POV-Ray : Newsgroups : povray.general : Earth heightfield, colormaps, etc... Server Time
18 Sep 2025 18:42:28 EDT (-0400)
  Earth heightfield, colormaps, etc... (Message 1 to 10 of 13)
Subject: Earth heightfield, colormaps, etc...
Date: 13 Apr 2003 19:31:15
Message: <3E9965F1.3030804@hotpop.com>
   I'm looking for some very high quality pictures of the earth,
specially europe.  I would need the land heightfield and the land colormap.
If anyone can help me, i'd greatly appreciate!
Thanks,
   Xilo
Subject: Re: Earth heightfield, colormaps, etc...
Date: 14 Apr 2003 03:47:06
Message: <3e9a677a$1@news.povray.org>
here
http://earthobservatory.nasa.gov/Newsroom/BlueMarble/BlueMarble.html
and here for height_field
http://gw.marketingden.com/planets/earth.html
Marc
3E9### [at] hotpopcom...
> Hi,
colormap.
> Thanks,
>    Xilo
Date: 14 Apr 2003 10:26:15
Message: <3E9A37B8.2050302@hotpop.com>
> here
This website is awesome, with quality images beyond what I expected!
Though, this one offers less quality, I'd have to pay to download better
heightfields.
   Since I'm specially interested in europe, I'd have to have a much
better height field than that in order to make interesting landscape...
  Though it'll be perfect for a start!
Thanks a lot Marc!
   Xilo
Date: 14 Apr 2003 14:18:53
Message: <3E9AFB79.A3A55428@onwijs.com>
Xilo Musimene wrote:
> > here
> heightfields.
> Thanks a lot Marc!
>    Xilo
I can perhaps give you a heightfield with a higher resolution, but the
vertical resolution might not be that good (bitmap with range [0..255]).
I got the USGS data here:
http://edcdaac.usgs.gov/gtopo30/
It's a 5400x4800 pixel bitmap for the Europe part (lots of sea and
ocean).
Oh, just checked, I only have North West Europe right now. The other
parts should be on the site as well.
Remco
Date: 14 Apr 2003 21:28:43
Message: <3E9AD300.7060604@hotpop.com>
> ocean).
Well, I've seen those images, at the site you mentionned, and those are
not heightfields, but rather rendered heightfield...  can you make a
real heightfield out of it?   Even if the scale has only 256 values, it
would be perfect for my use!
If possible, and I don't want to ask for too much, I'd like to have the
four quadrants concerning europe...  but only if it's possible for you,
or if you can explain to me how to read USGS data I could possibly write
a program to make images out of it...  I'm a programmer...
Thanks a lot,
   Xilo
Date: 14 Apr 2003 21:49:28
Message: <3E9B6516.24AFD32C@onwijs.com>
> Thanks a lot,
>    Xilo
Well, that's what I did. The format is very straightforward. If you
download the four sectiosn, each section has several files, but you'll
only need the DEM file. It has the height data stored in 5400 rows and
4800 colums, with 2 bytes for each pixel. Couldn't be simpler (also
couldn't be more bloated...).
If you have the four sections you can combine them to one fairly huge
heightfield - or at least cut out the part you need.
Remco
Date: 14 Apr 2003 23:09:44
Message: <3E9AEAAD.8080400@hotpop.com>
Good, I should get started right away!  Do you think the seperation can
be seen or is the data perfectly cut?
And is there any more data I could read like coloration? DEM would be
elevation, I see there are many other files also do you know what they
are for?
Thanks!
   Xilo
Date: 15 Apr 2003 09:45:42
Message: <3E9C0CEF.8CA07A87@onwijs.com>
> are for?
> Thanks!
>    Xilo
My guess is the sections will fit perfectly since these seem to be
cutouts from a huge database.
I have a documentation of the file formats I can send you. I think it
came from the same site I found the data so you could also check there.
These are the included files:
   DEM        digital elevation model data
   HDR        header file for DEM
   DMW        world file
   STX        statistics file
   PRJ        projection information file
   GIF        shaded relief image
   SRC        source map
   SCH        header file for source map
I don't see any colour information, the GIF is just a representation of
the data in the DEM file.
The SRC-file funnily enough contains the source for the data for every
pixel. I don't see how that can help...
Cheers!
Remco
Date: 15 Apr 2003 18:04:20
Message: <3E9BF499.9010803@hotpop.com>
Ok good!  I already have an image anyway, I'll just pray it fits
perfectly! If not, I'll have to retouch it...
I'll check the source website thoroughly, thanks a lot Remco!
Xilo
Date: 15 Apr 2003 21:56:41
Message: <3E9C2B0E.6000606@hotpop.com>
Ok, I've been working on my program a lot and it now works... it
currently outputs a bmp and the grayscale is scaled to 8bits,
unfortunately...  I'll work with that for now and eventually, I will
write Grayscale 16bit PNGs!
Though, there is something extremely strange about the image I get...
First, I realized the countrys near Holland, etc, were "really" lower
than sea level!  And second, holland is white, sea is gray, and land is
black...  but in the alps, where the elevation is very high, it gets
lighter...
I would have expected the land to be on the coast almost the same value
as the sea, but there is a definite sharp change from light gray(sea) to
dark gray(land), and that can be seen on all coasts...
I believe the sea has a special code, and should not be displayed like
the land, I don't know...  I could send you a very small jpeg of some
region of the result I get so you can see for yourself and this way
maybe you'll understand what's happenning?
Thanks,
   Xilo
