POV-Ray : Newsgroups : povray.general : Rendering texture for use in SkySphere Server Time
31 Mar 2026 20:01:58 EDT (-0400)
  Rendering texture for use in SkySphere (Message 1 to 10 of 10)
Subject: Rendering texture for use in SkySphere
Date: 14 May 2003 15:24:41
Message: <3EC297FA.9010509@hotpop.com>
Hi there,
   I was wondering what where the best ways I could render a nice
SkySphere, what kind of camera, etc...
Say I want to draw a sky full of stars...  say my stars are sphere...
say that I can place the spheres all around the origin to make a sphere
of stars around it.
Now how could I capture this sphere from the origin to make a texture
that I can use in an object like a skysphere later.
(Actually, I will use it out of povray, so I really need to render the
texture)
Thanks,
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Subject: Re: Rendering texture for use in SkySphere
Date: 14 May 2003 15:39:55
Message: <3ec29b8b@news.povray.org>
Actually what you are trying to do is a (spherical) environment map,
which is a very basic technique.
  You can render such spherical environment map by specifying "spherical"
in your camera settings. Usually the optimal resolution for such map
is twice as wide as high (eg. 256x128 or whatever).
  After this you can use the image created like this as an image map
with spherical mapping (map_type 1 iirc).
  You can have a lot more than just stars there if you want. You can
have planets, entire worlds or whatever. The only requisite is that
none of the geometry in this "world" should be anywhere near the camera.
Date: 14 May 2003 16:22:20
Message: <3EC2A57C.1050002@hotpop.com>
Warp, you just made things perfectly clear to me!  I knew there was
something simple but could find it...
I know I can have more than just stars and that's the point of using
povray for my sky texture!
It's for use in a backgound sphere for a new opengl program I'm doing...
Now, I wonder how to map this texture on an OpenGL sphere...  Normally,
I would have to do a cylindrical mapping on my sphere, but I can deform
the texture to make it spherical...
I guess I should deform it with a sinus of some sort...  Anyway, should
be easy by now...
Thanks a lot!
Date: 14 May 2003 16:42:12
Message: <3ec2aa24@news.povray.org>
  You know what? I have done *exactly* this about a week ago for a
school project (ie. render an environment map with povray and use it
in a "sky sphere" in OpenGL).
  That's easy. Here is the code I used for my sky sphere.
  Firstly it's handiest to make a display list for the sky sphere:
    glNewList(SKY_ID, GL_COMPILE);
        glDisable(GL_LIGHTING);
        glDisable(GL_DEPTH_TEST);
        glEnable(GL_TEXTURE_2D);
        glBindTexture(GL_TEXTURE_2D, SKY_ID);
        generateSkyDome();
        glEnable(GL_DEPTH_TEST);
    glEndList();
  This assumed you have bound the environment map to the texture number
SKY_ID (I use enum constant for all display lists and textures; it makes
things a lot more clear).
  You can then display the sky sphere like this (note that this should be
executed *before* drawing anything else in the scene):
    // Sky (remove translation from transf matrix):
    GLdouble m[16];
    glGetDoublev(GL_MODELVIEW_MATRIX, m);
    m[12]=m[13]=m[14]=0;
    glPushMatrix();
    glLoadMatrixd(m);
    glCallList(SKY_ID);
    glPopMatrix();
  The idea is that the sky sphere is a unit sphere around the camera (in
the same way as in povray). Since it disables depth-testing during its
drawing, everything else will be drawn over it, giving the impression
that the sky sphere is infinitely away (this is why it's important that
the sky sphere is drawn before everything else).
  The generateSkyDome() function which is called above looks like this:
void generateSkyDome()
    const unsigned steps = 16;
    glColor3d(1,1,1);
    for(unsigned vInd = 0; vInd < steps; ++vInd)
        double
            v1 = .001+.998*(double(vInd)/steps),
            v2 = .001+.998*(double(vInd+1)/steps);
        double
            vsin1 = std::sin(v1*M_PI),
            vsin2 = std::sin(v2*M_PI),
            vcos1 = std::cos(v1*M_PI),
            vcos2 = std::cos(v2*M_PI);
        double
            vTexCoord1 = double(vInd)/steps,
            vTexCoord2 = double(vInd+1)/steps;
        glBegin(GL_QUAD_STRIP);
        for(unsigned hInd = 0; hInd <= steps*2; ++hInd)
            double
                hsin = std::sin(hInd*M_PI/steps + M_PI/2),
                hcos = std::cos(hInd*M_PI/steps + M_PI/2);
            glTexCoord2d(double(hInd)/(steps*2), vTexCoord1);
            glVertex3d(-hsin*vsin1, vcos1, hcos*vsin1);
            glTexCoord2d(double(hInd)/(steps*2), vTexCoord2);
            glVertex3d(-hsin*vsin2, vcos2, hcos*vsin2);
        glEnd();
Date: 14 May 2003 20:07:24
Message: <3EC2DA3C.6060807@hotpop.com>
Good to see a fellow OpenGL devellopper! =)
It seems to me that you build a sphere correctly, but map the image like
if the sphere were a cylinder, there is no sin, cos, etc.. in your
glTexCoord2d() statement...
I probably missed something somewhere; I a good programmer, but a poor
analyst...
I will try to render a grid with povray and map the grid, this way I
will clearly see any deformation!
Thanks Warp!
   Xilo
Date: 14 May 2003 21:24:13
Message: <3ec2ec3d@news.povray.org>
  It's as it should be. The spherical projection works this way. When
using the spherical projection, the image is evenly spaced on the surface
of the sphere in the longitudinal (ie. vertical) direction. Thus the
uv-coordinates have to be evenly spaced as well.
Date: 14 May 2003 23:18:09
Message: <3EC306E9.2040905@hotpop.com>
You are probably right...  I'll try what I can and I'll post some
results in povray.binary.images
Thanks,
   Xilo
Date: 15 May 2003 01:10:03
Message: <web.3ec320511591996c18ccf4f70@news.povray.org>
If you're going to render an image for a sky in another program (particulary
a polygon-based one), rather than using a sphere, you could use a skybox.
Just render 6 views of your scene looking n,s,e,w,u,d with a 90 degree
camera angle and as square images. Then just map them onto the surfaces of
a cube, place a camera in the centre of the cube, and there you go.
Rohan _e_ii
Date: 15 May 2003 06:16:25
Message: <3EC368FE.8050502@hotpop.com>
Interesting, I think indeed there would be no visible deformation...
and will take up much less polygons!  Thanks!
BTW, I'm currently doing the exact opposite:  I'm rendering a box in
povray with the spherical camera and applying it to a sphere in opengl
to see if it looks like a sphere stuffed in a box...
Will post images to p.b.images...
Thanks,
   Xilo
Date: 15 May 2003 10:13:30
Message: <3ec3a08a@news.povray.org>
  It's strange that I don't see such deformations in my program.
  Perhaps I will post some images as well...
