POV-Ray : Newsgroups : povray.general : "Smoothing" a mesh2 object Server Time
30 Jul 2024 06:31:07 EDT (-0400)
  "Smoothing" a mesh2 object (Message 1 to 7 of 7)
Subject: "Smoothing" a mesh2 object
Date: 25 Sep 2009 13:30:01
Message: <web.4abcfd29b8262dab182abe670@news.povray.org>
I am using a height_field to generate an island out in the water.  The
facets just blend away.  I was also using a height_field for the ocean generated
Unfortunately, for other reasons, I converted the ocean to use a mesh2 object.
Is there some way of smoothing the facets of a mesh2 object without having to
calculate all the normals of each facet and then averaging them at each point?
Obviously there is code in POVRay already since its used for smoothing the
height_field.  Is there some other way to apply it to the mesh2 object?
Thanks
Subject: Re: "Smoothing" a mesh2 object
Date: 25 Sep 2009 17:30:01
Message: <web.4abd363ecd70e16b96d7ef40@news.povray.org>
> Thanks
I don't know if this is of any help in your case, but to smooth any mesh objects
I always use the freeware program poseray http://mysite.verizon.net/sfg0000/ and
then import the generated include file to POV-Ray. Huge files, but very good
results.
Date: 2 Oct 2009 14:30:00
Message: <web.4ac64668cd70e16182abe670@news.povray.org>
> results.
I was hoping for something either built into POVRay or a script to handle it.  I
need it to be a more automated process.  Unfortunately, I'm doing this for a
video and the current (un smoothed) mesh is calculated for every frame for
multiple "wave trains" from multiple directions.  So generating the mesh and
then exporting the data to be process and then reloaded would make a month long
rendering into a year long rendering.
But thanks... at least it confirms that it wasn't built in and I was just
overlooking something obvious.  I guess, I'll just have to do the vector math in
the script from scratch.  Just a little disappointing that POV-Ray does it...
just not exposing it on Mesh or Mesh2 as an option.
Date: 3 Oct 2009 04:50:00
Message: <web.4ac70f71cd70e167f60427b0@news.povray.org>
> > results.
There is the subdivision patch of POV 3.6 here:
http://www.cise.ufl.edu/~xwu/Pov-Sub/
I've used it quite a bit with Wings3D models, and it works well, and quickly
too.
> I need it to be a more automated process.  Unfortunately, I'm doing this for a
Wait... wouldn't pre-generating it (externally), then loading it be faster?  If
you are calculating it directly in POV using functions and macros, native code
would likely be *many* times faster.
If the functions are in POV, can this be done using the isosurface object?  With
the correct bounding shape, isosurfaces with smallish gradients render pretty
quickly.
-Reactor
Date: 3 Oct 2009 11:53:32
Message: <4ac7737c$1@news.povray.org>
POV-Ray does it for /height fields/, but those are totally different
animals. Normal computations for height fields are not performed in the
"mesh domain" (in fact height fields are not even represented as meshes
internally), but in the "image domain" (based on the value differences
between adjacent pixels), which obviously is impossible to apply to meshes.
Date: 4 Oct 2009 04:22:02
Message: <4ac85b2a$1@news.povray.org>
Le 02/10/2009 20:28, Inquisitor nous fit lire :
If you are open to patch, have a look
at http://jgrimbert.free.fr/pov/patch/tessel/index.html
especially the smooth object.
Date: 9 Nov 2009 23:48:26
Message: <4af8f09a$1@news.povray.org>
I see that you've already found responses here, but I recently had a
similar problem with a .pov exporter from Milkshape3D incorrectly
handling smoothing of the mesh object. It would generate a single normal
vector for each triangle instead of per vertex, which then wouldn't
smooth anything in pov. For this problem I was able to write a .php
script that reads the .pov file (or any string passed to the function,
doing smaller groups at a time increases total speed) and will modify
(average) the normal vectors for shared vertices to correctly smooth the
object.
I set it up to smooth anything within a maximum specified angle (usually
set to 90 degrees or so), and it can handle multiple sets of locally
smooth points that are at the same location (where sharp edges are
intended). If your pov file is set up this way, where the mesh is
defined as lots of smooth_triangle{} patches, I'd be happy to share this
script. If it is set up as a group of triangle{} patches, then I think
it would be possible to generate a normal vector and do the same thing,
possibly in two passes though (assuming the triangles have vertices
specified in a counterclockwise direction).
Another note is that the way I set this up requires that each vector for
the triangle vertices needs to be identical (same string representation,
not just numerically equivalent), but again with more work that could be
fixed.
Feel free to send me an email at this address if you would like this
script (that goes for anyone), I'm not posting it just now to the
newsgroups because it's a bit of a hack and isn't pretty or optimized yet.
CShake
