POV-Ray : Newsgroups : povray.general : back side and interior texture Server Time
16 Jan 2026 00:49:29 EST (-0500)
  back side and interior texture (Message 1 to 10 of 22)
Subject: back side and interior texture
Date: 25 Feb 2004 11:21:21
Message: <403ccb81$1@news.povray.org>
I read the manual about interior texture. It says that it can be apply
to triangle (and I assume mesh and mesh2) but I did not find (with a
grep) the definition of backside and frontside for triangles, mesh and
mesh2 ?
Moreover, the definition seems to differ from OpenGL's (order of
vertices) and seems not to use normals either when they are given so I
can not guess it !
Please help.
Thanks
Christophe Raffalli
Subject: Re: back side and interior texture
Date: 25 Feb 2004 11:45:59
Message: <403cd147$1@news.povray.org>
In article <403ccb81$1@news.povray.org> , Christophe Raffalli
> mesh2 ?
> can not guess it !
> Please help.
You cannot currently recreate the OpenGL backface cullling effect with
POV-Ray.  This effect only exists in OpenGL as a speed optimisation because
for OpenGL it is faster to not render backfacing triangles.  This is not the
case in POV-Ray.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 25 Feb 2004 12:07:58
Message: <403CD6BA.5080509@univ-savoie.fr>
>>mesh2 ?
>>can not guess it !
>>Please help.
> POV-Ray.
I am not sure I understand
> case in POV-Ray.
What I want is to be able to choose which face if the backside and which
face if the front face for a mesh2 in fact.
For the moment I get a nice patchwork (not completely random) because
texture and interior texture are applied in a way I do not understand to
each triangle in the mesh. (my mesh uses OpenGL convention for the order
of vertices and has normals pointing to the outside).
Should I give a script sample ?
>     Thorsten
> Thorsten Froehlich
Date: 25 Feb 2004 12:24:03
Message: <g82vg1-ji7.ln1@triton.imagico.de>
> mesh2 ?
AFAIK the use of interior_texture depends on the normal direction and
the normal direction of a flat triangle in a mesh depends on the order
of vertices.  In case of a smooth triangle this is of course more
complicated, you probably can even create triangles with partly
interior_texture and partly not.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 25 Feb 2004 12:28:25
Message: <403cdb39$1@news.povray.org>
In article <403### [at] univ-savoiefr> , Christophe Raffalli
You cannot do this if you also desire to apply individual textures to each
face of the mesh.  You can of course split the mesh into as many faces as
you want to texture individually, but I am aware that doing so is not
feasible if you have many individual textures.
interior_texture is only applied to those triangles which do not have their
own texture.  I understand that this may not always be desired, but
currently (POV-Ray 3.6 beta 1) you cannot get the effect you would like.
No, I completely understand what you are trying to do.  As said, you cannot
currently recreate the effect you desire as of POV-Ray 3.6 beta 1.
    Thorsten
Thorsten Froehlich
Date: 25 Feb 2004 13:24:00
Message: <403ce840$1@news.povray.org>
In article <g82### [at] tritonimagicode> , Christoph Hormann
Nope, the way interior_texture is currently implemented it won't work as
expected with meshes.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Feb 2004 13:42:04
Message: <1q6vg1-00m.ln1@triton.imagico.de>
Well - i never tried it but at a first quick glance i can't find a
reason why not.
Date: 25 Feb 2004 13:53:00
Message: <403cef0c@news.povray.org>
In article <1q6### [at] tritonimagicode> , Christoph Hormann
> reason why not.
Just believe me.  It is not obvious why it won't work, but I did have a very
close look at it very recently, and it will not work as expected.  In fact,
it cannot work as expected.
    Thorsten
Date: 25 Feb 2004 15:41:36
Message: <403D16B8.3060306@univ-savoie.fr>
I only have two textures: one for all frontside and one for all back side.
>     Thorsten
> Thorsten Froehlich
Date: 25 Feb 2004 15:44:58
Message: <403d094a$1@news.povray.org>
So what is the problem?  As long as you don't specify per triangle textures
in a mesh, everything will work just fine.  All you need to do is specify
both texture and interior_texture.
    Thorsten
