POV-Ray : Newsgroups : povray.general : V 3.7 Timeout problem Server Time
15 Jan 2026 00:59:18 EST (-0500)
  V 3.7 Timeout problem (Message 1 to 10 of 10)
Subject: V 3.7 Timeout problem
Date: 20 Jan 2014 02:39:31
Message: <52dcd2b3$1@news.povray.org>
I had a render running that's pretty big (20GB mem use)
and it fails with a "Operation timed out" problem.
This shows up when the first frame is finished and it starts on the second frame
Render Time:
  Photon Time:      No photons
  Radiosity Time:   No radiosity
  Trace Time:       0 hours  9 minutes 25 seconds (565.473 seconds)
              using 8 thread(s) with 4145.640 CPU-seconds total
Rendering frame 11 of 3951
Operation timed out.
Render failed
My guess is that pov times out waiting for the swap somehow.
I found the error text in pov_err.cpp (obviously), but can't find where it's
initiated.
Running Povray 3.7 with the -CC switch on Opensuse 13.1 on a 16GB 8-core
Btw, I've had renders of similar size, and larger, running under Povray 3.6 And even
though they chewed the heck outta the swap drive, they never timed out.
Ger
Subject: Re: V 3.7 Timeout problem
Date: 20 Jan 2014 13:20:01
Message: <web.52dd67fa5143bb5ec275d1490@news.povray.org>
> Render Time:
> Render failed
initiated.
If swapping takes way too long, the program may end up being waiting several
seconds. There are timeouts for the internal message passing that are designed
to catch situations when the receiving thread hangs. They are 10 seconds in wall
clock  time iirc. Try building with -DkDefaultTimeout=30 and see if it helps.
Thorsten
Date: 20 Jan 2014 16:30:27
Message: <52dd9573$1@news.povray.org>
> several seconds. There are timeouts for the internal message passing that
> are designed to catch situations when the receiving thread hangs. They are
> 10 seconds in wall
> helps.
Tried with 30, raised it to 300 and it still fails. But the messages come well before
the 300 seconds are over.
Also, I kept an eye on memory usage, specially at the end of the render, and the usage
never drops until it fails.
I'll build it with some crazy value and see what happens, but it may take a while
before that one finishes. :)
Ger
Date: 20 Jan 2014 16:41:37
Message: <52dd9811@news.povray.org>
Am 20.01.2014 08:39, schrieb Ger:
Bad idea (thought not nearly as bad as on a Windows machine).
> And even though they chewed the heck outta the swap drive, they never timed out.
As speed doesn't seem to be a matter for you, trying to lower the number
of competing threads using +WT4 or some such could be worth trying. With
the swap drive surely being the bottleneck, you might even consider
+WT1, reducing page thrashing to the absolute minimum possible in this
setup.
Note that the more worker threads you have, the less coherent
consecutive memory accesses will be.
Date: 20 Jan 2014 16:53:16
Message: <52dd9acc$1@news.povray.org>
>> 3.6 And even though they chewed the heck outta the swap drive, they never
>> timed out.
> setup.
Sounds logical. I'll give the +WT1 option a go and see what happens
As a side note, when the actual render starts it never drops below 95% CPU usage until
it finishes.
Ger
Date: 20 Jan 2014 18:30:22
Message: <52ddb18e$1@news.povray.org>
>>> never timed out.
>> setup.
> usage until it finishes.
No such luck
Render Time:
  Trace Time:       1 hours  5 minutes  6 seconds (3906.412 seconds)
              using 1 thread(s) with 3833.698 CPU-seconds total
Rendering frame 11 of 4091
Render failed
Ger
Date: 23 Jan 2014 16:47:42
Message: <52e18dfe$1@news.povray.org>
I have cut the render back to where it's just touching swap for about 100-200MB
This is what I get now
Finite Objects:     12040971
Infinite Objects:       1178
Light Sources:             4
Total:              12042153
Parser Time
  Parse Time:       0 hours  4 minutes 51 seconds (291.274 seconds)
              using 1 thread(s) with 178.430 CPU-seconds total
  Bounding Time:    0 hours  5 minutes  0 seconds (300.321 seconds)
              using 1 thread(s) with 143.572 CPU-seconds total
Render Time:
  Trace Time:       0 hours 10 minutes 22 seconds (622.810 seconds)
              using 8 thread(s) with 4904.880 CPU-seconds total
Rendering frame 11 of 4311
Parser Time
  Parse Time:       0 hours 12 minutes 19 seconds (739.418 seconds)
              using 1 thread(s) with 290.039 CPU-seconds total
  Bounding Time:    0 hours  6 minutes 45 seconds (405.536 seconds)
              using 1 thread(s) with 161.738 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.010, Depth 3, Jitter 1.00,
 Gamma 2.50)
Render Time:
  Trace Time:       0 hours 10 minutes 41 seconds (641.523 seconds)
              using 8 thread(s) with 4960.879 CPU-seconds total
Rendering frame 21 of 4311
Render failed
Only change between frames is the camera position
Ger
Date: 23 Jan 2014 22:31:11
Message: <52e1de7f@news.povray.org>
Am 23.01.2014 22:47, schrieb Ger:
> Parser Time
> Parser Time
Note how the scene already takes significantly longer to parse, which
should normally not happen if all that's changed is the camera position;
this shows how I/O performance is already degrading.
Which reminds me that there still /is/ something worth trying: One thing
that competes with swapping for I/O bandwidth is the writing of the pov
state file, which is essentially a log of rendering progress that would
be used if you abort a render and continue it later using the +C option.
The newest development version of POV-Ray 3.7 has an option to disable
creation of that file ("-CC"), which would leave more I/O bandwidth for
swapping.
Currently there is no Windows build of that version, but the newest
UberPOV beta (1.37.0.0-beta.4) also has it.
Date: 23 Jan 2014 22:45:18
Message: <52e1e1ce$1@news.povray.org>
> swapping.
LOL
Guess who asked for that option :)
Ger
Date: 23 Jan 2014 23:24:13
Message: <52e1eaed@news.povray.org>
Am 24.01.2014 04:45, schrieb Ger:
>> swapping.
> LOL
I don't remember, um... (mumbles)...
... never mind >_<
