POV-Ray : Newsgroups : povray.general : Granite with limits? Server Time
11 Apr 2026 12:49:50 EDT (-0400)
  Granite with limits? (Message 1 to 10 of 10)
Subject: Granite with limits?
Date: 10 Sep 2009 04:31:05
Message: <4aa8b949$1@news.povray.org>
Is there a way to create a granite-like pigment that is limited to
certain limits? I would like no new "cells" to be created if they will
extend beyond the limits. Sorry if I didn't explain this well enough...
-Mike
Subject: Re: Granite with limits?
Date: 10 Sep 2009 06:06:49
Message: <4aa8cfb9@news.povray.org>
"SharkD" <mik### [at] gmailcom> wrote in message
news:4aa8b949$1@news.povray.org...
> Is there a way to create a granite-like pigment that is limited to certain
> limits? I would like no new "cells" to be created if they will extend
I think you should be able to achieve this using either layered textures or
texture_map transitions. The optimum approach depends on exactly the result
you're trying to achieve.
If you want a plain texture with a granite-like pigment appearing within a
certain zone you can use a multi-layered texture where the top layer
contains a transparent 'hole' of the desired shape that lets the required
parts of the granite layer beneath show through. You can readily create
well-defined edges of any shape you want using the object pigment.
If you want fuzzy/blurred edges you would probably need to use pigments that
support color_map transitions, such as gradient or onion, but you can use
multiple layers to create some reasonably sophisticated 'holes'. For example
you could use 4 copies of a gradient texture rotated through 90 degrees each
time to create a blurry-edged square hole.
If you want a granite-like texture within the required limits and everything
to be totally transparent beyond those limits, you can use a pigment_map or
a texture_map to transition between the granite texture and a totally
transparent texture.
OTOH The bit of the question about new "cells" not being created implies you
might wish to avoid chopping through discrete splodges of texture in the
granite pattern. For example, cutting around the bright areas and avoiding
cutting through any dark patches. I can't think of an easy way of doing that
using only POV-Ray, although it's conceivable you could use the eval_pigment
function to chart a route through the bright bits without venturing into the
dark bits. You could then build a prism object to follow that route and use
it as an object pigment to create a top layer with a transparent hole of the
required shape. Lots of work though!
Chris B.
Date: 10 Sep 2009 12:35:40
Message: <4aa92adc@news.povray.org>
> you might wish to avoid chopping through discrete splodges of texture in
> the granite pattern. For example, cutting around the bright areas and
> avoiding cutting through any dark patches. I can't think of an easy way
> of doing that using only POV-Ray, although it's conceivable you could
> use the eval_pigment function to chart a route through the bright bits
> without venturing into the dark bits. You could then build a prism
> object to follow that route and use it as an object pigment to create a
> top layer with a transparent hole of the required shape. Lots of work
> though!
> Regards,
> Chris B.
I was thinking of maybe applying black hole warps and turbulence to a
more simple and plain pattern. I know I can control the placement of the
black holes, and the turbulence should help it look more grainy.
-Mike
Date: 10 Sep 2009 15:05:30
Message: <4aa94dfa$1@news.povray.org>
news:4aa92adc@news.povray.org...
> I was thinking of maybe applying black hole warps and turbulence to a more
> simple and plain pattern. I know I can control the placement of the black
Interesting idea. I've played around a little with black hole warps in the
past and you can get some interesting effects. I've put together a minimal
test scene along the lines of what I think you might be getting at:
camera {location <1.5, 1.5,-3> look_at 0}
light_source {<1,50,-100> color rgb 1}
box {<-1,-1,-0.01>,<1,1,2>
  pigment {gradient z
    pigment_map {
      [0   granite scale 0.1]
      [0.5 granite scale 0.1]
      [0.5 gradient z]
      [1   gradient z]
    turbulence 0.01
    warp {black_hole <0,0,-0.1>,1}
This pigment_map creates layers of different pigments in the z-direction
with a granite layer that starts a short distance back from the front
surface of the box (you can see this transition along the top and side of
the box). The warp pulls a circle of the granite pigment towards the surface
sufficiently for it to break through the plain white part of the pigment.
The small amount of turbulence creates a jagged edge to the circle.
Chris B.
Date: 10 Sep 2009 15:30:01
Message: <web.4aa9531890b339e233c8dce40@news.povray.org>
> -Mike
I think Rune made something that could do that, see here:
http://runevision.com/3d/povgoodies/#216
It basically generates a bunch of map entries, allowing you to control how the
pattern behaves.  Adapted for your purpose, it would make each cell larger and
larger until they blend together into one solid color.
-Reactor
Date: 10 Sep 2009 17:57:29
Message: <4aa97649$1@news.povray.org>
> or texture_map transitions. The optimum approach depends on exactly the
> result you're trying to achieve.
> a certain zone you can use a multi-layered texture where the top layer
> required parts of the granite layer beneath show through. You can
> readily create well-defined edges of any shape you want using the object
> pigment.
> that support color_map transitions, such as gradient or onion, but you
> can use multiple layers to create some reasonably sophisticated 'holes'.
> For example you could use 4 copies of a gradient texture rotated through
> 90 degrees each time to create a blurry-edged square hole.
> everything to be totally transparent beyond those limits, you can use a
> pigment_map or a texture_map to transition between the granite texture
> and a totally transparent texture.
> though!
> Regards,
> Chris B.
If you want a single square hole, you can use the boxed pattern.
pigment{boxed color_map{[0.0 rgb 1][0.01 granite]}}
Will give you a square area with a granite pigment, and the rest been
white. There is a narrow transition. Set both to 0.0 to get no transition.
pigment{boxed color_map{[0.0 rgb 1][0.3 granite]}}
Same, but with a mush broader transotion.
If you want a circular hole, replace the boxed by spherical.
A stripe can be obtained with the planar or cylindrical patterns.
Date: 10 Sep 2009 18:11:45
Message: <4aa979a1@news.povray.org>
  I think you mean pigment_map?
Date: 10 Sep 2009 18:58:16
Message: <4aa98488$1@news.povray.org>
Oups! Yes.
Date: 10 Sep 2009 20:21:55
Message: <4aa99823$1@news.povray.org>
> of the box). The warp pulls a circle of the granite pigment towards the
> surface sufficiently for it to break through the plain white part of the
> pigment. The small amount of turbulence creates a jagged edge to the
> circle.
I plan on using the pigment as a density map to create clouds, so I
don't think this method would work correctly.
In fact, I would like the black hole warps to create something out of
nothing. I.e. the basic pigment would be black everywhere except where
the black hole warps are. I tried to do this with a planar pattern, but
it required that a thin strip of white appear in the middle. *Maybe* the
warps affected it enough for gaps to appear in the strip.
-Mike
Date: 12 Sep 2009 03:00:15
Message: <4aab46ff$1@news.povray.org>
news:4aa99823$1@news.povray.org...
> I would like the black hole warps to create something out of nothing. I.e.
> the basic pigment would be black everywhere except where the black hole
> warps are. I tried to do this with a planar pattern, but it required that
I don't think that any of the warps can create something out of nothing,
they really just push and pull pigment around in 3D space or wrap pigments
around on themselves. There's no sort of hyperspace, or 4th dimension that
they can pull color from if they're not present to start with.
You may be right. I haven't done that sort of thing. It might be worth
starting a new thread mentioning interior or media in the title in case
those versed in the dark arts of density maps are no longer following this
thread :o)
Chris B
