POV-Ray : Newsgroups : povray.general : Realistic Sky, Lake, Pine Trees, Grass and Wheat Field needed.... Server Time
16 Jan 2026 07:06:57 EST (-0500)
  Realistic Sky, Lake, Pine Trees, Grass and Wheat Field needed.... (Message 1 to 8 of 8)
Subject: Realistic Sky, Lake, Pine Trees, Grass and Wheat Field needed....
Date: 27 Feb 2000 08:28:19
Message: <38b92673@news.povray.org>
Can any one suggest how I can produce REALISTIC versions of the following:
a) Sky with clouds.
b) An animated lake with moving water.
c) Pine trees (Maybe that can be animated to simulate blowing in the wind).
d) Short green grass.
e) A wheat field (That can be animated to simulate blowing in the wind).
Some or all of the above will be included in a 3 minute animation that will
be included on a new POV-Ray user site.
Please e-mail any suggestions to me and I will give you a mention on the
final animation credits.
Thanks in advance
Mickey
Subject: Re: Realistic Sky, Lake, Pine Trees, Grass and Wheat Field needed....
Date: 27 Feb 2000 08:37:23
Message: <38B92826.70E22A4@pacbell.net>
> a) Sky with clouds.
Skies.inc that comes with POV-Ray plus you can look at the following
tutorial. How to make it animated is left to the creative artist...
http://members.xoom.com/POVRAY3/index2.html
The POV-Ray objects collection has an include file called xtree.inc by
Remco DeKorte that makes a very realistic Pine tree.  Animation will again
be an exersize left to the creative artist
http://povobjects.virtualave.net/
A Grass include file can be found here -
http://www.spiritone.com/~english/cyclopedia/grass.html
See answer to d. Change color and height of grass patches. Animating
this will be an exersize for...
Date: 28 Feb 2000 02:51:06
Message: <38BA2882.2079E145@pacbell.net>
There is a tutorial available on this subject -
http://www.cstech.fr/~babin/babin/frames/frm-pov-en.htm
Date: 28 Feb 2000 11:59:55
Message: <38BAAA0C.3199DA9B@spiritone.com>
Me? I've thought of animating the grasspatch, but I have no idea how to apply
consisent transformations to all those splines...
Josh
Ken wrote:
> > a) Sky with clouds.
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Josh English
eng### [at] spiritonecom
Date: 28 Feb 2000 15:55:08
Message: <chrishuff_99-5E9074.15563928022000@news.povray.org>
In article <38BAAA0C.3199DA9B@spiritone.com>, Josh English
> to apply consisent transformations to all those splines...
Hmm, if it uses MegaPOV, then you might be able to do something with
vtransform(), vturbulence(), eval_pattern(), eval_pigment(), or any
combination of these...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 28 Feb 2000 18:58:12
Message: <38BB0C0C.91144244@spiritone.com>
I suspect those are above my head, the problem is that grasspatch makes a
whole bunch of individual splines. I can move all of them uniformly, but
it probably won't look as good.
Josh
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Josh English
Date: 28 Feb 2000 19:31:00
Message: <chrishuff_99-A5C8BD.19323128022000@news.povray.org>
In article <38BB0C0C.91144244@spiritone.com>, Josh English
Actually, they are pretty simple:
    The first function, vtransform(), just applies a transform like
scale, rotate, translate, matrix, or a sequence of these in a transform
{} block to a point vector, moving it as they would an object.
    The vturbulence() function applies turbulence to a point vector. If
you used this in the calculations for the grass positions, it would be
the same as turbulating the grass.
    The eval_pattern() function takes a point vector and a pattern, and
returns the value at that point(between 0 and 1 for most patterns,
although there are exceptions).
    The eval_pigment() function does the same thing, except that it
takes a pigment instead of a pattern and returns a rgb color vector. If
you use position vectors in the color_map of the pigment and use the
result of the function in your calculations for the grass, you could
simulate things like waving grass.
Or you could use a combination of these, like vturbulence() with
eval_pattern() controlling the amount of turbulence.
Chris Huff
Date: 29 Feb 2000 00:53:18
Message: <38bb5ece@news.povray.org>
Chris Huff wrote in message ...
eval_pattern() scanning a ripples or waves pattern should make a good ripple
effect in the grass.
Mark
