POV-Ray : Newsgroups : povray.general : texture_map & hight_fields Server Time
12 Apr 2026 17:06:29 EDT (-0400)
  texture_map & hight_fields (Message 1 to 10 of 10)
Subject: texture_map & hight_fields
Date: 12 Apr 2007 16:41:51
Message: <461e998f@news.povray.org>
I am trying to generate a scene where I am assign textures to a
height_field based on the height of the field.  I can get this to work
fine if I define the pigment in the texture_map.  However, what I want
to do is layer an image_map over the hight_field, and then set the
texture based on the height of the height_field.
Basically, the effect I'm trying to achieve is a 3D map, using an
image_map for colouration, and a height_field for 3D-ness.  I want to be
able to define textures along the y-axis to make waves at the water
level, trees in the hills, rocks on peaks, etc.
I've entered the code I am using at the bottom of the message; as the
code is written it works.
However, if I remove the pigment commands, and add the following:
pigment {image_map { jpeg im_map_1 } rotate <90,0,0> scale <15,1,8.4>
translate <1,1.001,-4.2> }
it stops working; regardless of where I put the pigment (outside/inside
the texture, even individually entered into each layer of the
texture_map).  When I add the line I get one of two errors:
1) "No matching } in 'texture', gradient found instead" (if "pigment" is
placed inside of texture)
2) "Cannot layer a patterned texture over another" (if "pigment" is
located outside of the texture block).
The pigment command above also works; if I put it into a texture block
that just contains pigment, finish and normals it works fine.  It's only
when I try to do a texture_map that things fail.
Any ideas?
Thanx
Bryan
height_field { tiff ht_map_1 smooth scale
<15,(ht_map_1_height+0.0001),8.4> translate <1,1.001,-4.2>
   gradient y
     texture_map {
       [0.0 pigment { color rgb <0,0,0> } finish { ambient 0.5 diffuse
         0.5 } normal { leopard 1 turbulence 1.7 scale 0.05 }]
       [(1/255) pigment { color rgb <0,0,1> } finish { ambient 0.5
         diffuse 0.5 } normal { leopard 1 turbulence 1.7 scale 0.05 }]
       [(3/255) pigment { color rgb <0,1,0> } finish { ambient 0.5
       [1.0 pigment { color rgb <0,1,0> } finish { ambient 0.5 diffuse
    }//end texture map
   }//end texture
  }// end height_field
Subject: Re: texture_map & hight_fields
Date: 12 Apr 2007 20:30:50
Message: <461ecf3a$1@news.povray.org>
I don't think that the rotate, scale, and translate statements are legal
there. You need to find a way to transform the pigments after the
texture_map.
William Tracy
You know you've been raytracing too long when www.povray.org is your
default homepage in your web browser.
fish-head
Date: 13 Apr 2007 03:58:26
Message: <461f3822@news.povray.org>
> there.
  Perhaps you should consult the documentation before making such claims.
Date: 13 Apr 2007 11:55:50
Message: <461fa806@news.povray.org>
Congratulations, you made me look at the documentation again. :-)
My initial reaction was that I didn't think you could do transforms to
textures nested within a texture_map. The docs are pretty silent on
this, but looking around it seems that pretty anything legal in a
texture outside a texture_map is legal inside a texture_map.
That, and looking at the original post again, the error looks like its
something completely different.
So, yeah, stupid me. :-P *puts dunce cap on*
William Tracy
You know you've been raytracing too long when you're watching Bay Watch
on the telly, see Pamela A. walking by and shout out "Great bump mapping!"
Date: 13 Apr 2007 12:58:48
Message: <461fb6c8@news.povray.org>
"Bryan Heit" <bjh### [at] NOSPAMucalgaryca> wrote in message
news:461e998f@news.povray.org...
 You need the quotes:
   pigment {image_map { jpeg  "im_map_1"}
   ~Steve~
> Bryan
Date: 16 Apr 2007 08:40:31
Message: <46236ebf$1@news.povray.org>
>    ~Steve~
Sorry, im_map_1 refers to a text-string variable which already contains
the quotations.  This is a macro, so pretty much all input textures and
files are defined outside of the macro (for flexibility)
Bryan
Date: 16 Apr 2007 09:56:24
Message: <46238088@news.povray.org>
news:46236ebf$1@news.povray.org...
>>    ~Steve~
   Gah...  No, I'm sorry, I didn't realise you could do that. But, there you
go, now I've learnt something.  :o)
         ~Steve~
> Bryan
Date: 16 Apr 2007 14:31:40
Message: <4623c10c$1@news.povray.org>
May be the problem is related to your macro. I tried applying
a texture_map to a sphere and using image_maps for pigments
without encountering any problem.
Date: 17 Apr 2007 13:27:50
Message: <46250396$1@news.povray.org>
Christian Froeschlin wrote:
>> contains the quotations.  This is a macro, so pretty much all input
>> textures and files are defined outside of the macro (for flexibility)
Did you define an image_map for each pigment statement within each block
in the texture_map (this isn't clear in your response)?  That works fine
for me.  What is not working is defining the pigment once (i.e. placing
the image_map over the entirety of the height_map), and then defining
the finish{} and normal{} statements within the texture_map.
Bryan
Date: 17 Apr 2007 15:13:16
Message: <46251c4c$1@news.povray.org>
I don't think textures work like that. Do something along the lines of
#declare P = pigment { image_map { ... } ...  }
and use pigment {P} in each individual texture map entry.
