POV-Ray : Newsgroups : povray.general : How do I model a plastic bin? Server Time
22 Jul 2026 05:05:14 EDT (-0400)
  How do I model a plastic bin? (Message 1 to 8 of 8)
Subject: How do I model a plastic bin?
Date: 6 Sep 1999 00:30:21
Message: <37d3435d@news.povray.org>
I'm thinking of a "bin" that is sort of like an open-top box, but one side
is lower and tipped forward, so
it's easy to grab stuff if it's sitting on a shelf.
I don't want sharp angles like it's made of 5 flat slabs.  A real plastic
bin has rounded edges.  Since one of the faces is at an angle, how might I
do that?
--John
Subject: Re: How do I model a plastic bin?
Date: 6 Sep 1999 01:35:17
Message: <37D352DB.7D72@unforgettable.com>
> do that?
Hmm, what are those things called that look like rounded-off cubes?
Super-something?
Well, anyway, if you can use those in CSG, then your problem is solved:
Add a tilted one to a straight one, cut off the top at an angle, and
subtract a smaller version from it to make it hollow inside.
Alternatively, you can get the same effect using boxes, cylinders, and
spheres. Your CSG code will be a bit more complex, though.
-Xplo
Date: 6 Sep 1999 05:05:28
Message: <37d383d8@news.povray.org>
'superellipsoid' can slow when used in some CSG but that may be the
best way anyhow.  If a need for speed going with alternative two, as
Xplo suggests, would be my advice.
For nearly square "super L's" use low numbers like <0.1,0.1>
Xplo Eristotle <inq### [at] unforgettablecom> wrote in message
news:37D### [at] unforgettablecom...
one side
plastic
might I
> > do that?
> Super-something?
solved:
and
> -Xplo
Date: 6 Sep 1999 09:59:16
Message: <37D3C8FA.AACD4566@compuserve.com>
In my macro collection(binaries.utilities, posted by Ken) there are
macros for making rounded objects out of boxes, cylinders, and cones.
They are CSG objects with the edges rounded with torii or cylinders, or
the end caps with spheres for the cone. I have a newer version almost
finished which does a better job-I will try to get it ready for upload,
but school is starting tomorrow, and I have several other projects
going.
Date: 6 Sep 1999 16:28:18
Message: <37d423e2@news.povray.org>
> Super-something?
A superellipoid is square, a three-d "round rect".  Cutting the top off at
an angle won't give me the rounding within the edge exposed by that cut.
But that does give me an idea:  make a cube structure (either method) and
then use a matrix scale to shear it.  I'll see what that does for me
shortly.
--John
Date: 7 Sep 1999 03:03:32
Message: <37d4b8c4@news.povray.org>
John M. Dlugosz <joh### [at] dlugoszcom> wrote in message
news:37d423e2@news.povray.org...
> shortly.
That worked.  Making a smooth rectangular prisim with spheres and cylinders
doing the smoothing, then shearing it, gives the correct effect.  See the
results at http://www.dlugosz.com/POV/dryad_dreams.html .
I'll submit the "bin" macro (configurable dimensions, thickness, angle of
opening, and corner smoothing) to the PILE and the POV Objects collection
shortly.  Are those the best places to send it, or are there others I should
know about?
--John
Date: 7 Sep 1999 10:22:20
Message: <37D51F75.7CD90D14@geocities.com>
> > shortly.
> know about?
> --John
If it's a macro, zap it on over to the new Twysted Net.
http://www.twysted.net/
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 7 Sep 1999 19:44:04
Message: <37d5a344@news.povray.org>
Jon A. Cruz <jon### [at] geocitiescom> wrote in message
news:37D51F75.7CD90D14@geocities.com...
Nice database, but the macro file is not suitable for anything major (e.g.
long listings, docs and illustrations, example files).  I'll check out his
Object library, though.
--John
