POV-Ray : Newsgroups : povray.general : New video cards may offload POV Server Time
11 Aug 2024 13:13:31 EDT (-0400)
  New video cards may offload POV (Message 1 to 10 of 37)
Subject: New video cards may offload POV
Date: 24 Jul 1999 14:06:39
Message: <379a00af@news.povray.org>
Plain PaperTry this link
http://headline.gamespot.com/news/99_07/23_pc_nvidia/index.html
Looks like the next generation of video boards may start doing some of the
math currently done in POV.
Jim
Check out my web site  http://www.kressworks.com/
It'll blow your mind (politically), stimulate your senses (artistically)
and provide scientific insights that boggle the mind!
Subject: Re: New video cards may offload POV
Date: 24 Jul 1999 15:21:39
Message: <379A11BC.A1FF9EA@pacbell.net>
> Jim
Sorry Jim but it won't help Pov in this case.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 24 Jul 1999 23:37:23
Message: <379a8673@news.povray.org>
Really?  Even with the onboard shading, lighting, and rendering functions?
Or would a card specific version of POV be required to take care of those
functions?
Jim
Ken <tyl### [at] pacbellnet> wrote in message
news:379### [at] pacbellnet...
the
> > Jim
> Ken Tyler
Date: 24 Jul 1999 23:46:26
Message: <379A8802.F53A31D2@pacbell.net>
> functions?
> Jim
 With the current way that Pov works it calculates each pixel internal to the
program before it outputs to the screen. There are no internal routines that
take advantage of external hardware accelerations. If you read the literature
carefully they make reference to direct x and openGL instruction sets which
are specificaly written to take advantage of such abilities. Pov works in a
completely different way. There's has been a lot of talk about writting an
openGL preview mode for Pov but it is problematic and would still not help
for final renders. Quality of the images produced but direct X and openGL
are inferior to Pov's raytracing methods anyway and I personaly think it
would be a step backward.
Ken Tyler
Date: 25 Jul 1999 07:19:06
Message: <379AF3E8.AF37E7C3@puzzlecraft.com>
What Ken states is true. However, there are accelerator boards for professional
graphics that will accelerate POV-Ray. Daystar sells them for the Mac.
Basically, they work by replacing your motherboard with a quad-CPU motherboard.
They are expensive and top out at 1,800 mhz.
If you really want speed, Silicon Graphics has a motherboard that can support
256 alpha RISC CPU's which are now running at 1,000 mhz for a total speed of
256,000 mhz. Better have some really deep pockets for this.
A low budget solution is to get a dual Pentium Dell server and run it as a
workstation.
steve
> > functions?
> > Jim
> Ken Tyler
Date: 25 Jul 1999 09:20:43
Message: <379b0f2b@news.povray.org>
Steve <ste### [at] puzzlecraftcom> wrote in message
news:379AF3E8.AF37E7C3@puzzlecraft.com...
> workstation.
    Can you elaborate on this a little? I have been having some sort of
thought like this... getting a box and a motherboard and a network card and
using that box to do nothing but renders. No keyboard, monitor, mouse,
soundcard, videocard, with smallest possible HD, lots of RAM...
    But, since I have never done any networking but some serial port copying
of HDs...
Date: 25 Jul 1999 09:52:14
Message: <379B167E.84F30E41@plymouth.ac.uk>
What Bill is suggesting is buying a server similar too those found in
offices and running povray on that. What you're thinking of is buying a
bare-bones system to run POV. If you did that you'd still need the
keyboard, mouse and videocard (at the very least to install Windows
etc.) but you could save on the monitor by having a switch box (using
your existing monitor) or running it remotely using a piece of software
such as CarbonCopy. Networking is getting very cheap and what you're
suggesting is entierly possible, all you would need is the two network
cards, a cable and the software (Windows.) I've been doing this
successfully for nearly a year and only had a few minor problems.
	Graham.
> > workstation.
> of HDs...
Date: 25 Jul 1999 10:40:04
Message: <379b21c4@news.povray.org>
support
of
Sillygon Graphics have an ALPHA cpu running at a 1000Mhz,,
I thought digital (compaq) uses/builds alpha processors and SGI uses MIPS
(R12K being the latest edition, running at 300Mhz), and a SINGLE motherboard
supporting 256 CPU's, I know that their deskside origin2000 sports 1-4 node
cards, 2-8 cpu's. And an Origin2000 rack system can house 1-256 node cards,
2-512 cpu's (R10K or R12K), but that's the entire rack-system, not a single
motherboard.
Could you please give some details on this?
Regards, Jens Berg Churchill.
Date: 25 Jul 1999 13:15:45
Message: <379b42ae.212962279@news.povray.org>
  True, Ken. These cards are great for their intended use but we would see
no advantage. I don't think that incorporating OpenGL into POV-Ray would be
anything to crow about. We've already fast previews with more control by
using the quality switches (+q). OpenGL might be better suited to displays
from modeling programs, although I like Moray just the way it is now.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 25 Jul 1999 13:28:16
Message: <379B48A0.5961D6C2@pacbell.net>
> Alan
I think I summed it up very well in the VFAQ. If you want to play games and
mpeg movies on your system then by all means buy a good harware accelerated
graphics card. If speed is a concern in raytracing then buy a fast processor,
with a mother board the has a fast buss, good amounts of level one and 2 cache
memory for swapping out instructions, and tons of fast system ram. Then sit
back and wait cause raytracing is a slow process no matter what kind of system
you can afford to buy :)
Ken Tyler
