POV-Ray : Newsgroups : povray.general : Binary meshes? Server Time
17 Apr 2026 10:17:46 EDT (-0400)
  Binary meshes? (Message 1 to 10 of 10)
Subject: Binary meshes?
Date: 15 Jun 2015 09:09:37
Message: <557ece91$1@news.povray.org>
Hi(gh)!
Still aiming at POVEarth/POVghanistan (and also high-quality renderings
of other Solar System bodies) - but currently, there is a bottleneck
when it comes to generating "spherical" (i. e. following Earth's
curvature) mesh2s from 16-bit (or whatever format) heightfields!
The Japanese ASTER mission elevation tiles have a resolution of 3601 by
3601 measuring points (i. e. pixels in a heightfield generated from
these data) - but even with 16 GiB of RAM, I had to decrease the
resolution to 2600 by 2600, otherwise POV-Ray would crash.
Of course this is because POV-Ray generates full ASCII code rather than
(like with heightfields) binary data to internally represent the mesh2
object.
Have there ever been any attempts to write a patch to make binary meshes
feasible with POV-Ray?
See you in Khyberspace!
Yadgar
Subject: Re: Binary meshes?
Date: 17 Jun 2015 17:54:24
Message: <5581ec90@news.povray.org>
Le 15-06-15 09:09, Jörg 'Yadgar' Bleimann a écrit :
> Hi(gh)!
> object.
> Yadgar
I'd start with an hight_field, then, start to play with functions and
isosurface.
Take your TIFF image, convert it into an image pattern, then into a
function.
The image's coordinates would become the longitudes and latitudes, to be
adjusted by the base coordinates of the location to be rendered, and the
values of each points would be added to a base radius to give the actual
elevation.
Just don't convert into a mesh.
Date: 18 Jun 2015 21:26:02
Message: <55836faa@news.povray.org>
Hi(gh)!
> isosurface.
> function.
> elevation.
O.k., this would avoid the memory-consuming generation of ASCII script
code - of course at the expense of rendering time. But I never found out
how to constrain such a function to a certain surface area defined by
geographic coordinates rather than just producing a whole "sphere"...
The more sophisticated approach would be hacking the very source code of
POV-Ray, adding an object type "Geo_Mesh", which internally would be
treated just like a heightfield - you would specify an image map (or
even ASCII matrix file) containing the elevation data, then geographic
coordinates for opposite corners, finally the "base radius" of the
sphere to which the elevation values would be added.
Does such a patch for POV-Ray already exist - or would I be the first to
write it?
Yadgar
Date: 19 Jun 2015 10:29:58
Message: <55842766@news.povray.org>
Le 15-06-18 21:26, Jörg 'Yadgar' Bleimann a écrit :
> Hi(gh)!
> write it?
> Yadgar
I'd use a box to contain only the part to be used, dimentiones as small
as possible. If the container is a sphere, then, it should be default to
just a sphere outside the area of interest.
The max_gradient should be relatively low, in the 2.2 range, with a
simple function. This should render reasonably fast. Using evaluate
could make things go slightly faster.
As for the patch, I don't think it exist.
Date: 19 Jun 2015 16:08:34
Message: <558476c2$1@news.povray.org>
Hi(gh)!
You probably misunderstood me - I'm aware of a function which allows
heightfields to be "wrapped" around a sphere as an isosurface (it's even
included in the ready-made script texts with the Windows version of
POV-Ray 3.7!). But this would apply to global heightfields - I instead
thought of heightfields only covering a small tile of the surface, for
example 1 by 1 degree, and they should not globally "wrap", but be
constrained to their geographic coordinates!
Then I probably know what I have to do - perhaps around 2020, there
might be an inofficial 3.7 (or 3.8) patch named "GeoPOV" which
facilitates binary meshes ("Geo_mesh2")... but it would be a long and
arduous task, especially for me who never modified professional C++ code!
Yadgar
Date: 20 Jun 2015 00:53:17
Message: <op.x0iiiuo8ufxv4h@xena>
Are you looking for omething like this?
http://www.imagico.de/
http://earth.imagico.de/gallery-menu.php?lang=en
-Nekar Xenos-
Date: 20 Jun 2015 04:46:24
Message: <55852860$1@news.povray.org>
Hi(gh)!
Yes, but Christoph uses isosurfaces rather than meshes - much too slow
for animations!
Yadgar
Date: 22 Jun 2015 09:20:00
Message: <web.55880ab0dc565de016086ed00@news.povray.org>
=?UTF-8?B?SsO2cmcgJ1lhZGdhcicgQmxlaW1hbm4=?= <yazdegird@gmx.de> wrote:
> Hi(gh)!
> object.
> Yadgar
Maybe adding  support for an existing library like Alembic format would solve
this request and some others?
https://en.wikipedia.org/wiki/Alembic_%28Computer_Graphics%29
or micro poly tesselation and displacement at rendertime, renderman style? Does
Aqsis have it? as an open source example?
I don't know much about all these solutions but I would love to be able to do
exactly the same thing you request.
Date: 22 Jun 2015 12:51:11
Message: <55883cff@news.povray.org>
Am 22.06.2015 um 15:16 schrieb Mr:
Nope. We need to transform it into a POV-Ray specific internal
representation anyway.
I don't think this will fly; there are rendering algorithms where micro
tesselation fits in easily, but raytracing isn't one of them.
Date: 27 Sep 2015 11:57:36
Message: <560811f0$1@news.povray.org>
Very very belated, but I've been doing something similar with my Flooded
Moon project (http://cowlark.com/flooded-moon). I have a bespoke tool
which takes a set of NASA PDS files and generates a mesh centred on the
camera, with the polygon size dropping off in the distance. You may find
it useful.
I'd love such a thing --- particularly if it could be a format which
Povray could use directly without conversion. And then have it loaded
with mmap. Writing out 2GB of ASCII mesh out to disk just so I can load
it straight back in to memory is so *slow*, and all wasted work.
┌─── dg@cowlark.com ─────
http://www.cowlark.com ─────
│ "There is nothing in the world so dangerous --- and I mean *nothing*
│ --- as a children's story that happens to be true." --- Master Li Kao,
│ _The Bridge of Birds_
