![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I need to map a height field onto the inside of a hollow box, but I can only
think of one
way to do this: generate the image that will be used for the height field,
then cut it into
5 pieces (there's no top on the box) and map each piece separately. I need
to make
sure the edges meet up smoothly... no areas where the separate maps don't
fit together
right. It would be a lot easier with UV mapping; is it possible to UV map a
heightfield?
I don't think it is, but I haven't really messed with UV mapping yet.
Any help would be greatly appreciated!
- Doug Eichenberg
http://www.getinfo.net/douge
dou### [at] nls net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <39b294c4$1@news.povray.org>, "Doug Eichenberg"
> can only think of one way to do this: generate the image that will be
> used for the height field, then cut it into 5 pieces (there's no top
> on the box) and map each piece separately. I need to make sure the
> edges meet up smoothly... no areas where the separate maps don't fit
> together right. It would be a lot easier with UV mapping; is it
> possible to UV map a heightfield? I don't think it is, but I haven't
First, what do you mean by "map a height field onto the inside of a
hollow box", and what would UV-mapping have to do with a height field
other than for texturing? You aren't thinking of a bump map instead of a
height field, are you? A height field is an object, and can't be
"mapped".
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> "mapped".
Sorry, my language wasn't too clear on that one. I want to texture the
inside of a box (minus one side, call it the top, through which the camera
will be looking) with a water-like surface (ripples, wrinkles, whatever).
The texture (or hieght field, or bump map, or whatever I use) needs to
appear like one unified surface over the surface area of the boxes
sides (as if it were UV mapped) Does that make any sense? It's a very
simple idea, I'm just having a hard time describing it.
- Doug Eichenberg
dou### [at] nls net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If i understood you right, you want a box with walls of a certain thickness and
with a rough interior surface that is open on the top.
The easiest way would be probably the difference between a regular box and a box
shape isosurface with some additional roughness (noise3d/pigment function)
Christoph Hormann <chr### [at] gmx de>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Doug Eichenberg" <dou### [at] nls net> wrote in message
news:39b2a6bb$1@news.povray.org...
I know what you are talking about but even tiling couldn't mesh height
fields in such a way.
You'd get it close to right but every bit of relief on the surfaces would
simply leave a crease. And even if that were okay the tiling would make
each side the same, or look-alikes.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Exactly the problem I've run into. I might try Christoph's idea... I'll
have to
check out isosurfaces (ugh...) which I haven't messed with yet.
Thanks for the feedback!
- Doug Eichenberg
dou### [at] nls net
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
