POV-Ray : Newsgroups : povray.general : Oval Shape Server Time
27 Mar 2026 19:59:37 EDT (-0400)
  Oval Shape (Message 1 to 10 of 16)
Subject: Oval Shape
Date: 31 Aug 1999 13:03:17
Message: <37CAB99E.93CB3A0C@dshack.com>
This question maybe a simple one to the experts but I can't seem to make
a simple oval.  I can make a chain link by taking the difference of a
torus and adding cylinders, I can make a torus.  But I can't figure out
the way I am supposed to strech the torus into an oval.  Please tell
me.  I am sure it is simple.
Kenny Pyatt
Subject: Re: Oval Shape
Date: 31 Aug 1999 13:19:48
Message: <37CC0E78.352544AD@pacbell.net>
> Kenny Pyatt
Uneven scaling is one way to do this. If for example you were looking
through the hole of a torus in front of the camera scale it:
 scale<1, 1.5, 1>
Or try something like this for one link:
camera { location 6*-z  look_at 0}
light_source { 6*-z rgb 1}
#declare Torus_Part =
intersection {
 torus{1,.25 rotate 90*-x}
 plane{y,0}
#declare Link =
union{
object{Torus_Part translate y*-.5}
object{Torus_Part rotate 180*x translate y*.5}
cylinder{y*-.5, y*.5, 0.25 translate x*-1}
cylinder{y*-.5, y*.5, 0.25 translate x* 1}
pigment{rgb 1}}
object { Link }
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 31 Aug 1999 13:40:30
Message: <37cc138e@news.povray.org>
An oval using the torus is not going to turn out right unless you use
Kens second method. Uneven scaling is one thing, procedural-type
scaling is another, of which POV-Ray is unable to do. Another
possibility is to string together spheres or blob components along a
spline path, just not as efficient.
Ken <tyl### [at] pacbellnet> wrote in message
news:37CC0E78.352544AD@pacbell.net...
to make
of a
figure out
tell
> > Kenny Pyatt
looking
>  scale<1, 1.5, 1>
> intersection {
>  plane{y,0}
> #declare Link =
> union{
> pigment{rgb 1}}
> object { Link }
> Ken Tyler
Date: 31 Aug 1999 14:26:06
Message: <37CC1E03.483C861@pacbell.net>
>  scale<1, 1.5, 1>
Adding to my previous post if you want the links elongated more so than
the script I posted before you can try the following script. I also added
a method of linking the links together with the proper rotations.
camera { location 12*-z  look_at 0}
light_source { 60*-z rgb 1}
#declare Torus_part =
intersection {
 plane{y,0}
#declare Link =
union{
object{Torus_part translate y*-.5}
object{Torus_part rotate 180*x translate y*.5}
cylinder{y*-.5,y*.5,0.25 translate x*-1}
cylinder{y*-.5,y*.5,0.25 translate x*1}
pigment{rgb 1}}
union{
 #declare a=0;
 #while(a<10)
   object { Link
            scale     0.5
            translate y*-5
            rotate    y*90*a
            translate y*1.2*a
 #declare a=a+1;
  scale<.5,1,.5>
  rotate 45*y
Ken Tyler
Date: 1 Sep 1999 00:52:04
Message: <37ccb0f4@news.povray.org>
Kenny Pyatt wrote in message <37CAB99E.93CB3A0C@dshack.com>...
A true oval cannot be created by scaling a torus.  If you scale a torus, you
get an elliptical torus.  An oval is composed of four arcs, so a ovoidal(?)
torus would be composed of four sections of tori in two different sizes.
Mark
Date: 1 Sep 1999 04:08:28
Message: <37ccdefc@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote:
: A true oval cannot be created by scaling a torus.
  Perhaps I'll think about how to do it with a poly-object. It looks like
it will need a 6th degree polynomial (since the regular torus need a 4th
degree one)...
Date: 1 Sep 1999 12:32:30
Message: <37CD54FE.76230D45@gci.net>
Isn't the equation for a 2D oval/ellips something like
(x^2)/a + (y^2)/b = 0? A circle is x^2+y^2=0.
Couldn't we find the part of the torus discription
that deals with the major radius and add the division
parts?
> degree one)...
Date: 2 Sep 1999 00:24:26
Message: <37cdfbfa@news.povray.org>
Mr. Art wrote in message <37CD54FE.76230D45@gci.net>...
>parts?
An oval is not an ellipse, they just look similar.  An oval is easier to
draw freehand, but an ellipse is easier to create mathematically.
Mark
Date: 2 Sep 1999 00:35:06
Message: <37CDFE45.9B214917@gci.net>
Point taken. But is there someone out there that can point out the
places in the code to put the values a and b in something like
this?
// Torus having major radius sqrt(40), minor radius sqrt(12)
#declare Torus=
quartic {
    1,   0,   0,   0,   2,   0,   0,
    2,   0,-104,   0,   0,   0,   0,
    0,   0,   0,   0,   0,   0,   1,
    0,   0,   2,   0,  56,   0,   0,
    0,   0,   1,   0, -104,  0, 784
 sturm
 pigment{White}
This is almost stright form the docs.
> >parts?
> Mark
Date: 2 Sep 1999 03:22:25
Message: <37ce25b1@news.povray.org>
Mr. Art <mr.### [at] gcinet> wrote:
: Point taken. But is there someone out there that can point out the
: places in the code to put the values a and b in something like
: this?
  It's not as easy as "putting the values a and b in this".
  I have been calculating polynomials (man, I wish I got some mathematical
program to help me; typing polynomials by hand is tedious) and it seems
to be impossible.
  If I'm correct, a perfect elliptical torus would require a 8th degree
polynomial (a very simple explanation of this is that it's because the torus
is a 4th degree polynomial and you have to raise it to the power of 2).
Povray can only handle polynomials up to the 7th degree. Bad luck.
  A non-perfect elliptical torus (ie. the minor radius does not stay
constant along the torus) may require only a 6th degree polynomial (note:
this torus is not the same as a scaled torus; the minor radius would be
the same at both axes of symmetry; the radius will differ at the "corners").
