POV-Ray : Newsgroups : povray.general : Glows show through objects? Server Time
11 Jan 2026 16:58:40 EST (-0500)
  Glows show through objects? (Message 1 to 10 of 11)
Subject: Glows show through objects?
Date: 25 Jan 2009 10:55:51
Message: <497c8b87@news.povray.org>
Hey,
Been bout a year since I've been around here, so, I hope everyone is doing
well.
I was dicking around the other day and noticed that glows seem to show
through objects in MP1.21...or that I've done something wrong.
Image posted in p.b.i and scene file in p.t.s-f
Its no big deal or anything, just dicking around with making a fake
christmas tree macro, with some creative license. :-p
tia,
ian
Subject: Re: Glows show through objects?
Date: 25 Jan 2009 11:45:01
Message: <web.497c96aca7c344784f183f000@news.povray.org>
"[GDS|Entropy]" <gds### [at] hotmailcom> wrote:
> Hey,
> well.
I seem to remember the same problem.  I would use the trace function to fix the
problem.  Shoot a ray from the camera toward the object.  Call the glow point
'pt,' the camera point 'cam,' and the point you get shooting a ray from cam
toward pt, 'tr.'  Then if the ray doesn't hit the object at all, or if
vlength(pt-cam) < vlength(tr-cam), draw the glow.  In other words, if the ray
hits the object before it reaches the potential glow, don't draw it.
But there may be a simpler way...
 - Ricky
Date: 25 Jan 2009 11:56:27
Message: <497c99bb$1@news.povray.org>
o_O'
I haven't the foggiest as to how to implement that...though it sounds
logical and seems like it would work.
I've never used the trace function, or vlength...you wouldn't happen to have
a link to an example would you?
This seems like one of those bugs that shouldn't have made it to the final
version, doesn't it?    >_<
tia,
ian
"triple_r" <nomail@nomail> wrote in message
news:web.497c96aca7c344784f183f000@news.povray.org...
>> Hey,
>> doing
>> well.
> fix the
> point
> cam
> ray
> - Ricky
Date: 25 Jan 2009 12:15:00
Message: <web.497c9ddea7c344784f183f000@news.povray.org>
> o_O'
It's all there:
http://www.povray.org/documentation/
http://www.povray.org/documentation/view/3.6.1/229/
 - Ricky
Date: 25 Jan 2009 14:12:18
Message: <497cb992$1@news.povray.org>
Hmm...
Ok, that is quite informative, though I haven't a comprehensive enough
understanding of SDL to make the connection between that and blocking
irrational rays from being traced (heretofore a territory I havent even
imagined).
You said you had this issue previously, do you have the source that includes
a similar solution?
I learn best from examples vs. documentation.
tia
ian
news:web.497c9ddea7c344784f183f000@news.povray.org...
>> o_O'
> It's all there:
> - Ricky
Date: 26 Jan 2009 03:39:23
Message: <497d76bb$1@news.povray.org>
"triple_r" <nomail@nomail> schreef in bericht
> fix the
> point
> cam
> ray
I thought I remembered that you could set the glow to be hidden by an object
or not, but after a rapid test, that proved wrong. However, I seem to
remember now (there I go again) that in the NKFlare lens flare macros the
flares can indeed be hidden. You have to choose a flare that approximates
most the megapov glow.
NKFlare can be found at: http://www.nathan.kopp.com/nkflare.htm
See also Chris Colefax's lens effects:
http://www.geocities.com/SiliconValley/Lakes/1434/lenseffects.html but I
seem to remember (again!) that those suffered from the same thing. I may be
wrong, though.
Date: 26 Jan 2009 14:00:01
Message: <web.497e0741a7c34478ef2b9ba40@news.povray.org>
Here's an example.  It should be pretty self-explanatory.  Six glows are drawn,
one on each face of a cube, and three are blocked.
 - Ricky
#version unofficial megapov 1.21;
#declare s = seed(123501);
// MACRO
/* Test whether a ray starting at start_pt and
 * ending at target_pt hits test_obj before it
 * gets there.  Returns either true if it reaches
 * it or false otherwise.  Add an extra epsilon
 * so that conindident points ARE drawn. */
#macro test_ray( start_pt, target_pt, test_obj )
    #local epsilon = 1.0e-10;
    #local nrml = <0,0,0>;
    #local direc = target_pt - start_pt;
    #local intersec = trace( test_obj, start_pt, direc, nrml );
    !(vlength(nrml) > 0 & vlength(direc) > vlength(intersec-start_pt)+epsilon)
// SCENE
// Light/camera
light_source{ <15,25,-20> rgb 0.2 }
#declare cam_pt = <2.5,3.0,-3.5>;
camera{
    location cam_pt
    look_at 0
#macro draw_glow( pt, cam_pt, test_obj )
    #if(test_ray(cam_pt, pt, test_obj))
        glow{
            type 0
            location pt
            size 0.05
            radius 1.0
            fade_power 2
            color rgb vnormalize(<rand(s),rand(s),rand(s)>)
// Draw the objects
#declare thing = box{-1,1}
draw_glow(  x, cam_pt, thing )
draw_glow( -x, cam_pt, thing )
draw_glow(  y, cam_pt, thing )
draw_glow( -y, cam_pt, thing )
draw_glow(  z, cam_pt, thing )
draw_glow( -z, cam_pt, thing )
object{ thing pigment{rgb 1} }
Date: 26 Jan 2009 16:09:54
Message: <497e26a2$1@news.povray.org>
Thank you!
That does illustrate the concept quite effectively.
Now my only task is to make that idea work with objects which are unioned
with glows in one loop and then translated via a second loop to different
positions.
:-D
Ian
news:web.497e0741a7c34478ef2b9ba40@news.povray.org...
>> have
> drawn,
> - Ricky
> // MACRO
> #end
> // SCENE
> // Light/camera
> camera{
>    location cam_pt
>    look_at 0
>        glow{
>            type 0
>            location pt
>            size 0.05
>            radius 1.0
>            fade_power 2
>    #end
> #end
> // Draw the objects
Date: 26 Jan 2009 19:20:00
Message: <web.497e527da7c34478ef2b9ba40@news.povray.org>
> Thank you!
> positions.
Instead, I would use vtransform() or something to build an array of the point
coordinates as you build an object *without* glows.  Then go back when the full
object has been built, and just use that in place of the box in my example,
applying it to each glow location.  Whatever you do, don't attempt to use the
macro on each individual piece!
 - Ricky
Date: 30 Jan 2009 14:32:33
Message: <498355d1@news.povray.org>
Ok...I know I'm going to look like a bumbling idiot once I see the answer
(which is probably right in front of me) to this, but I have been trying
unsuccessfully for the last few days to integrate your example into this
relatively simple file, which I have attached, minus my (most probably
idiotic) attempts to rectify this issue. *slams head against brick wall*
There are definite disadvantages to working 3rd shift and going to college
in the day...it fries your brain, making otherwise trivial tasks impossible.
Nomatter where in my file I try to integrate those macros, or what object or
variable I attach them to, the result is the same...that being no difference
vs. what is obtained without said mods.
Is my problem that I need to construct my object within one loop instead of
two, and then to allocate generated vectors to an array contained within
said loop? I'm fxxin lost at this point. *prays for sleep*
TIA for any elucidation, disobfuscation, or even a swift kick in the ass.
:-D
ian
news:web.497e527da7c34478ef2b9ba40@news.povray.org...
>> Thank you!
>> positions.
> point
> full
> example,
> the
> - Ricky
Download 'blueStalk5.pov.txt' (6 KB)
