POV-Ray : Newsgroups : povray.general : FYI. tiling pattern maps require 7 significant digits. Server Time
17 Apr 2026 12:00:56 EDT (-0400)
  FYI. tiling pattern maps require 7 significant digits. (Message 1 to 5 of 5)
Subject: FYI. tiling pattern maps require 7 significant digits.
Date: 23 Aug 2014 12:51:36
Message: <53f8c698$1@news.povray.org>
I've made a couple previous runs at using the relatively new tiling
patterns finding some things working and others not. Today finally
figured out the tiling pattern requires 7 significant digits in the map
file used with the pattern when into values like 0.316666...
The scenes/textures/patterns/tiling.pov example writes only 4
significant digits & I was using that code to create my maps.
I'd suggest updating the tiling example to write 7 significant digits  &
perhaps a note about this should made in the documentation too. Tiling
23,3 is an example with the issue should folks want to verify.
Not really sure why more accuracy is required. It only affects parts of
some tiles within any given tiling pattern with the issue.
Bill P.
Subject: Re: FYI. tiling pattern maps require 7 significant digits.
Date: 23 Aug 2014 12:59:19
Message: <53f8c867@news.povray.org>
> Bill P.
You should use fraction, it is simpler and not limited in precision
(well, let povray handles that point).
Tiling 23 is using 3 tiles, how do you split 1.0 in 3 parts of same
size, when the underluying arithmetic is bound to binary representation ?
Now, maybe an update of the scenes/textures/patterns/tiling.pov example ?
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 23 Aug 2014 15:09:29
Message: <53f8e6e9@news.povray.org>
Agree, all good points. I admit to just using the tiling.pov's WriteMap
feature to get the maps in large part because I didn't understand how
the tiling pattern worked.
... I used this feature of the example
// change to yes to write the color_map to a text file
#declare WriteMap = no;
The quick fix to tiling.pov for the WriteMap feature above is just :
71,72c71,72
<             #write (MapFile, "    [", str(V2/TileTypes,5,4)," rgb <",
vstr(3, ThisColor,", ", 0,4),">]\n")
<             #write (MapFile, "    [", str((V2+incre)/TileTypes,5,4),"
rgb <", vstr(3, ThisColor,", ", 0,4),">]\n")
 >             #write (MapFile, "    [", str(V2/TileTypes,5,7)," rgb <",
 >             #write (MapFile, "    [", str((V2+incre)/TileTypes,5,7),"
Even getting the color tiles I expect, I still don't understand
everything about this tiling pattern. I didn't expect the pattern to
plateau (or perhaps it peaks and recedes) inside the tiles? Rather I
thought there would be a continued gradient to the center making
impossible the sensitivity to mathematical noise in the map we see.
I'll see if tomorrow I can find some time to update so a fractional
representation map is written to the WriteMap file instead of the fix
above. Perhaps too adjusting the break points slightly more away from
the apparent calk/tile edges of the pattern if I can get a better
understanding of the gradients. Guess I can plot the whole thing as one
gradient to better see what it is really doing in the tiles.
Bill P.
Date: 23 Aug 2014 16:47:07
Message: <53f8fdcb$1@news.povray.org>
the smallest tile (such as in 23) provide the limit for the size of the
calk of all tiles. The inner part, deeper, of other tiles are getting
uniform entry. At best, the smallest one becomes 100% calk, but a part
of the other ones remains (unless they have the same depth).
The calk is parallel to the side of the tile, and it appeared on the
part of the map (so you can have a banded calk around a tile).
> Bill P.
Date: 24 Aug 2014 13:15:41
Message: <53fa1dbd$1@news.povray.org>
Thank you for the explanation and hint about banded calk being possible.
I now have a much better understanding our tiling pattern.
As for a more complete update of the tiling.pov example code, I believe
changing the following two lines from :
#write (MapFile, "    [",str(V2/TileTypes,5,4)," rgb <", vstr(3,
#write (MapFile, "    [",str((V2+incre)/TileTypes,5,4)," rgb <", vstr(3,
to :
#write (MapFile, "    [(",str(V2,0,3),"/",str(TileTypes,0,0),") rgb <",
#write (MapFile, "
[(",str(V2,0,3),"+",str(incre,0,3),")/",str(TileTypes,0,0)," rgb <",
implements the fractional map indexes you suggested.
Bill P.
