POV-Ray : Newsgroups : povray.general : Scene optimization Server Time
27 Feb 2026 19:00:43 EST (-0500)
  Scene optimization (Message 1 to 10 of 10)
Subject: Scene optimization
Date: 13 Mar 2007 20:29:38
Message: <45f75002$1@news.povray.org>
I'm currently working on several large scenes, at least one of which
rewuires radiosity.  I'd like to remove all the light sources from the
scene, and light it purely with radiosity, but it contains candle
objects which use a filtering media that only looks right with light
sources.
The end result is a scene with five seperate light sources that may look
nice when rendered, but has a maximum render speed of 1:06:00 per line.
Can anybody provide me with some tips and hints on optimizing textures,
lighting schemes, and other scene settings for faster render times
without compromizing image quality?
Any advice would be greatly appreciated.
ADB
Subject: Re: Scene optimization
Date: 13 Mar 2007 21:23:08
Message: <45f75c8c@news.povray.org>
Probably not without more information.
Do you use any functions (for instance, in isosurfaces)?  Those can
often be optimized to provide similar results at much better speeds.
Check the statistics at the end of your render.  If you see that
something has an extremely low hit rate (say, <5%) you could probably
provide better bounding for it.
...Chambers
Date: 14 Mar 2007 20:42:23
Message: <45f8a47f$1@news.povray.org>
Anthony D. Baye nous apporta ses lumieres en ce 13-03-2007 21:29:
> sources.
> ADB
In the radiosity section, do you change error_bound? To what extent? When you
push it down, the rendering time increase. It also requires a higher count to
prevent splotshiness, resulting in still longer renders. One of the main reason
to use small error_bound is to produce sharper and deeper shadows.
You can try lowering pretrace_end. At the cost of more pretrace time, it may
allows you to use more relaxed settings elsewhere, resulting in globaly faster
renders.
Do you have "normals on" in the radiosity block? Normal computation in radiosity
is very computationaly heavy. If you can do without, remove normals on.
Do you have large difference/intersection where you remove 100's small pieces
from a large base object? You may try diferencing a blob instead of many spheres
and cylinders. You may also try using merge to combine all the pieces that you
remove. That way, you only test 2 bounding box instead of one for each components.
If you use area_light, also use adaptive 0. If this give artefacts, try adaptive
1 (need light array at least 5*5 to be benefical) or 2 (min of 9*9). When using
adaptive, it's best to use powers of 2 +1 to get the best efficiency.
Do you use media? The default sampling method is method 3. When using that,
using intervals larger than 1 is a speed killer. Stay with intervals 1 and
increase samples. samples 10 interval 5 is way slower than samples 100. I've
done the tests.
If you have an isosurface that looks like it can be simulated with a blob, try
using a blob to get a similar shape.
If you have an isosurface with some very large max_gradient, Using the log,
square root or cube root of the function may allows you to reduce max_gradient
to a more reasonable range, speeding up it's rendering.
Many reflection or refractions? Lots of total internal reflections? Try
increasing adc_bailout. In some cases, the visual impact is negligeale, but the
resulting speed up very interesting. The default is 1/256, depending on the
scane, you may get by with as much as 1/100 or even 1/64 without to much
negative impact!
Any glossy object? phong and specular don't work with radiosity. You can get a
similar effect using a small amount of blured reflection, but it will increase
the rendering time.
Filtering and scattering media never react to radiosity, they need actual
lights. Emissive media can illuminate radiosity if you use "media on" in the
radiosity block.
Simple textures can't be optimised, they are as simple as can be. Layered ones
can be worked upon. You need some test scene with some simple objects to receive
your test textures. Start with your layered texture on one object. Now, on
another object in the same scene, try to emulate the complex texture with a
simpler one. Once you find a suitable, simpler texture, copy it to your real scene.
Using blured reflections? Do you have any object with blured reflection
reflecting in another surface also using blured reflection? High quality blured
reflection can have as many as 256 components, resulting in 256 reflected rays
for each pixel. If it reflect another such surface, you end up with as many as
65536 rays to evaluate! Duplicating those objects and having the original with
the blured reflection and "no_reflection"(don't show in reflection) and a copy
with normal reflection and "no_image" (visible only in reflections) can help
aleviate the problem.
In some cases, using light_group can significatively improve your rendering time.
'I had to hit him -- he was starting to make sense.'
Date: 15 Mar 2007 14:00:02
Message: <web.45f99727927a0a0a2de2099c0@news.povray.org>
> renders.
/> My radiosity settings are pretty default, the count is set to 35, the
error_bound is 0.2.  I do use media on, but I don't think I have normals
on.
/> I do use a macro that creates my circular brick walls, I tried several
methods for creating rounded brick walls, and finally came up with an
isosurface that could do it from the outside, but I needed texture on the
inside, so i was forced to use CSG.
I used merge wherever possible, and tried bounding the wall manually, but
there was no significant speed increase.
/> My heaviest isosurfaces are the ones I used to carve runes into the
floor, they typically have a ridiculous max_gradient, and I'm looking for a
suitable runic font to replace them with.
> negative impact!
/> I have considered trying that.
> the rendering time.
/> This is the real killer, besides the light sources, or perhaps because of
them.  I have many glossy and reflective surfaces, the floor is highly
polished, as are the columns, and there are silver accents and features
throughout the scene.
> radiosity block.
/> I use massive amounts of emitting media in the scene for flame effects,
and it does render rather slowly, but I've learned to live with it,
considering the effects.
/> I am currently pulling almost all of my textures straight from the
standard texture library, specifically stones.inc (The textures there are
much better than most of my attempts.)
/> I did introduce a light group, to limit the effect of the light_sources
to the candles only, the speed increase that resulted was nothing short of
incredible (Well in excess of 500%.  In twelve hours, it had rendered
almost half of the scene, when previously, it had taken several days to
render less than a quarter.)
Thanks for the input.
ADB
Date: 15 Mar 2007 16:56:27
Message: <45f9c10b$1@news.povray.org>
Anthony D. Baye nous apporta ses lumieres en ce 15-03-2007 14:57:
>> renders.
> on.
With an error_bound in that range, you need a larger count, 350 still been
"low", you may need count 1000!
error_bound 0.2 is far from default (1.8)
Merge may help if you have lots of objects to remove. If you use it in place of
an union, you get longer render times in most cases.
I you use an object_pattern, you are stuck. If that's the case, try fidling with
the treshold value, I suspect that setting it close to 1 or 0 could help, but
nover got around to test that...
>> negative impact!
>> the rendering time.
Ading no_reflection on some of those may help. The floor can be a decent
candidate, if you want it to show in reflections, add another one without
reflection, no_image and no_shadow. That second "floor" will show in
reflections, but you won't see what's reflected on it in other reflections.
If you want those objects to still show in reflections, add a copy of the object
with a non-reflective texture and no_image and no_shadow.
>> radiosity block.
Emissive media is perty fast as there is no shadow tests to do.
> ADB
   Last night my wife met me at the front door. She was wearing a Sexy negligee.
The only trouble was, she was coming home.
	Rodney Dangerfield
Date: 19 Mar 2007 10:19:44
Message: <45feaa10$1@news.povray.org>
Do you need proper brick walls or could you live with a cylinder with a
brick texture on? I know the default brick texture is just for planar
surfaces but you could roll your own for curved surfaces - my tina-chep
entry is a *very* primitive example of this.
http://myweb.tiscali.co.uk/3dextra/tc2.jpg
Date: 21 Mar 2007 03:15:04
Message: <web.4600e87e927a0a0ad41bc31b0@news.povray.org>
> >> radiosity block.
While it's true that none of the three media types *react* to radiosity
lighting, both emission AND scattering media can *contribute* to it.  But
scattering media does that only if lit by light sources. Otherwise, it has
no effect. I think that's what Alain meant to say.
Is it possible to reduce the number of samples in your media (without
causing visual problems)? That would reduce rendering time somewhat.
Ken W.
Date: 21 Mar 2007 03:45:01
Message: <web.4600ef86927a0a0ad41bc31b0@news.povray.org>
> sources.
Here's a trick I use in my own radiosity-only scenes. Say I have a small
torch flame (emission and absorption media) that, used by itself, would
require a radiosity count of 1000 to give a good smooth lighting effect to
the scene. If I use five of those flames in the scene, I find that I can
reduce the count to (very roughly) 1/5 of that and still get good overall
lighting. The radiosity light "patches" from *all* the flames add together
and nicely overlap. How well this works depends on other factors,
of course -- mainly, whether or not each flame is lighting all
parts of the scene.
Ken W.
Date: 21 Mar 2007 19:32:03
Message: <4601ce83$1@news.povray.org>
Kenneth nous apporta ses lumieres en ce 21-03-2007 04:10:
>>>> radiosity block.
> Ken W.
Just tested a purely scattering media in a radiosity scene.
Case 1:
A very bright parallel cylinder light (color rgb 8000) parallel to and just
above a plane.
Scene filled with scattering media.
Result: ABSOLUTELY no lighting of the plane as I expected.
Case 2:
The same light slightly tilted up to hit a second plane above.
Media contained in a cylinder or a box between the 2 planes.
Result:
It don't cast radiosity shadow.
Jehovah's Witnesses: Shit has been prophesied and is imminent; only the
righteous shall survive its happening.
Date: 25 Mar 2007 04:30:02
Message: <web.46063fc9927a0a0a74bc043d0@news.povray.org>
> Case 1:
> above a plane.
That's a strange result.  The plane *should* be literally blasted with
light! I just ran a slightly different experiment, and the scattering media
is definitely creating radiosity lighting on the object  in my scene.
I'm using a media-filled sphere.. not atmospheric media... lit by a very
narrow-beam parallel cylinder light from below, with a white cylinder
object off to the side, outside of the media sphere, to pick up the
radiosity effect. (Media_on in the radiosity block, of course.) The "cone"
of light and the long cylinder object are parallel to each other, as in
your scene. Just to make absolutely sure that the parallel light isn't
somehow lighting my object, I enclose the light and the media sphere in a
light_group.  Rendering this, the cylinder shows a very nice radiosity
effect.
Perhaps there's something odd going on with atmospheric scattering media (?)
Ken W.
