POV-Ray : Newsgroups : povray.general : Animating characters? Server Time
20 Nov 2025 13:27:50 EST (-0500)
  Animating characters? (Message 1 to 10 of 13)
Subject: Animating characters?
Date: 26 Aug 2008 00:37:13
Message: <48b38879$1@news.povray.org>
So I know that for still images, I can export from Poser (or, in my
case, Daz Studio).  However, what if I want to do animations?  What are
the best tools for this?
I'm guessing that most people who animate characters don't use POV, but
I'm not most people :)
...Chambers
Subject: Re: Animating characters?
Date: 26 Aug 2008 04:55:00
Message: <web.48b3c4b53f3b0d77be7bfb550@news.povray.org>
> ...Chambers
I think my answer wont help. Trying to do the same I started learning Blender (
http://www.blender.org/ ) about 4 months ago. The good thing of Blender is that
if you want, you can use Pov as render engine. If your animation is not very
complex you can use Moray as well ( http://www.stmuc.com/moray/ )
www.enriquesahagun.es
Date: 26 Aug 2008 05:07:47
Message: <48b3c7e3@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:48b38879$1@news.povray.org...
> So I know that for still images, I can export from Poser (or, in my case,
> Daz Studio).  However, what if I want to do animations?  What are the best
> tools for this?
> ...Chambers
Hi Ben,
You may want to add a few more words about what you're trying to achieve.
Animating good looking human figures with hair, clothes etc. in POV-Ray is
still tricky, but if you're only after little robots or toon characters it
can be a lot easier.
I think you're right that most people don't animate human characters
directly in POV-Ray. I wrote a set of macros (see
http://www.geocities.com/povperson/), but they are cumbersome to use (I
don't think anyone else has ever mastered using them). Others have also done
stuff of their own (see
http://www.youtube.com/watch?v=1TvoYMHyCV0&feature=user) but I don't recall
seeing the code for that published at all. Rune has published a little
walking macro and Teresa Willis did WilBot and son of Wilbot back in 1997
(see http://www.jbarchuk.com/twillis/) which implements a walking macro.
Otherwise there's an old Blobman macro for POV-Ray 3.1 that I think someone
used to construct an animation recently, but it's ugly.
I think the best human animations I've seen done in POV-Ray to date were
done frame by frame by exporting a large number of poses from Poser or Daz
(or from some other modeller for toon-style or robot-style characters). Mike
Williams wrote a Poser to POV tutorial at
http://www.econym.demon.co.uk/posetut/index.htm back in 2003. Someone did a
very nice animation of a lady walking in a circle a long time ago using this
sort of technique, but I can't find that right now. This approach can also
be very cumbersome.
Recently I've been looking at MakeHuman which seems to me to have the most
future potential. It's an Open Source human modeller with a Python API that
I'm currently helping to document. Once I've done that, I'm interested in
exploring the possibilities of developing an API to generate POV-Ray meshes
and poses directly (still early days).
Chris B.
Date: 26 Aug 2008 07:23:31
Message: <ldiClMB$V+sIFw+F@econym.demon.co.uk>
To get fairly realistic looking animations of realistic looking Poser
figures you can perform the animations in Poser, either by interpolating
between a series of Poser poses, or using a built-in animated pose, or
by using a motion capture file.
To render them in POV you have to export the mesh of each individual
frame, because the exported information doesn't contain anything that
could be used in POV to work out how the skin and clothes move when the
figure bends its elbow.
You can do smooth animation of unrealistic characters by processing a
motion capture file into POV code, and get results like this
        http://www.econym.demon.co.uk/temp/grenade.mpg
That's using a free sample motion capture file from www.biovision.com
But if you tried to do that with a Poser character, it would break at
the joints instead of bending.
Mike Williams
Gentleman of Leisure
Date: 26 Aug 2008 10:10:38
Message: <48b40ede$1@news.povray.org>
> achieve. Animating good looking human figures with hair, clothes etc. in
> POV-Ray is still tricky, but if you're only after little robots or toon
> characters it can be a lot easier.
I've got a series of 8 - 15 second clips, each containing between 1 and
8 principal characters, and up to several dozen secondary characters.
I could do still poses in Daz, but exporting individual frames for the
entire thing would be cumbersome at best.
> most future potential. It's an Open Source human modeller with a Python
> API that I'm currently helping to document. Once I've done that, I'm
> interested in exploring the possibilities of developing an API to
> generate POV-Ray meshes and poses directly (still early days).
I remember hearing about MakeHuman before; I'll take another look at it.
...Chambers
Date: 26 Aug 2008 11:55:58
Message: <48b4278e$1@news.povray.org>
news:48b40ede$1@news.povray.org...
> I've got a series of 8 - 15 second clips, each containing between 1 and 8
Is that 8x15 second clips? So about 2400 frames and an average of 30
characters per scene? That sounds a lot!
How real do you need the people to look and what sort of details do you need
(hair, clothes, eye movements, lip movements)?
What sort of poses and animation do you need? Complex unique movements or
cyclic movements?
Are all of the people moving or can you have some motionless characters
(e.g. a couple of dozen lying on a sun lounger)?
How much time do you have?
Here are some fairly random thoughts:
  o  You can reduce the effort by re-using as much as possible, so repeating
the same basic pose sequence (e.g. walking).
  o  If you can reuse the same characters and poses in all of the
backgrounds (maybe changing their starting points, direction etc. to make it
less obvious), that would massively reduce the work required. It may even be
possible to use the exact same sequence, just rotating the entire background
group so you're looking at it from a different angle in the different clips.
  o  You may even be able to reuse foreground characters and poses, e.g.
looking over the shoulder of a character just showing the back of the neck
and having the same character face on may not be too apparent.
  o  If you do a 20 second sequence for a 15 second animation you can offset
the starting pose by 5 seconds to make it less apparent that two characters
are following the same sequence.
With something like a walking animation, or climbing stairs, or climbing a
ladder you can just export a single walk cycle, e.g. a one second cycle, and
re-use it by using the sequence repeatedly (translating/rotating it at
regular intervals as required so that the repeats move the character further
along the walk path).
If DAZ supports the sort of Poser functionality that Mike described in his
response then that would probably be the quickest thing to try. If you can
use an existing animation sequence, step through the sequence and quickly
export the character and props, then perform a batch conversion you may be
able to get a single character animation sequence into POV-Ray in a
reasonable length of time.
The currently released 0.9.1 allows you to create a character, pose it and
export .obj files that can be converted with PoseRay, but there's no clothes
or hair and no built-in animation functionality yet. This means that with
MakeHuman you'd currently have to define each pose rather than use the sort
of functionality Mike described for Poser to cut the effort required for
generating your frames. If you've got lots of time and want to help exploit
the future potential then this may still be a good way to go.
If you're on a tight deadline then it's probably going to mean a lot of
tedious, repetitive conversion work to define a set of sequences that you
can repeatedly reuse.
Chris B.
Date: 26 Aug 2008 18:28:15
Message: <48b4837f@news.povray.org>
It doesn't allow scripting? Command-line software ftw!
Date: 26 Aug 2008 18:29:22
Message: <48b483c2@news.povray.org>
No, that is probably clips between 8 and 15 seconds :)
Date: 27 Aug 2008 13:20:00
Message: <web.48b58cb43f3b0d77261d9700@news.povray.org>
Correct :)
Most of the "scenes" will be OK with minimal movement; some walking, a few
waving arms, things like that.  I have some creative license, so I can choose
which ones I want to target, and I'll be focusing on ones that let me reuse
assets (characters and scenery).
....Chambers
Date: 28 Aug 2008 03:09:14
Message: <48b64f1a@news.povray.org>
> choose
> reuse
Well this does all sound like what POV-Person does, so long as you're not
too fussy about the quality of the anatomical models (built using a
combination of meshes, CSG and Blobs).
It has a crowd generation macro that can generate random people standing
around in the background (it can position them on a surface for you). The
animation cycles can be applied to any one of a range of different
characters and there are options for randomly varying the body shapes. It
generates some rudimentary items of clothing (using a very limited set of
macros) and hair (also from a limited set). It even has a pose interpolation
algorithm so you can manually define two poses (or use two of the predefined
poses) and generate an intermediate pose or animation (e.g. a hand wiggling
about).
It's all controlled through POV-Ray SDL macros and variables though, so
you'd need to learn about how it works from the documentation and examples
and I don't have any evidence that anyone has ever managed to do that. Also
I never got round to combining the animation and crowd control options into
a single example scene, so adding animation to a crowd would require a bit
of study.
One potential option is to use POV-Person to auto-generate a crowd of
stationary people standing around in the background (see the examples in the
download and in the documentation) and punctuate with occasional animated
character, plus hand-crafted foreground characters converted from Poser or
another modeller. The disadvantage is , of course, that you'd end up having
to learn something about both techniques.
Chris B.
