POV-Ray : Newsgroups : povray.general : Is this an optimum outline for Mesh_Smoothing macro? Server Time
24 May 2026 23:50:33 EDT (-0400)
  Is this an optimum outline for Mesh_Smoothing macro? (Message 1 to 9 of 9)
Subject: Is this an optimum outline for Mesh_Smoothing macro?
Date: 28 Dec 2001 15:45:12
Message: <3c2cd9d8$1@news.povray.org>
I was looking at bicubic patches, but they seem pretty limiting so I want to
try modeling with mesh2. I want to write a macro that will figure the normal
vertices. I am assuming that I created the triangles myself, so all faces
will be defined clockwise. This is the best idea I could come up with. Is
there a faster way? Unfortunately, I know very little of programming outside
of Povray.
#macro Mesh_Smooth (VERTICES_array, FACES_array)
Make a 1D array (VCOUNT_array) to store the number of times each element in
VERTICES_array appears in FACES_array
Make a 1D array (NFACES_array) to store the normals of each face in
FACES_array
Make a 1D array (CHECKED_array) to store the number of times a faces normal
has been used to determine a vertex normal
Start with VERTICES_array[n]
Create 1D array (USEDFACES_array) with VCOUNT_array[n] elements to store the
NFACES.array positions used in determining the vertex normal
Create 1D array (FVNORMS_array) with VCOUNT_array[n] elements to store the
NFACES.array content used in determining the vertex normal
Make a loop from 0 to VCOUNT_array[n]-1
Search in FACES_array for occurances of VERTEX_array[n]
When found, check for normal in NFACES_array and if not present, calculate
the normal of the face and store it in NFACES_array and in FVNORMS._array.
Also, increase CHECKED_array[n] by one and store "n" in USEDFACES_array.
When appropriate number of faces have been calculated, calculate vertex
normal and output it to a file
Use USEDFACES_array to check CHECKED_array for faces which have been used
three times. Remove any which have from FACES_array, NFACES_array, and
CHECKED_array.
Repeat.
Subject: Re: Is this an optimum outline for Mesh_Smoothing macro?
Date: 30 Dec 2001 03:32:30
Message: <3C2ED20F.C887BBCA@hotmail.com>
> want to try modeling with mesh2. I want to write a macro that will
> figure the normal vertices. I am assuming that I created the triangles
> myself, so all faces will be defined clockwise. This is the best idea
> I could come up with. Is there a faster way? Unfortunately, I know
> very little of programming outside of Povray.
If you download the Subdivision Surface Suite at:
  http://enphilistor.users4.50megs.com/sss.htm
You can find code that will help you.
Although the code I have at the above location doesn't support sharp
edges, you might want to do so.  It requires maintaining the state of
each edge, and the calculations get a bit more complicated, but
allows much more flexibility in the models you can support.
ICQ: 46085459
Date: 31 Dec 2001 17:14:27
Message: <3c30e343@news.povray.org>
Thank you,
 I have enjoyed studying your macros.
Subject: Why can I not download sss.zip?
Date: 2 Jan 2002 11:41:48
Message: <3C3339BC.6020507@reading.ac.uk>
Clicking on the sss.zip link I get a screen that shows:
"Forbidden
Remote Host: [xxx.xxx.xxx.xxx]
You do not have permission to access http://enphilistor.users4.50megs.com/sss.zip
Data files must be stored on the same site they are linked from.
Thank you for using 50megs"
with (I assume) the local proxy IP address where the 'x's are.
Any idea what's wrong? I'm using Netscape 6.2 on NT4 sp6.
Bye for now,
	Mike Andrews.
Subject: Re: Why can I not download sss.zip?
Date: 2 Jan 2002 12:13:37
Message: <3c333fc1$1@news.povray.org>
"Michael Andrews" <M.C### [at] readingacuk> wrote in message
news:3C3### [at] readingacuk...
> "Forbidden
Try the link on: http://enphilistor.users4.50megs.com/sss.htm
Basically, you are being told that you can only download the file from a link on
a html page on that server (this is to stop people linking to that resource from
other domains).
Oops, I just noticed that that was the link John gave you - have you got some
setting that says "open links in new window" or similiar?
Date: 2 Jan 2002 12:38:12
Message: <3C3346F4.5060901@reading.ac.uk>
Hi Tom,
Hmm, not sure. It's a fairly new install of NS6.2 and I'm trying to
think whether I've used it to download other things ...
In this case I've tried left-click which should bring up a 'save as' for
things it can't display, and right-click -> save as which saves the html
  response masquerading as the .zip file 8-/
I'll have to peer into the settings, I guess ...
Bye for now,
	Mike Andrews.
Date: 2 Jan 2002 13:08:35
Message: <3c334ca3@news.povray.org>
In article <3c333fc1$1@news.povray.org> , "Tom Melly" <tom### [at] tomandlucouk>
on
from
> other domains).
No, the only way the server can know you linked from its own page is if your
browser sends the referrer information.  While it is in no way required and
supplying it violates the user's privacy most browsers send it by default.
Maybe it was accidentally turned off.  Checking the prefs will help...
    Thorsten
Date: 2 Jan 2002 13:08:41
Message: <Xns918AC2F6D602Dseed7@povray.org>
Are you running Junkbuster or something else that pretevents sending a
HTTP-Referrer header?
Ingo
Subject: Problem fixed: Re: Why can I not download sss.zip?
Date: 3 Jan 2002 04:53:31
Message: <3C342B6A.90706@reading.ac.uk>
Hi folks,
I'm still not sure just what the problem was, but after making a few
changes in the preferences I could download the zip file.
I think it was something odd in the file-download preferences. One of
the things i tried was to hit the 'reset' on the helper applications
tab. Whether this is what fixed the problem, I'm not sure ...
Thanks to all for the suggestions,
	Mike Andrews.
