POV-Ray : Newsgroups : povray.general : Height Field Warning Server Time
1 Dec 2025 10:17:34 EST (-0500)
  Height Field Warning (Message 1 to 10 of 12)
Subject: Height Field Warning
Date: 12 Jul 1999 19:29:47
Message: <378A79E7.53DEDF76@pacbell.net>
People (term used lightly in some cases),
  By sheer accident I ran into a terrible problem rendering a HF logo
today. I was helping another Pov user via email who had sent me a logo
image he wanted to try to render in 3d. The image he sent was in .tif
image. After writing the .pov scene to my satisfaction I then rendered
the scene.
  It was at this point I started doubting my abilities at using this
program. The logo was was simply white text on a black background. One
would expect that the results would be raised letters with a little
background that could be easily removed with the water level modifier.
Nope ! Did not look that way. Instead I got a solid block with the
letters REMOVED !
  I shook my head, scratched a few places, and then decided I had the
colors reversed from what they should be. I opened the image in PSP and
made a negative of the original. Upon rendering the scene again with the
modified image I once again had exactly the same problem. WHAT you might
now be saying ? I sure did !
  This nonsense went on for about 20 min of trying various options but for
the life of me I could not figure out what had happened to a proven method
of 3d logo creation. It was only after shutting down the program, eating
lunch, and considerable pondering did I discover the error of my ways.
 I had saved the gif image with transparency set to the background color
option set in PSP. When the pov went to render the file it found the
transparency info contained in the gif image and was reversing (?) the
operation of the HF process. Ultimately I re-saved with transparency
disabled and it worked as expected.
  I just though you all might be interested in knowing that this too can
happen to you and if it does you will know how to correct for it.
Ken Tyler
mailto://tylereng@pacbell.net
Subject: Re: Height Field Warning
Date: 13 Jul 1999 00:41:25
Message: <378ac375@news.povray.org>
    I had something similar happen to me over the weekend. While editing a
HF in Corel I switched to the imagemap, did some erasing, and switched back
to the HF and removed a similar section. When I rerendered the edges of the
erased area were suddenly at full height.
    Turns out the color I erased with was from the imagemap (I suppose) and
must have gotten added to the palette at the end (#255) when I saved,  even
though it looked black.
    Anyway, undoing and then selecting a low value color from the HF then
re-erasing fixed it.
    I don't remember if transparency is saved at the #255 position in the
palette.
Date: 13 Jul 1999 01:03:08
Message: <378AC870.7E315278@aol.com>
One of the reasons I uncheck any of those "Use Background Color for
Transparency" boxes I come across since I never am sure where that color
is going to be.
> the scene.
> letters REMOVED !
> Ken Tyler
 mailto://inversez@aol.com?Subject=PoV-News
Date: 13 Jul 1999 01:14:21
Message: <378ACA92.AA59681@pacbell.net>
> palette.
  In PSP there is a seperate options dialog you have to activate when
doing a save_as or save operation. If three days ago you had opened the
extra dialog and choosen to save with transperency the next time you use
the program it will remember that last used setting. You have no way of
knowing that it is set one way or another unless you check and that is
what bit me on this one.
Ken Tyler
Date: 13 Jul 1999 01:35:29
Message: <378ACF88.85B62C31@pacbell.net>
> is going to be.
I usualy have set to off but I made a mistake all right ! I Ken Tyler made
a mistake ! Now let if go :)
  I am hoping that others may learn from 'My' mistake and not repeat it. If
it were not for my considerable intellegence I might have made a bug report
instead accusing Pov v3.1g of having a bug. But this didn't happen now did
it ?
Ken Tyler
Date: 13 Jul 1999 05:24:59
Message: <378B04EF.2AFB1272@xs4all.nl>
> Ken Tyler
Good grief! ;-)
Would this be the cause of my premature baldness over a bump_map I can't seem to
get to work?
On the other hand: I tried it with PNGs and couldn't get the results I wanted
(and expected) there either. Must be me, I guess...
Remco
http://www.xs4all.nl/~remcodek/
Date: 13 Jul 1999 09:17:23
Message: <378B3BBD.A4D7DCE4@netvision.net.il>
ken, with all due respect to your gigantic intelligence and titanic
rendering abilities (not to mention your lynk bank), i did this exact
operation last week in 2 minutes.
> the scene.
> letters REMOVED !
> Ken Tyler
Date: 13 Jul 1999 10:56:14
Message: <378B440B.E234E98F@xs4all.nl>
Did you share your wisdom?
Remco
http://www.xs4all.nl/~remcodek/pov.html
Date: 13 Jul 1999 10:57:31
Message: <378B53F9.5C4D6FB@peak.edu.ee>
I bet it was eating lunch that did the trick :)
BTW, it would be nice if the transparency info in GIF could be put to good use,
such as clipping out the transparent sections. The alpha channel could also be
used, clipping out completely transparent parts. I can think of many
applications for this (although all can be simulated with texture maps)
Does this sound viable?
Margus
Date: 13 Jul 1999 11:06:15
Message: <378B552F.647D1263@pacbell.net>
> Margus
  I think simply using black along with the water lever modifier in those
areas you wish to clip is a more reliable system. What was actually being
represented by the Hf was not the black field or the transparent white
field but instead it was the boundry layer between the two. If you experiment
with it a little bit you will see what I am talking about. I am surprised
it returned any height values at all. It may be that PSP was antialiasing
the pixels at the boundry and that is why there was something besides a
flat object produced.
Ken Tyler
