POV-Ray : Newsgroups : povray.general : Focus Blur model Server Time
18 May 2024 22:38:07 EDT (-0400)
  Focus Blur model (Message 1 to 10 of 12)
Subject: Focus Blur model
Date: 18 Jun 2018 06:05:01
Message: <web.5b27829cac8990aa601b3e010@news.povray.org>
I am trying to use a pair of datasets generated with POV-Ray(links below) in
order to test a depth from defocus cue algorithm but I know almost nothing about
POV-Ray and I can't figure out the parameters for the camera. What I need is:
- The aperture diameter of the camera (it says on the site that it is 40 but
that seems physically inaccurate).
- The focal length of the lens.
- The sampling period of the pixels.
I have experimented a bit with the dataset, the code is on:
https://github.com/CrisDamian/BlurEqualisationTechnique
There is also an issue on this:
https://github.com/CrisDamian/BlurEqualisationTechnique/issues/1
Datasets:
http://devernay.free.fr/vision/focus/patio/
http://devernay.free.fr/vision/focus/office/
Subject: Re: Focus Blur model
Date: 18 Jun 2018 16:32:58
Message: <5b2816fa$1@news.povray.org>
That's NOT a diameter but that's about the horizontal field of view, in
degree, of the default camera.
> Datasets:
In POV-Ray, there is no real diameter for the camera and no real focal
length. Unless defined otherwise, it's an ideal pinhole camera.
When you want to enable focal blur, you need to define an arbitrary
aperture and set a focal point. The effective focal plane is
perpendicular to the line going from the camera to the focal point.
There is no concept of f stops.
The area of sharpness depend on the ratio between the aperture and the
distance from the camera location to the focal point
Sample camera with focal blur :
camera{location -20*z
  up y // default
  direction z // default
  right 4/3*x // default if version <= 3.7
  aperture 0.25
  focal_point <0,0,0> // default
  blur_samples 100// maximum number of samples to take.
  confidence 0.99 //Must be less than 1
  variance 1/256 //must NOT be zero
This setup result in a camera that is close to a camera at f80 with an
horizontal field of view of about 40°.
The samples are taken in a roughly circular pattern.
You can set a minimum number of samples by using two values for
blur_samples :
blur_samples 12, 100
The samples are simply averaged to get the final value for the current
pixel been rendered.
Date: 18 Jun 2018 19:04:20
Message: <5b283a74$1@news.povray.org>
Edouard Poor posted a "35mm Camera Macro" package back in 2009 which
might be of some help.
http://news.povray.org/povray.binaries.images/thread/%3C49c0b1af%241%40news.povray.org%3E/
Bill P.
Date: 19 Jun 2018 03:20:01
Message: <web.5b28ad704ad23916601b3e010@news.povray.org>
>   up y // default
>   aperture 0.25
> blur_samples :
I have found an attached `patio_stereo_near2.pov` file with something like this:
    camera{
      location cam_pos+half_interocular*dir_right*(clock*2-1)
      direction
cam_dir-vlength(cam_dir)*dir_right*half_interocular/convergence_dist*(clock*2-1)
      up        cam_up
      right     cam_right
      focal_point fountain_pos
      aperture 10     // twice much blurring
      blur_samples 800      // many samples, high quality image
      variance 0. // 0001 // see pov-ray soc on focal blur
So it means that the focal plane is perpendicular to `direction` and goes
through `focal_point`.
My goal is to find the diameter of the point spread function (also called the
circle of confusion https://en.wikipedia.org/wiki/Circle_of_confusion) with
respect to depth.
Date: 19 Jun 2018 05:12:24
Message: <5b28c8f8$1@news.povray.org>
Am 19.06.2018 um 09:14 schrieb CrisDamian:
>>   up y // default
>>   aperture 0.25
>> blur_samples :
>     camera{
>       direction
>       up        cam_up
>       right     cam_right
> respect to depth.
Near the image center, POV-Ray's focal blur model approaches that of an
idealized thin lens, with an idealized aperture placed right in the lens
plane:
The `location` vector specifies the center of the lens within the scene,
in scene units.
The `direction` vector specifies the direction of the optical axis. Its
length is only relevant with respect to the `up` and `right` vectors,
and only if no `angle` parameter is specified.
The `up` and `right` vectors specify the orientation of the camera
sensor; the ratio of their lengths also specifies the "physical" aspect
ratio.
In the absence of an `angle` parameter, the ratio between the lengths of
the `direction` and `right` vectors also governs the horizontal angle of
view. Presuming orthogonal vectors, the angle is
alpha=2*atan(|right|/|direction|).
The `focal_point` vector's length, in scene units, specifies the
distance along the optical axis at which an object would be in full
focus; the vector's direction is actually ignored.
The `aperture` setting specifies the size of the camera aperture in
scene units.
Further from the image center, POV-Ray's focal blur model becomes
increasingly non-realistic: Rather than a plane of focus, POV-Ray's
focal blur model actually has a sphere of focus, and the aperture is
also modeled to have spherical symmetry.
Date: 19 Jun 2018 05:26:19
Message: <5b28cc3b$1@news.povray.org>
Am 19.06.2018 um 11:12 schrieb clipka:
> scene units.
I'm just realizing that this statement is ambiguous. Strike "size" and
substitute "diameter".
Strike that entire paragraph; I was misinterpreting the source code.
The surface of focus is a plane perpendicular to the `direction` vector,
and the aperture is modeled to be circular, in a plane also
perpendicular to the `direction` vector [for the sake of focal blur;
POV-Ray does not account for the reduction in luminous intensity this
model would normally imply at high angles].
Date: 26 Jun 2018 10:35:01
Message: <web.5b324e4b4ad2391616086ed00@news.povray.org>
> Bill P.
Sorry,
I could not find this in povray.binaries.scenes,
Could anyone explain to me why POV-Ray binary scenes and povray images are
separated in the newsgroups? I feel it makes things so tedious every time! I
thought there were only advantages to have no POV forum and only mail
newsgroups... I probably am using them wrong?
Also to be back on topic, couldn't this 35 mm macro be integrated in the
official list of POV/UberPOV macros if it still works? Thanks for all the
information already brought up so far.
Date: 26 Jun 2018 11:08:09
Message: <5b3256d9$1@news.povray.org>
On 26/06/2018 15:31, Mr wrote:
> Sorry,
I found it. The date it was posted is 16/03/2009
I replied to it to bump the post. I also downloaded the macro if you
can't find it.
Regards
Date: 26 Jun 2018 15:15:01
Message: <web.5b3290164ad23916c437ac910@news.povray.org>
"Mr" <mauriceraybaud [at] hotmail dot fr>> wrote:
> Sorry,
Well, the povray.binaries.scenes (pbs) section is usually for posting the actual
scene file(s) that may be in a binary format, such as a zipped directory
including the .pov text file, mesh include files, image files necessary for
running the scene (image maps, heightfields, etc)
The povray.binaries.images (pbi) section is for posting the actual rendered
images for people to look at, comment on, and enjoy.  Some folks hold the inner
working of their scenes as closely guarded secrets  ;)
Management of things like that is an arduous and largely thankless task.  I'm
sure you could start an indexed repository of macros and other scene code
(hopefully with date or version information :) ) just to see what I mean.
A nice zip file to add to the insert menu would be a beautiful thing as well.
There's just SO MUCH, and it's not used all the time, and even just the stuff
that's IN POV-Ray and documented to the amazing extent that it is, is nearly
impossible to keep track of.
And then there's the time and energy to bring it to fruition...
Just throwing that all out there for your consideration - it's not as trivial as
we all wish it was.
Date: 27 Jun 2018 09:46:19
Message: <5b33952b$1@news.povray.org>
http://news.povray.org/povray.binaries.scene-files/thread/%3C5b325680%241%40news.povray.org%3E/
(Thanks for making the link easier to find Stephen)
I believe it the case that in the olden days of dial-up Internet and
slow data transfers, the separation of uploaded data and discussion made
sense. Why too there is the practice of posting binary images apart from
discussions which might happen in other newsgroups. I agree it's today
cumbersome.
Bill P.
