POV-Ray : Newsgroups : povray.general : Does PoV-Ray 3.6 support multi-core processors? Server Time
28 Jan 2026 01:00:58 EST (-0500)
  Does PoV-Ray 3.6 support multi-core processors? (Message 1 to 8 of 8)
Subject: Does PoV-Ray 3.6 support multi-core processors?
Date: 26 Aug 2011 19:53:06
Message: <4e5831e2$1@news.povray.org>
High!
As for raytracing computers NEVER are fast enough, I currently toy with
the idea of upgrading my prehistoric rattletrap (AMD Athlon 64 3500+) to
a multicore system, preferably with an AMD Phenom II X6, i. e. a
hexa-core CPU.
But obviously not all software supports using all cores - does PoV-Ray
3.6 (I would not use 3.7 unless its final version is released, a friend
experienced a bad crash with the current beta)? Are there differences
between the Windows and Linux versions (I use Linux)?
See you in Khyberspace - www.khyberspace.de
Yadgar
Subject: Re: Does PoV-Ray 3.6 support multi-core processors?
Date: 26 Aug 2011 20:24:48
Message: <4e583950@news.povray.org>
> High!
> hexa-core CPU.
> Yadgar
Version 3.6.1 don't support multiple cores. To use multiple cores, you
need yo launch multiple instances and do partial renders that you stitch
toggether afterward. In a radiosity scene, it will cause discontinuities
when the various sub-renders meet.
It means that any scene will be loaded multiple times and redundently
use your memory, possibly forcing additional swap file access.
Version 3.7 is in release candidate stage. It's very stable and will use
all available cores.
Some advantages of 3.7 over 3.6.1:
Multi processor/core support. One instance will use all cores/processors
installed.
MUCH beter radiosity code and many radiosity bugs eradicated.
Beter antialiasing and the ability of using antialiasing and focal blur
at the same time.
Beter and faster focal blur support with optional bokeh mask.
Native support for high dynamic range both as imput for image_map and as
an output file format.
Extremely beter resume capability: No artefacts when resuming a
radiosity scene.
I realy think that you should completely skip the very aging version
3.6.1 and jump straight to version 3.7 RC3.
Date: 26 Aug 2011 20:30:01
Message: <web.4e58399ac63734ce379c87210@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> hexa-core CPU.
> Yadgar
the intel i7-995x is the top processor on the passmark list.
http://www.cpubenchmark.net/high_end_cpus.html
windows will think it has 12 cores if I am not mistaken (I have a hyperthreaded
pentium 4 and it is a 1 core with 2 threads, thinks it's a 2-proc box).  you
will want megapov since I hear that's the only one that supports
multithreading/multicores.
Date: 27 Aug 2011 01:33:43
Message: <4e5881b7@news.povray.org>
> High!
> As for raytracing computers NEVER are fast enough, I currently toy with the
> idea of upgrading my prehistoric rattletrap (AMD Athlon 64 3500+) to a
> multicore system, preferably with an AMD Phenom II X6, i. e. a hexa-core CPU.
> But obviously not all software supports using all cores - does PoV-Ray 3.6
You should go with POV-Ray 3.7 nonetheless. If your friend experienced "a
bad crash", I assume his system crashed while he was using POV-Ray. This is
indeed possible if his system is not cooled according to CPU vendor
specifications as POV-Ray 3.7 will use all cores and is ideally suited to
bring your systems to its thermal limits. POV-Ray, just like any other
application that would use all available processing capabilities can also
cause instability of a poorly cooled system, but in the end that is a
hardware problem, not a software problem.
	Thorsten
Date: 27 Aug 2011 01:52:45
Message: <4e58862d$1@news.povray.org>
That is complete nonsense. You cannot have heard this anywhere, as nobody
who has just a bit of clue would say so. The only version available that
supports multicore processors is POV-Ray 3.7, which is currently a fairly
stable release candidate version and available from povray.org for download.
	Thorsten, POV-Team
Date: 27 Aug 2011 03:08:40
Message: <4e5897f8$1@news.povray.org>
> High!
> hexa-core CPU.
No need to be afraid of a software induced crash. Version 3.7 has been
very stable for a long while now. I never had a crash, even with my old
dual core. I have upgraded recently to an Intel i7 machine and POV uses
8 threads, which is a fantastic gain of render time for me after *just*
two threads before (which was already a nice gain of render time
compared to the single thread of version 3.6 and my even older
machines... ;-)  ).
Date: 27 Aug 2011 07:03:53
Message: <4e58cf19@news.povray.org>
High!
On 27.08.2011 07:52, Thorsten Froehlich wrote:
> The only version
> available that supports multicore processors is POV-Ray 3.7, which is
> currently a fairly stable release candidate version and available from
But I will have to compile it on my own for Debian Linux?
See you in Khyberspace!
Yadgar
Date: 27 Aug 2011 11:35:00
Message: <web.4e590d90c63734ce3b47249a0@news.povray.org>
> High!
> > The only version
> Yadgar
You should always be compiling your own binaries under Debian (or any other
unix-like system). The official binaries run, but tend to be suboptimal on
current processors.
