't be too hard too implement, but having an image viewing app loaded
on your pc alongside POV isn't too hard for the user to implement, either. ;-)
Date: 12 Mar 2004 09:06:29
Message: <nrf350h149mo8ltlv0qjs7i7o52072derp@4ax.com>
On Fri, 12 Mar 2004 13:00:26 -0000, Phil Cook
Start two instances of POV-Ray and edit one file in each of them. You
may have to uncheck the "Keep single instance" option if it is
checked.
Peter Popov ICQ : 15002700
Date: 12 Mar 2004 10:01:08
Message: <opr4q729qop4ukzs@news.povray.org>
On Fri, 12 Mar 2004 08:00:02 -0500, Francois Labreque
> Cook error:
>> with POV-Ray the program it's something that may already exist that
>> I've missed.
> requests should go here.
Good I was worried I'd offend someone.
>> I wouldn't expect it to last beyond the session, but a temporary memory
>> thought.
> the last image you've rendered.
Oh goodie, not me being dense as usual then,
> menu item that allowed to display recently rendered images) could be a
> nice addition that wouldn't be too hard too implement,
It's just something I thought of as I wanted to show someone a render I'd
just done, but had one in-between which meant opening up an extra program.
> but having an image viewing app loaded on your pc alongside POV isn't
Umm, but that's a little similiar to the argument being held over
JPEG2000, why should someone have to open an external viewer when the
program you're using supports inline viewing. IMO it's not a difficulty
just err... inelegant :)
Phil
Date: 12 Mar 2004 10:09:09
Message: <opr4q8gnzap4ukzs@news.povray.org>
>> thought.
> checked.
Ah which would explain why I couldn't get two working at the same time,
admittedly I was a little concerned over opening multiple instances, I
should have remembered how robust POV-ray is :) Oh good that allows me to
render multiple images simultaneously, <sigh> still seems a little
inelegant to me having a program that can hold multiple files and then
opening a separate instance of it, oh well at least I know a way round it
now, thank you.
Phil
Date: 12 Mar 2004 11:06:23
Message: <4051dfff$1@news.povray.org>
In article <opr4q2e0eqp4ukzs@news.povray.org> , Phil Cook
> re-render.
The Mac version displays as many images as you want, so which version are
you talking about?  Windows or Linux or another one?
    Thorsten
e-mail: tho### [at] trfde
Date: 12 Mar 2004 11:23:55
Message: <opr4rbw8byp4ukzs@news.povray.org>
On Fri, 12 Mar 2004 17:06:21 +0100, Thorsten Froehlich <tho### [at] trfde>
<snip>
>> I
>> nice
>> re-render.
>> thought.
Oops sorry my bad, Windows, v3.5. 'Show' only displays the last rendered
file regardless of which file you're currently editing, multiple instances
of POV-ray show the last render as per each instance.
Phil
Date: 13 Mar 2004 05:55:05
Message: <4052e889@news.povray.org>
"Phil Cook" <phi### [at] nospamdeckingdealscouk> wrote in message
news:opr4rbw8byp4ukzs@news.povray.org...
To be more specific, 'show' doesn't actually display a rendered 'file'; it
re-displays the pixel data that is still stored in memory after the display
window was closed.
It does not read a file from disk, as you seem to think. POV-Ray is not an
image viewer, nor is it meant to be (as there are other programs that do
that quite well).
-- Chris
Date: 13 Mar 2004 11:47:02
Message: <opr4s7yzdwmpsiks@news.povray.org>
On Sat, 13 Mar 2004 21:55:01 +1100, Chris Cason
>> instances
> it
> display
> window was closed.
> an
> that quite well).
Actually I thought that might be the case and was prepared for someone to
give that as a reason why 'Show' didn't work in that way; but as the
compression algorithms to output to certain formats are obviously present
I thought it might be a possibility that the full codecs was implemented
and that it *may* be made to work in that way and that I had just missed a
switch somewhere: obviously not.
Phil
Date: 18 Mar 2004 20:49:56
Message: <405a51c4@news.povray.org>
Reading your post, I'd like to take this moment to say I'd appreciate a
"Show" button that would remember at least the last 3 or 4 images rendered.
The user could set this as an option to the windows executable (on other
platforms ymmv) choosing how far back the memory should go.
As a side note, has there been any attempt to write a GUI for POV that is
cross platform, or do most people who just give in and use emacs? :)
...Chambers
http://www.geocities.com/bdchambers79
