POV-Ray : Newsgroups : povray.general : Question about bicubic patches Server Time
10 Aug 2024 05:13:34 EDT (-0400)
  Question about bicubic patches (Message 1 to 10 of 10)
Subject: Question about bicubic patches
Date: 10 Mar 2000 05:33:19
Message: <38c8cf6f$1@news.povray.org>
Questions, questions, questions, ...
I've just read from the docs that POV converts the bicubic patch into
triangles. My question is why? It seems obvious that it must have something
to do with
computation time, and the fact that there is no great advantage to spending
the time calculating a intersection point for every ray. Does that sound
right? Maybe there is another reason? Can a bezier surface be made with an
isosurface?
TIA.
Dave.
mic### [at] sympaticoca
Subject: Re: Question about bicubic patches
Date: 10 Mar 2000 08:09:29
Message: <38c8f409@news.povray.org>
David Curtis <spa### [at] junkmailcom> wrote:
: I've just read from the docs that POV converts the bicubic patch into
: triangles. My question is why? It seems obvious that it must have something
: to do with
: computation time, and the fact that there is no great advantage to spending
: the time calculating a intersection point for every ray. Does that sound
: right?
  Well, the documentation says:
"The keyword type is followed by a float Patch_Type which currently
must be either 0 or 1. For type 0 only the control points are retained
within POV-Ray. This means that a minimal amount of memory is needed
but POV-Ray will need to perform many extra calculations when trying
to render the patch. Type 1 preprocesses the patch into many
subpatches. This results in a significant speedup in rendering at the
cost of memory."
  I understand this to mean that the patch is not converted to triangles if
it's of type 0 (at least at parse time).
Date: 10 Mar 2000 09:16:11
Message: <38c903ab$1@news.povray.org>
>: to do with
>: right?
True, but it's still converted to triangles at render time.
I think MegaPOV still has the "type 2" bicubic patch, which evaluates the
bicubic directly.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 10 Mar 2000 10:51:36
Message: <38c91a07@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: I think MegaPOV still has the "type 2" bicubic patch, which evaluates the
: bicubic directly.
  How is this done? How fast is it? Can it be done even nearly as fast as
with triangles?
Date: 10 Mar 2000 11:48:55
Message: <38c92777$1@news.povray.org>
>: bicubic directly.
>with triangles?
According to the comments, it uses "NSK (Nishita, Sederberg,Kakimoto)"
Whether it's faster or slower is something I've never investigated.  The
code (bezier2.c in the superpatch, presumably also in megaPOV) is also
riddled with FIXME statements (and the accompanying comments are often
in Czech, as well, making it difficult to determine what needs fixed)
so I'm not sure how well it all works in the real world.
Date: 10 Mar 2000 21:28:54
Message: <38C9B1E1.DF6B1B21@erols.com>
> to do with computation time, and the fact that there is no great advantage
> to spending the time calculating a intersection point for every ray. Does
> that sound right?
Yes.
A bicubic patch would have to be represented by a sixth-degree polynomial.
There are methods to calculate ray-surface intersections with a sixth-
degree surface, but they are slow and imprecise.  In most cases a bicubic
patch, with u_steps and v_steps set to three, provides just as good an
end product, but renders far more quickly.
John
Date: 13 Mar 2000 09:51:57
Message: <38CD00A1.9D430B61@mitre.org>
> > that sound right?
> Yes.
18th degree polynomial.
Xander
Date: 14 Mar 2000 17:29:19
Message: <38CEBFC5.2C71D5C4@erols.com>
> > > that sound right?
> > Yes.
I recall the 3.0 docs as saying that it was six.  What's your source
for 18?
ICQ: 46085459
Date: 15 Mar 2000 07:29:33
Message: <38CF8249.8CF19A23@mitre.org>
> > > > that sound right?
> > > Yes.
> for 18?
Wrote the Bezier code, didn't write the docs.  Hard to say where the 6
came from.
A few years ago, I spend way too much time trying to find a general way
to implicitize a bicubic patch (although I did get a result for bilinear
patches).  If you start digging you find that a two variable parametric
surface with degree n in one variable and degree m in the other can be
implicitized to a function of degree 2 * n * m.  [Therefore 2 * 3 * 3 =
18.]  Techniques for doing the implicitization are pretty well
understood, but tend to be applied to a single equation with fixed
coefficients, not to an arbitrary one (heaven forbid you move the
control points of your Bezier...).
There are, of course, specialized ways to implicitize things that have
simplifying characteristics.  However, I couldn't find anything to help
in this regard with bicubic Beziers.
After spending time on that (got some big equations from Mathematica if
you are really interested...), I realized that a) direct numerical
solution of that high order a poly wasn't going to be particularly
accurate, and b) Using an initial tesselation to find an approximate
solution, coupled with a few N-R iterations would be way better.
The tesselation/iteration process can be very accurate and reasonably
fast.  Bezier surfaces have a really nice property that the surface is
completely contained within the convex hull of their control points.  By
using the bounding box of the ctl points (yes - it's bigger than the
convex hull) and looking for intersections, you can feed those to the
N-R iterator.  Keep the u/v bounds of the subpatch within the box so you
can ensure the iterator doesn't go too far.  A couple of subdivisions of
the patch are usually enough to ferret out any folds or bubbles in the
surface - leading to a way easier solution.
Xander
Date: 15 Mar 2000 21:11:08
Message: <38D04545.439DC679@erols.com>
> By using the bounding box of the ctl points (yes - it's bigger than
> the convex hull) and looking for intersections, you can feed those to
> the N-R iterator.  Keep the u/v bounds of the subpatch within the box
> so you can ensure the iterator doesn't go too far.  A couple of
> subdivisions of the patch are usually enough to ferret out any folds
> or bubbles in the surface - leading to a way easier solution.
I wrote a macro to generate the triangles for a bicubic bezier, so that
I could use Bezier patches inside of meshes.  The Ant people in one of
my IRTC entries were constructed from meshes done this way.
John
ICQ: 46085459
