POV-Ray : Newsgroups : povray.general : Library paths and image maps Server Time
1 Dec 2025 14:06:11 EST (-0500)
  Library paths and image maps (Message 1 to 10 of 15)
Subject: Library paths and image maps
Date: 5 May 1999 15:24:46
Message: <37308DAA.2A2989C2@pilot.msu.edu>
I cant get POV to find my image maps, further I have no clue why.
	Can somone explain to me what exactly I have to do to make this work?
the path for my image maps is :  C:\Program Files\POV-Ray for Windows
v3.1\User\Image maps. What do I have to do to the .INI file and on the
command line? is therer anthing else I need to do?
While Im here I want to make the sky fade from blue to black as it goes
up. How is this accomplished?
-Drew
Subject: Re: Library paths and image maps
Date: 5 May 1999 15:46:19
Message: <37309176.FD2F8B63@pacbell.net>
 Open pov and choose the tools menu. Select edit master povray.ini.
Add the following line to the bottom of the ini file
Library_Path=C:\Program Files\POV-Ray for Windows v3.1\User\Image maps
 Don't worry if there is already another Library_Path=   statement in
the file. Just add yours below it and then re-start the program.
It should now search for your image in that directory before giving
up and asking you where it is.
You can also include a path in your image map statement like this:
  image_map { tga "c:\pov\includes\images\Image.tga" }
> -Drew
A simple gradient pigment pattern will accomplish this for you.
sky_sphere {
 pigment { gradient y
  color_map {
   [0 rgb < 0, 0, 1 >]
   [1 rgb < 0, 0, 0 >]
  Also look in the docs under the tutorial section describing the use of
sky spheres. It contains more examples and some of the different options
you should be aware of.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 5 May 1999 15:51:18
Message: <37309498.80719554@tiac.net>
I recently had a library path problem too so I'm interested
in any response you may get.
As far as fading from black to blue try "gradient". There's
an example in:
Insert->Ready Made Scenes->Basic Scene
The sky sphere goes from blue to white.
Date: 5 May 1999 21:21:50
Message: <3730E08B.D76E4C8A@aol.com>
Just to make a note here. I've used more than 10 library paths and have
been able to use any new additional path once the Povray.ini has been
edited and saved without need to close and restart POV-Ray for Windows
v3.1e. The Scene help file says library paths are limited to 10 and
appears to be in error about this.
Anyone care to acknowledge this?
>  pigment {
> Ken Tyler
 mailto://inversez@aol.com?Subject=PoV-News
Date: 5 May 1999 21:48:41
Message: <3730E662.D296C4E9@pacbell.net>
  If by that you mean you want me to add more than ten library paths
to my ini file and then design a scene that will use one source file
from each directory just to back up you statement I would like to go
on record as saying I support you on this without feeling a need to
verify it thank you very much.
  Perhaps that was/is a limitation with Win 3.0 and the newer win 95/98
have no such bottlenecks built in. Or maybe not.
Ken Tyler
Date: 6 May 1999 00:55:21
Message: <3731141B.EA1BDC90@tiac.net>
>v3.1e.
I believe I typed everything in correctly, but the additional
pathname didn't work for me.
Restart? I didn't think to do that. I'll have to try again and see what
happens.
Date: 6 May 1999 05:03:04
Message: <37314CAA.2182685E@aol.com>
Yes, it's true. More than 10 Library_Path= lines works. I just had to test
this out to be positive. I created 12 new folders each with it's own
include file containing a 'text' statement of the numbers 1 thru 12 and
then forgot I had to also have the path to my fonts as well so they
totaled 13 in all. POV-Ray 3.1e has no problem using that many and I was
thinking I had heard 20 was the new limit, however I'm satisfied with the
13 paths possible so far. Oh, and no restarting of POV-Ray either, just
the saving of Povray.ini does fine.
> Ken Tyler
Date: 6 May 1999 05:13:59
Message: <37314EB4.E560197F@pacbell.net>
  I am glad you were able to confirm that. I know intuitively that changes
to the master povray.ini file needs no restart as it is read each time
a render is started. The same is not true of the secondary.ini file which
I do on occasion edit to add or remove graphic resolutions and AA settings
for unique circumstances. It seems to be read into memory and forgotton
until you close the program and restart. This is evidenced by the glaring
ommision of changes made to the file in the drop down resolution menu.
Ken Tyler
Date: 6 May 1999 10:17:05
Message: <37319651.0@news.povray.org>
Looking at povray.h for the 3.1e source code, I see that the limit has
been raised to 25.
Date: 6 May 1999 11:02:46
Message: <3731a106.0@news.povray.org>
Look what I found !
This quote is from the section "Using INI files" of the scene docs:
"The only exception is the +L switch for setting library paths. Up to ten
unique paths may be specified."
And this quote comes from "Library Path" the  Parsing Options section :
"Up to twenty unique paths may be specified."
Can we assume that 10 is the limit in a command line and 20 in an povray.ini
? The remaining five (according to the source and Mr.. Parker) could they be
for extra paths in extra .ini/command line options that we choose to make ?
>> Ken Tyler
> omniVERSE: beyond the universe
>  http://members.aol.com/inversez/homepage.htm
