POV-Ray : Newsgroups : povray.general : printing object's identifier Server Time
25 Feb 2026 08:06:42 EST (-0500)
  printing object's identifier (Message 1 to 10 of 20)
Subject: printing object's identifier
Date: 16 Mar 2016 18:35:38
Message: <56e9dfba$1@news.povray.org>
hi,
I'm trying to print, from a macro, the declared name of an object passed
to it, ie.
#declare Tobj = torus { ... };
object { Tobj }
mymacro(Tobj)
and in the macro (where the parameter is ObjId)
#debug concat("object's name:", ObjId)
that doesn't work, POV complains "expected string, oid found instead",
so is there a way to get the name string ('Tobj') from the ObjId?
thank you.
jr.
Subject: Re: printing object's identifier
Date: 16 Mar 2016 19:50:42
Message: <56e9f152$1@news.povray.org>
Am 16.03.2016 um 23:35 schrieb jr:
> hi,
> to it, ie.
> object { Tobj }
> mymacro(Tobj)
This question has been asked before.
Short answer: It's not possible.
Almost equally short answer: It doesn't make sense. If it would work,
POV-Ray would print "ObjId" instead of "Tobj", because the macro has no
knowledge of any prior name of the object.
What you /could/ do is approach it the other way round, converting a
string to an identifier:
object { Tobj }
mymacro("Tobj")
and in mymacro use the Parse_String macro (from string.inc... or is it
strings.inc? I never can remember) to convert the string to an identifier.
Note however that in this case you must somehow make sure that you don't
pass the name of an identifier that is also declared locally in the macro.
Date: 16 Mar 2016 20:32:03
Message: <56e9fb03$1@news.povray.org>
hi clipka,
On 16/03/2016 23:50, clipka wrote:
thanks for swift response.  this approach led to a different problem
(see below).  the macro is stored in its own file and meant to be
general purpose (to trace the outline of whichever object was passed via
ObjId), and I need both the object's name (for feedback and to populate
a field in the output), and the object to trace.  I'm now thinking,
given the below, it might be easier/better to supply both the name and
the identifier as separate arguments, do you concur?
jr.
object { Tobj }
mymacro("Tobj")
#debug concat("id: ", ObjId)
Parse_String(ObjId)
#local bbox_min = min_extent(ObjId)
POV now fails on the min_extent since I'm passing it a string..
Date: 16 Mar 2016 21:07:48
Message: <56ea0364$1@news.povray.org>
Am 2016-03-16 20:31, also sprach jr:
>I'm now thinking,
That's the way I do it.
C'est la vie.
dik
Date: 16 Mar 2016 21:42:09
Message: <56ea0b71$1@news.povray.org>
Am 17.03.2016 um 01:31 schrieb jr:
> hi clipka,
> jr.
> object { Tobj }
> mymacro("Tobj")
> Parse_String(ObjId)
You need to use
#local bbox_min = min_extent( Parse_String(ObjId) );
But yes, it would probably be easier to have two separate parameters,
one specifying the object and one specifying a string to use as a "name"
for that object.
Date: 17 Mar 2016 09:37:23
Message: <56eab313$1@news.povray.org>
hi,
ok, separate arguments it is.  thank you clipka & Dick B.
On 17/03/2016 01:41, clipka wrote:
> You need to use
thank you for showing the correct use.  fwiw I did grep for this macro
in all 3.7.0 (scene) files, it does not appear used anywhere.
jr.
Date: 17 Mar 2016 10:30:01
Message: <web.56eabebf374275025e7df57c0@news.povray.org>
> jr.
Given just HOW MUCH stuff POV-Ray has jammed into it, that's not entirely
surprising.   Documenting features takes a lot more time and care (for me) than
coding a scene.
Perhaps if you could write up a small, commented SDL file that illustrates and
demonstrates this particular feature, then it would be available to anyone in
the future searching the newsgroups and wanting to know how to go about using
it.
"Many hands make light work", and all that   :)
Glad you're getting it to work out.
Date: 18 Mar 2016 14:01:18
Message: <56ec426e$1@news.povray.org>
hi,
> coding a scene.
> it.
man, talk about bein' put on the spot.  ;-)
I don't mind doing the 'legwork' (though, as a beginner, just how useful
such a sample scene would be is questionable), but have to confess that
I can not think of /any/ realistic use case for Parse_String(); lack of
use case may well be a contributing factor to the macro not being used
in the sample scenes.
I will put a simple, contrived scene file together, give me a few days
please, I'm in the middle of my own stuff right now.
agree.
a fanciful thought on the subject: given the recent revolution in
self-publishing, perhaps, between the povray news group users, a wiki
could be nurtured to the point of producing/selling a print-on-demand
book on using/programming POV?  (I know I'd buy :-))
jr.
Date: 18 Mar 2016 14:20:00
Message: <web.56ec4699374275025e7df57c0@news.povray.org>
:D
 It just needs to be a little working SDL blurb that can be used as or pasted
into a macro.   Though sometimes it can be surprising what some people can do
with a little feature once they start to contemplate what it might be used for.
It was simply a suggestion - please take your time and pardon my shameless and
opportunistic "tagging" of you.  ;)
I hope your project is working out well.  I wish you further luck and success.
Date: 18 Mar 2016 21:38:06
Message: <56ecad7e@news.povray.org>
hi,
>> I will put a simple, contrived scene file together, give me a few days..
I'm sure you know how, (often) immediately writing something like "can
not think of /any/ realistic use case" an idea, from nowhere, lodges
itself in the brain, persistent, like an itch that must be scratched?
anyway, it happened and I had to get it of my system, the resulting file
is attached.
too late!  :-)
the .pov illustrates building object identifiers dynamically via cli.
the file is commented and works with version 3.7.0.  it does lack visual
pizzazz but I'm no artist anyway.  also, the newlines in the error
messages don't work on my machine.
regards, jr.
Download 'utf-8' (2 KB)
