POV-Ray : Newsgroups : povray.general : While we are talking about changes Server Time
26 Apr 2026 10:31:46 EDT (-0400)
  While we are talking about changes (Message 1 to 10 of 46)
Subject: While we are talking about changes
Date: 12 Mar 2000 07:56:22
Message: <38cb93f6@news.povray.org>
How hard could it be to have POV primitives come with default values? So
that if you simply wrote box{} you would get an unpigmented box of unit size
at the origin. Since most people use a unit, at origin object, then scale
and translate, it could save tons of typing.
    Of course they should be able to be over-rode...
    Most of the reason I use the insert menu is so that I don't have to type
in the default values myself. Not sure how that would work on cones
though...
Subject: Re: While we are talking about changes
Date: 12 Mar 2000 09:58:31
Message: <38CBAF9C.7C199D2B@attglobal.net>
Hum....  I do get your point and in some cases it could be a good idea,
but
box {
    scale < 2, 2, 2 >
    translate < 5, 5, 5 >
is actually more characters than
box {
    < 5, 5, 5 >
    < 7, 7, 7 >
Of course, what's the use of default values if they can't be
over-ridden?
> though...
Call me old school, but i prefer typing than getting my and hand over to
the mouse and select primitives from the menu.
Something I'd like to be able to do is automatically place objects
relative to others without having to do all the trig myself, but I guess
that could go in a modeler.  The POV-team probably has enough headaches
to resolve as it is.
Francois Labreque | The surest sign of the existence of extra-
     flabreq      | terrestrial intelligence is that they never
        @         | bothered to come down here and visit us!
  attglobal.net                                  - Calvin
Date: 12 Mar 2000 10:21:42
Message: <38cbb606$1@news.povray.org>
> but
> box {
>     scale < 2, 2, 2 >
> box {
>     < 5, 5, 5 >
>     < 7, 7, 7 >
    True, but how often do you do things like that? I almost -always- make
objects at origin then scale and translate. The few times I don't are
usually when I want to connect a cylinder or cone to certain points.
Date: 12 Mar 2000 15:10:51
Message: <38CBFF1A.8C37A179@merlin.net.au>
> > but
> > box {
> >     scale < 2, 2, 2 >
> > box {
> >     < 5, 5, 5 >
> >     < 7, 7, 7 >
I nearly always create objects at their final size, apart from non equal
scaling.
But then I'd do sphere{0,5 scale<1,2,1>} rather than sphere{0,1
scale<5,10,5>}
PoD.
Date: 12 Mar 2000 15:11:48
Message: <slrn8cnv23.3rs.ron.parker@linux.parkerr.fwi.com>
Who is this "most people" you talk about?  Most modelers do that, but
I would think most people make the box where they want it.  I know I
do.
Date: 12 Mar 2000 15:16:33
Message: <38CBFB91.1EA01060@istar.ca>
> do.
One of the major reasons that I use Moray, instead of hand coding, is
that I can't get my brane to work in the mode that will understand the
box code.
No matter how much I work on it, it's always a struggle. Having a default
I can scale is easier to understand. I can easily visualize a box scaled
to <1, 2, 5>, but a box defined by corners <-0.5, -1, -2.5>  <0.5, 1,
2.5> is not something I can see in my mind.
Date: 12 Mar 2000 15:51:47
Message: <38CC0243.2F0296E5@pacbell.net>
Both methods require repetitious use before you become comfortable with
them. When I was first learning Pov I bounced back and forth between
various modellers I was evaluating and hand coding. Personally I found
more power in the hand coding environment but had I found a modeller
I was comfortable with I might have swung the other way. Regardless
I still think that with practice you would learn to use the various
control points of a box with the same ease that you do the scale feature
in your modeller of choice.
Besides defining a unit box is no more difficult than
box{-.5,.5}
Defining a unit sphere
sphere{0,1}
Defining unit cylinders you have a choice of which axis to align it to
cylinder {x*-.5, x*.5, 1}
cylinder {y*-.5, y*.5, 1}
cylinder {z*-.5, z*.5, 1}
etc.
Date: 12 Mar 2000 17:19:00
Message: <38CC1A53.5AAB654B@erols.com>
> do.
The place where this "feature" of all modellers I've seen gets me is
with the cylinder.  Whenever I use a cylinder, it's along the lines of
  cylinder { <3,2,4>,<1,1,3>,.5 }
which with most modellers has to be done by calculating the scaling and
rotation outside of the program, and then entering them by hand.  This
is why I don't use them.
John
ICQ: 46085459
Date: 12 Mar 2000 18:17:51
Message: <38CC24C4.EED45E45@faricy.net>
Francois Labreque wrote:
> box {
>     scale < 2, 2, 2 >
> box {
>     < 5, 5, 5 >
>     < 7, 7, 7 >
or you could do box { 5 7 } :-)
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 12 Mar 2000 20:20:07
Message: <38cc4247@news.povray.org>
> do.
    Perhaps I am mistaken. I supposed that since the docs recommend it, new
users are often told to do it, and it make sense to do so in terms of
declarations, that most people would do so.
    Personally, BTW, I don't care about character count. My insert menu box
looks like:
/////////////// box ////////////////////////
box {
     < -0.5, -0.5, -0.5 >,
     <  0.5,  0.5,  0.5 >
     scale      < 1.0, 1.0, 1.0 >
     rotate     < 0.0, 0.0, 0.0 >
     translate  < 0.0, 0.0, 0.0 >
     texture { DefaultTexture }
        } // end box
    ... I do it like this so that I have to type less. I mouse delete
anything I don't need and modify the rest to my requirements.
       If I am putting it in a loop or something I will chop it down, but
otherwise...
