POV-Ray : Newsgroups : povray.general : Spherical Isosurface + HieghtMap Server Time
30 Mar 2026 07:11:57 EDT (-0400)
  Spherical Isosurface + HieghtMap (Message 1 to 10 of 16)
Subject: Spherical Isosurface + HieghtMap
Date: 25 Mar 2002 06:50:27
Message: <3c9f0f03$1@news.povray.org>
Ok. I'm trying to model the planet earth using a heightmap of it I
downloaded. The heightmap has Mt. Everest as pure white and the oceans as
pure black Will this code make mt everest and ONLY mt. everest touch the
outside of the containig sphere, or will it extend out of the sphere and
make it look like the top was cut off. I don't really understand how far
reaching the function goes but I think I've figured out that it doesn't
scale with the container.
Here is what I have:
union {   isosurface {
    function {(EarthRadius-EarthHeight(x, y, z).grey)}
    max_gradient 8
    threshold 0.9
    contained_by { sphere { 0, EarthRadius } }
    no_shadow
    pigment { EarthImage
    //color White
    finish  { ambient 1 }
 rotate y*90
Thanks,
Corey
Subject: Re: Spherical Isosurface + HieghtMap
Date: 25 Mar 2002 07:02:00
Message: <e64u9ukc6rl9hd5crbe2k45erk1sfeb1pq@4ax.com>
On Mon, 25 Mar 2002 06:55:32 -0500, "Corey Woodworth" <cdw### [at] mpinetnet>
One advice. Read _carefully_ documentation (all chapters about isosurfaces),
then read http://www.econym.demon.co.uk/isotut/, and then study examples in
/scenes/ folder available in standard distribution. It helps a lot.
ABX
Date: 25 Mar 2002 08:58:47
Message: <3c9f2d17@news.povray.org>
By the way, you'll probably get a result which renders a lot faster
(and you will save yourself work) if you use the HF_Sphere() macro
in shapes.inc.
Date: 25 Mar 2002 13:22:43
Message: <3c9f6af3$1@news.povray.org>
news:3c9f2d17@news.povray.org...
> in shapes.inc.
WOW! Such a plethora of new shapes for me to play with! I had no idea! :)
 I am having more luck with the macro but it takes forever to parse at
decent resolutions. I know I can save it but I'm still testing different
values. Also the isosurface would be alot  more accurate since it is a REAL
sphere and it uses all the pixels from the bump map instead of just the ones
it sampes. Still very cool though!
Thanks,
Corey
Date: 25 Mar 2002 13:23:29
Message: <3c9f6b21@news.povray.org>
news:e64u9ukc6rl9hd5crbe2k45erk1sfeb1pq@4ax.com...
isosurfaces),
in
Yeah I've skimmed through both but a some of it is a lil over my head :)
Corey
> ABX
Date: 25 Mar 2002 13:34:58
Message: <nuqu9u4rd9arf7qemfed5nkurhoabb7ogl@4ax.com>
On Mon, 25 Mar 2002 13:27:48 -0500, "Corey Woodworth" <cdw### [at] mpinetnet>
wrote:
> I know I can save it but I'm still testing different values.
Values of what ? Resoultion of mesh ? Consider that image_map base on image so
it has some highest limit of resolution.
and much slower, and so much memory optimized when copied, and gradient
sensitive (note I'm advocate of functions/isosurfaces)
> since it is a REAL sphere and it uses all the pixels
AFAIK shape showed in your source at begining of this thread isn't spherical
heigh field, only container is sphere
ABX
Date: 25 Mar 2002 14:06:41
Message: <3c9f7541@news.povray.org>
news:nuqu9u4rd9arf7qemfed5nkurhoabb7ogl@4ax.com...
image so
Yes, but my bump map is *very* large. Much larger than I could make the
resolution
of the mesh without running out of memory i think.
Slower to render? Its definetly faster to parse!
spherical
Yes but its not limited to the resolution of  the mesh. And even if it is
limited to
the resoultion of the height field, that resolution is a lot higher than I
can
(practically) make the mesh. Still I know very little about this and could
be very
wrong. Please correct me if I am :)
Corey
> ABX
Date: 25 Mar 2002 14:16:49
Message: <sgtu9u87d7i9966rv1gbas3sra9nmisohe@4ax.com>
On Mon, 25 Mar 2002 14:11:39 -0500, "Corey Woodworth" <cdw### [at] mpinetnet>
wrote:
> Yes, but my bump map is *very* large. Much larger than I could make the resolution
Do you really think you see all details on 800x600 render ?
but when you adjust values and start adjusting of enviroment, in case on mesh
you can use include file with fast parsing, in case of isosurface you can't
use include file with fast rendering
> limited to the resoultion of the height field, that resolution is a lot higher than
I
> can (practically) make the mesh.
The question is, do you really need it ? Do you really make posters with
dimensions 8000x6000
> Still I know very little about this and could be very
You are right abot accuracy. But You are using wrong method for spherical
mapping for so small image dimensions as presented in p.b.i.
ABX
Date: 25 Mar 2002 14:25:09
Message: <3c9f7995$1@news.povray.org>
news:sgtu9u87d7i9966rv1gbas3sra9nmisohe@4ax.com...
resolution
I plan on scaling it up quite a bit when I'm done and then cropping it back
down. to just the important parts.
mesh
can't
is
higher than I
Well I'm not using a CRAZY size 10k bump map. I'm using a 2k one. I know
I won't see all the detatails of it, but with a mesh I only see very few
details.
My mesh keeps looking chunky. :) I up the resolution and it looks less
chunky
but still far from what I want it to be.
So you  suggest I just keep upping the resolution of the mesh untill it
doesn't
look like a mesh at my target resoultion?
Corey
> ABX
Date: 25 Mar 2002 18:02:43
Message: <3c9fac93$1@news.povray.org>
May I interfere?  :o)  Well, I don't know how slow the isosurface solution
is, but I would go for a mesh. If you hesitate to do this because you
consider the memory it needs, please remember that even with an isosurface,
your input is an image_map. This also needs a lot of memory. If you save a
mesh, you nolonger need the bump map.
As for mesh resolution, it normally doesn't need to be very high. Meshes can
be smoothed (faked). I'm not sure an isosurface will look better in this
case.
Btw, don't worry about asking questions. :o)
Hugo
