POV-Ray : Newsgroups : povray.general : Different error messages for same POV-file Server Time
26 Apr 2026 10:24:35 EDT (-0400)
  Different error messages for same POV-file (Message 1 to 10 of 24)
Subject: Different error messages for same POV-file
Date: 13 Mar 2000 07:44:48
Message: <38CCE1C6.4947A712@hotmail.com>
Hello
I'm trying to make some macros to enable me to
experiment with different rotation matrix's. (That I
later will apply to 3D vectors to get the desired
rotation of the vector.)
I know about the built in rotate functions in POV-Ray.
I just want to learn about rotation matrix's.
Each matrix is built up as an array of 3 3D-vectors
each. And my macros again operate on these arrays.
My problem is that I get several different error
messages when I try to Run the file below in this
message (I did not alter it between the Runs).
Can anyone please tell me if I am doing anything wrong
in my macros? (variable passing, variable declarations,
variable name conflicts etc.)
I am using POV-Ray v3.1g.watcom.win32 (Pentium II
optimized) and I am using a 100 MHz Pentium PC with
32 MB RAM, running Windows 98.
Regards
Tor Olav
mailto:tor### [at] hotmailcom
Here is some of the error messages:
  Warning Stream to console.......On
  #local PP = array[3]
  #local QQ = array[3]
  #local PP = Mtrans(NN)
  #local NN <----ERROR
C:\My documents\POVray-bilder\Matrix03_.inc:39: error: undeclared
identifier expected but float function 'clock_delta' found instead.
identifier expected but float function 'tan' found instead.
identifier expected but float function 'on' found instead.
identifier expected but float function 'abs' found instead.
identifier expected but float function  found instead.
  #local PP = Mtrans(NN <----ERROR
C:\My documents\POVray-bilder\Matrix03_.inc:54: error: Cannot pass
uninitialized identifier as macro parameter.
Initialize first.
  #local NN = array[3]
  #local NN[0] = <MM[0] <----ERROR
C:\My documents\POVray-bilder\Matrix03_.inc:40: error: Attempt to access
uninitialized array element.
Here is the POV-file that generates the errors:
// Copyright 2000 by Tor Olav Kristensen
#macro S3Prod(U, V, W)
  vdot(U, vcross(V, W))
#macro Mcof(MM)
  #local NN[0] = vcross(MM[1], MM[2]);
  #local NN[1] = vcross(MM[2], MM[0]);
  #local NN[2] = vcross(MM[0], MM[1]);
  NN
#macro Mdet(MM)
  S3Prod(MM[0], MM[1], MM[2])
#macro Mtrans(MM)
  #local NN[0] = <MM[0].x, MM[1].x, MM[2].x>;
  #local NN[1] = <MM[0].y, MM[1].y, MM[2].y>;
  #local NN[2] = <MM[0].z, MM[1].z, MM[2].z>;
  NN
#macro Mmult(MM, NN)
  #local QQ[0] = <vdot(MM[0], PP[0]), vdot(MM[0], PP[1]), vdot(MM[0],
PP[2])>;
  #local QQ[1] = <vdot(MM[1], PP[0]), vdot(MM[1], PP[1]), vdot(MM[1],
PP[2])>;
  #local QQ[2] = <vdot(MM[2], PP[0]), vdot(MM[2], PP[1]), vdot(MM[2],
PP[2])>;
  QQ
#macro Mscale(s, MM)
  #local NN[0] = s*MM[0];
  #local NN[1] = s*MM[1];
  #local NN[2] = s*MM[2];
  MM
#macro Minv(MM)
  #local s = 1/Mdet(MM);
  #local NN = Mcof(MM)
  #local QQ = Mscale(s, PP)
  QQ
#declare MMi =
array[3] {
  <  2,  0,  6>,
  <  8,  1, -4>,
  <  0,  5,  7>
#declare QQi = array[3]
#declare QQi = Minv(MMi)
#declare RRi = array[3]
#declare RRi = Mmult(MMi, Minv(MMi))
Subject: Re: Different error messages for same POV-file
Date: 13 Mar 2000 11:42:40
Message: <38CD1A4C.548C1ABE@spiritone.com>
What do you have for the version number in the scene. That can effect which
features are enabled or not. Also, are you using MegaPov? I usuall have to
add #version unofficial MegaPov 0.4; to my scenes to get those to work.
Josh
Tor Olav Kristensen wrote:
> Hello
> Regards
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
<snip>
Josh English
eng### [at] spiritonecom
Date: 13 Mar 2000 12:45:08
Message: <38CD2959.151A5E04@gci.net>
I know that these are not directly part of the problem,
but, s seems to be flagged as a reserved word in MegaPOV.
> Hello
><snip>
>   MM
> #end
> #macro Minv(MM)
>   QQ
> #end
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
Date: 13 Mar 2000 17:17:52
Message: <38CD6815.BAB28BB6@hotmail.com>
Hi Josh
Thanks for replying.
I had not put any #version declaration in the file.
But now I did try to insert
#version 3.1;
at the beginning of the file, but the problems persists.
I still get wildly changing error messages for the same file.
(I even got new ones.)
No, I am using plain POV-Ray v3.1g for Windows
Regards
Tor Olav
> > Hello
> > Regards
> > Tor Olav
Date: 13 Mar 2000 17:34:20
Message: <38CD6BF2.D5D56C4D@hotmail.com>
Hello mr. art
Right now I did try to replace the s with other
variable names, but it didn't stop those ever-
changing error messages.
I'm just using plain POV-Ray (v3.1g) for Windows
(Not MegaPOV).
I looked up reserved identifiers and keywords in
the help file, but I could not find 's' listed
for this plain version of POV-Ray.
Regards
Tor Olav
> > Hello
> ><snip>
> >   MM
> > #end
> > #macro Minv(MM)
> >   QQ
> > #end
> Mr. Art
> Bill DeWitt 2000
Date: 13 Mar 2000 23:09:26
Message: <38CDBDFA.B52B3077@erols.com>
I have sometimes gotten error messages that seemed like the
wrong error message.  If I recall correctly, it turned out that
the actual error was at some point earlier than what the parser
flagged.
ICQ: 46085459
Date: 14 Mar 2000 03:39:23
Message: <38CDFB03.F82A8CEA@aetec.ee>
> Hello
Hello.
Just a thought: try to add semicolons to lines, where they are
missing...
Date: 14 Mar 2000 17:29:10
Message: <38CEBC39.582A511F@online.no>
Hello John
I too have got error messages pointing to the
wrong point in my code when my error(s) were
hidden somewhere earlier.
In these cases I just had to start commenting
out code, changing variable names and moving
things around until the error messages points
at my real error.
I suspect that this may also be the case here,
and I have therefore tried to play around with
my code before posting to this newsgroup... But
I haven't had any luck smoking out my(?) errors
yet.
But I have found out that if I replace the last
line of these four:
with
#declare RRi = Mmult(MMi, QQi)
then the error messages disappear.
This may be my solution for this time, but the
problem still bothers me, because I want to be
able to replace macros like e.g. this one:
#macro Minv(MM)
  QQ
with macors like this one:
#macro Minv(MM)
  Mscale(1/Mdet(MM), Mtrans(Mcof(MM)))
Lately I have also found that it seems that
the more I do of the substitutions like the
one above, the more it seems likely that I
start getting those random changing error
messages I have described earlier.
(It seems like I can do some substitutions
without being punished.)
And now I don't know how to proceed in my
hunt for these errors.
Am I the only one who is getting changing
error messages when running the code I
enclosed in my initial posting?
Regards
Tor Olav
> flagged.
> ICQ: 46085459
Date: 14 Mar 2000 18:09:40
Message: <38CEC5B6.C3C921B1@online.no>
Hi Vahur
> > Hello
> Hello.
> missing...
Hmm...
I have been a little bit worried about my use of semicolons.
Earlier I have seen that too many missing semicolons can
cause crashes of POV-Ray (on my Windows 98 machine at home,
and if I remember right, also on my Windows NT4 machine at
work).
Therefore I have looked through my code to make sure that I
had put them where I thought they should be.
But your reply (thank you btw.) made me check both my code
and the help file once again.
Here are my (rather lengthy) findings:
When POV-Ray parses my file, I do not get any warning
messages like this one:
warning: All #versions and #declares of float, vector, and
color require semi-colon ';' at end.
So everything apparently looked fine, but I thought that
maybe my array declarations should have some semi-colons as
well (even if array declarations aren't mentioned in
messages like the one above.)
In the help file for Windows didn't have any luck finding
explicit instructions about whether I should use semi-colons
after array declarations or not.
But I found two code examples of array declarations:
The first one
8< snip
 #declare MyArray = array[10];
 #declare MyArray[5] = pigment{White}  //all other elements must be
                     //pigments too.
8< snip
used semi-colon, and the second one
8< snip
 #declare MyGrid = array[4][5]
 #declare YourArray = MyArray  //this is ok
8< snip
did not.
So now I thought that I should try to insert some of them
after my array declarations.
So I did, but now the parser started complaining about these
semi-colons:
#declare NNi = array[3]; <----ERROR
error: object or directive expected but ; found instead.
... So now I am totally confused about semi-colons!
Regards
Tor Olav
Date: 14 Mar 2000 22:35:42
Message: <38CF057C.6499B18E@peak.edu.ee>
> work).
This is new to me. You mean the machine crached? Or just POV quit parsing?
Usually, missing semi-colons should only produce warnings (at least in the
current version). Only in some macros have I seen actual errors caused by them.
Semi-colons should only go after declarations of floats and vectors (colours can
also be thought of as vectors).
If you are declaring an array, it should not have a semi-colon:
#declare MyArray=array[10]
If the docs said otherwse, this is a typo. However, if you are declaring an
element of an array, and that element is a float or a vector, it should have a
semi-colon:
#declare MyArray[0]=11.5;
See docs section "Declaring identifiers" for further reference.
Margus
