POV-Ray : Newsgroups : povray.general : Did I miss anything? (parent/child texture in CSG) Server Time
16 Apr 2026 07:07:20 EDT (-0400)
  Did I miss anything? (parent/child texture in CSG) (Message 1 to 10 of 12)
Subject: Did I miss anything? (parent/child texture in CSG)
Date: 31 Jan 2024 08:14:39
Message: <65ba47bf@news.povray.org>
Ok, first, small picture to capture you attention (attached).
Now, problem I have with that. I'm using nested objects of objects
(small POV example attached), and it seems like when I enable pigment or
something at the minimal level, it overcomes instructions for top
object. Sorry, haven't found anything about it in POV help.
My problem is, I want a per-object normal, rather than per-union. But
when I uncomment
#declare bublik = torus {0.5, 0.25
//    normal {spiral1 5, 0.1 blah-blah-blah
pigments for all the objects made from "bublik" go to hell. I want
colors from that higher level objects, but normal from "bublik" since it
have orientation I want. Any chances I can have it? Did I miss anything?
(in help file, I mean)
Ilyich the Toad
Download 'l1.png' (237 KB) Download 'windows-1251' (1 KB)
Preview of image 'l1.png'
Subject: Re: Did I miss anything? (parent/child texture in CSG)
Date: 31 Jan 2024 09:45:00
Message: <web.65ba5c43d90d9b2b1f9dae3025979125@news.povray.org>
Excellent.   This is very cool.  :)
More please!
> when I uncomment
So, you're in very tricky territory right here.
I think what you might need to do is give each item a layered texture - try
making the base layer your pigment, and the top layer clear, but with a normal.
object {
     bublik
     texture {pigment {}}
     texture {pigment {rgb 1} normal {MyNormal}}
Or something like that.
- BW
Date: 31 Jan 2024 11:25:28
Message: <65ba7478$1@news.povray.org>
> More please!
Long ago I did something for textile simulation using normal 2D approach
(well, more like 2.5D), but it went to people who paid for it. But now,
with CPU speed drastically improved, chances are I can use 3D for this.
But so far prototype is full of junk, and I have next to no idea how to
simulate irregular displacement.
But anyway, I'll share it on my github place when I remove all the junk
I can find and add something looking more interesting than plane plastic
wire. This grid is typical to linen, for example, but I need linen
texture for it.
What as to textures, surely, I can decompose whole object down to thors,
sorry, as you were, tori (damn it, aren't tori some sort of gates in
Japan? anyway, I mean plural for donut) and assign anything necessary to
each of them separately, but it will make development and especially
debugging somewhat more complicated.
Ilyich the Toad
https://github.com/Dnyarri/
Date: 1 Feb 2024 00:37:47
Message: <65bb2e2b$1@news.povray.org>
The usual way is to use the fast path texture element overrides.
#declare Fn00 = function { pattern { spiral1 12 scale 1/6} }
#declare Fn01 = function { pattern { wrinkles scale 1/99 } }
#declare Tor00 = torus {
     0.5, 0.15
     // What follows are overrides of the default texture's
     // three components - creating a new texture for Tor00.
     pigment { White }
     normal {
         function { (Fn00(-x,y,z)+Fn01(x,y,z)*0.2)/1.2 }
         bump_size +0.67 rotate x*90
         accuracy 0.005
     finish { ambient 0.0 brilliance 1.5 }
object { Tor00 } // White around origin.
// White on left side of image
union {
     object { Tor00 translate y*-0.7 }
     object { Tor00 translate y*+0.7 }
     pigment { Green } // Ignored where objects are textured.
     translate (x+z)*-1.25
// Following is a way to override just the pigment component
// of the texture already on Tor00.
union {
     object { Tor00 pigment { Green } translate y*-0.7 }
     object { Tor00 pigment { Red }   translate y*+0.7 }
     translate (x+z)*+1.25
There are limitations to the approach where the texture{}s are
non-simple (ie layered) or a material{} is used.
Bill P.
Aside: Remember how in v3.8 beta2 is spiral1 is really spiral2 due a
typo? Well, I coded a v3.7 version for posting here after my yuqk
version (where spiral1 is spiral1) and, dang if doesn't look like the
rotate of the spiral has been flipped in yuqk / v3.8? relative to v3.7.
I don't think this something I did, but suppose I might have to create
a fixed version of v3.8 beta 2 to be sure...
Download 'keepnormal.jpg' (51 KB)
Preview of image 'keepnormal.jpg'
Date: 1 Feb 2024 07:20:00
Message: <web.65bb8c5dd90d9b2b1f9dae3025979125@news.povray.org>
I always thought that once the object was textured, it was fixed, and could not
be overridden.  This has been discussed in the past, so I'm surprised.  I also
do a lot of scenes where I have some objects in a union textured/pigmented and
then the union gets a texture/pigment, and only the default textured objects get
the union texture.
I thought you had fixed the uv-mapping of the torus, so that it's consistent
with all of the other primitives, and not backwards anymore.  Does that have
anything to do with it?  (probably not, but...)
- BW
Date: 1 Feb 2024 08:19:55
Message: <65bb9a7b$1@news.povray.org>
> the union texture.
It can be confusing and we're not helped due some of the documentation
being misleading.
Internally what happens is things not explicitly textured with
texture{}(s) / material{} or by creating a texture via one of the fast
path / shorthand texture component texture specifications, like a not
texture{} wrapped color or pigment{} block specification, are not
textured at all until a post process step of the parsing.
In that post step the parent 'stuff' which exists is pushed down onto
the children - or the default texture gets applied - where there isn't
already 'stuff'. (lying a little)
The thing about the fast path texture component methods is they
sometimes assign the default texture and modify a particular component
of it. Or, they modify a particular component of the existing attached
texture. Supposing an already textured Tor00 and Tor01 with no texture.
object { Tor00 pigment{...} } // Modifies the already attached texture.
object { Tor01 pigment{...} } // Modifies / applies default texture
object { Tor00
// Replaces attached texture with modified, default texture. The
// texture{} wrap without a passed texture ID always starts with the
// default texture.
   texture { pigment {...} }
Aside: Good memory on the torus uv mapping! :-) One of the three forms
was mistakenly created right handed. I do still flip it to left handed
as I recall in the yuqk code. The official v3.8 POV-Ray releases left
the mapping code as is. At the moment, not sure how it could be related,
but maybe? I'm in the middle of some other code work, so the
investigation on the spiral 1 & 2  won't happen for a while.
Bill P.
Date: 8 Feb 2024 04:01:20
Message: <65c49860$1@news.povray.org>
Sorry for extremely dumb question but I'm too slow and looks like I'm
missing something.
It seems like people are capable to define procedural, that is,
algorithmic textures and stuff (for example, normals), to be calculated
by POVRay internally, to be used in scenes. I mean defining them as some
sort of non-POVRay-specific built-in functions but rather as some
general math function similar to that in general programming languages.
I, however, am unable to find any understandable docs regarding this. I
guess I'm completely wrong somewhere - asking wrong questions, searching
in wrong places, etc. Any ideas regarding what may be the right place to
get something to read?
Ilyich the Toad
Date: 8 Feb 2024 07:25:00
Message: <web.65c4c7e3d90d9b2b1f9dae3025979125@news.povray.org>
Welcome to functions!
https://wiki.povray.org/content/Reference:Function
"Declaring User-Defined Color Functions
Right now you may only declare color functions using one of the special function
types. The only supported type is the pigment function. You may use every valid
pigment. This is a very simple example:
#declare foo = function {
    color red 1
#declare Vec = foo(1,2,3)
An example using a pattern:
    crackle
    color_map {
      [0.3, color Red]
      [1.0, color Blue]
Date: 12 Feb 2024 20:14:14
Message: <65cac266$1@news.povray.org>
On 2/8/24 04:01, Ilya Razmanov wrote:
> Any ideas regarding what may be the right place to get something to read?
Glad Bill W got you started with answers.
I'd add that a look at the documentation for isosurface and parametric
surfaces - which are based on functions - might help. There are user
defined pigments, densities, cameras possible too with examples. You can
search the shipped example scenes for 'function'. Of course patterns and
their modifiers are more or less functions of a sort too.
Ah, and you can look at the functions.inc include itself for
descriptions of the inbuilt functions and their parameters in official
releases of POV-Ray. I think a rough copy of the documentation therein
is include somewhere in the official web documentation too. The warning
I'd give is not all of the function.inc function and parameter
description are accurate - it something seems really confusing, it might
be a documentation mismatch. It is what is.
As for a really good, all in one tutorial, Mike Williams published what
I think was the best one for functions and isosurfaces / parametrics. It
was one from which I learned a lot, but the web site is no longer
active. The wayback machine has a copy and, IIRC, Bill W (or someone)
put a copy of a lot of it somewhere accessible?
I'm attaching scene and image output file. The scene started with Mike's
cylcoords.pov from that tutorial - which I modified somewhat as the
attached version given you were working some with textured torus
objects. Once the base shape is in place, it's possible to get many
different looks by changing parameters to the component functions. I
often find it fun to just push parameters around and render repeatedly
just looking at what appears in the final render.
Aside: My yuqk fork differs substantially with respect to built in
functions and the interplay between patterns and functions - and I'm
still hacking on the inbuilt code quite a bit. I don't have ready
documentation which relates well to official POV-Ray releases. Yuqk's
documentation for concepts sometimes OK, but particulars will often be
different.
Bill P.
Download 'cylcoords1.jpg' (98 KB) Download 'cylcoords1.pov.txt' (2 KB)
Preview of image 'cylcoords1.jpg'
Date: 13 Feb 2024 06:35:00
Message: <web.65cb5338d90d9b2b1f9dae3025979125@news.povray.org>
Thanks for the reminder.
I just sent him a copy.
I think the document (pdf) is ~4mb, and the zip is 176 kb.
Perhaps we can find a spot to host the files?   The Wiki?
A link from the main page?   References?
- BW
