POV-Ray : Newsgroups : povray.general : Reflection vectors ? Server Time
28 Apr 2026 13:26:31 EDT (-0400)
  Reflection vectors ? (Message 1 to 10 of 19)
Subject: Reflection vectors ?
Date: 9 Jan 1999 08:53:40
Message: <36975EF9.50AB37AE@pacbell.net>
I was looking at the source for the scene file "Brilliant" and noticed
that the artist used vectors for describing the reflection values of each
facet. This possibility had totaly excaped me until now. What benefit
if any is gained by doing so ?
An example: finish { reflection <0.5,0.75,0.5> }
Ken Tyler
tyl### [at] pacbellnet
Subject: Re: Reflection vectors ?
Date: 9 Jan 1999 11:17:43
Message: <36978051.F186E362@bahnhof.se>
i think it defines how each colour will be reflected...
//Spider
> Ken Tyler
Date: 9 Jan 1999 14:58:03
Message: <3697B563.9F9DC655@erols.com>
It modifies the color of the reflected light.  You could, for instance,
have a silver mirror (neutral tones in the pigment) that reflected a blue
image of the things in view.
John
Date: 9 Jan 1999 15:30:13
Message: <3697BBE0.76BDBFDA@pacbell.net>
Thanks John, Spider.
Ken Tyler
Date: 11 Jan 1999 06:59:14
Message: <3699E791.93643AD1@olicom.dk>
> Ken Tyler
I have used that feature. The vector is a colorvector :) rgb that is.
cu
Bjarne Nygaard
Date: 11 Jan 1999 18:30:16
Message: <369A896C.EEEAF17@aol.com>
Surprised that you, Ken, of all people had failed to notice the
vectorable reflection before now. Though I must admit I did not, and
presume, do not (which comes in handy) know all there is to know.
Cross-threading a bit here, but, I tried to do a mixture of spectral
dispersion and reflection color shifting together to no avail.
Seems that the reflection simply refuses to be averaged as refraction
does. Been puzzled ever since. As others may already know, normals have
a difficult time being layered or averaged too (or so I think) so it
follows that there are probably many such impossible(?) characteristics,
along with a few good pluses which balances things out thank goodness.
> Ken Tyler
=Bob
Date: 11 Jan 1999 18:49:39
Message: <369A8D9A.C7D25ABE@pacbell.net>
> vectorable reflection before now.--
It just goes to show that even for someone who is well versed with
the program there are still things to learn. There are so many variables
in this program I doubt that I will ever learn them all. Can you without
looking right now type every possible pigment pattern type ? I did it
once to test myself about three months ago. I missed only two. One
of which I didn't know exsisted (new for 3.1).
Did you know you can use a negative number for a cone diameter and
end up with two cones kissing at their points ? Try this on for size:
cone{x*-1,1,x*1,-1 pigment{rgb 1}}
Who would ever think of using negative values like this especialy since
it's not documented anywhere ? I found out by way of typo. Wanna
see weird ? Try negative values with superellipsoids.
There are some other unique things you can do that are not documented
because the program has so much flexibility that I imagine even the
programmers don't know all that it can do.
I'm not to blame for not knowing because I'm only human and not some
perfect machine. I know little about media and next to nothing about using
blobs. Who cares ? Theres plenty of other features to keep me busy for
years. Implementing and using nested and recursive while loops will keep
me busy for most of 1999 and then it's time to master macros
Ken Tyler
Date: 12 Jan 1999 07:08:43
Message: <369B3A6F.AD469BC3@bahnhof.se>
Oopa... Skilled as imagined.
Kewl...
Porbably not, but then, programmers in general aren't noteworthy for their great
patience
in documentation.... (I know, I'm one of them.)
We don't blame you... I wonder what would happen the day I stopped learning and
testing in
pov.... Hmm. I maybe will get a scene finished... Yeah, that's it.
//Spider
Date: 12 Jan 1999 13:40:46
Message: <369b972e.0@news.povray.org>
Actually, at least up to now there as little point in using rgb values in
reflection. The following would give exactly the same results:
pigment {rgb 1} finish {reflection <1,0,0>}
pigment {rgb <1,0,0>} finish {reflection 1}
i.e. you can do the same thing with pigments.
Now with the variable reflection patch, I'm not so sure... Must try it out.
Margus
Date: 12 Jan 1999 15:26:07
Message: <369BAFDD.3099@merlin.net.au>
> Margus
Not true, in the first instance the object has a red pigment and in the
second, white.
Try the following
plane{	-z,0
  pigment{White}
  finish{ reflection Red } }
sphere{
  <3,0,-3>,1
  pigment{Blue+Green} }
White plane, no reflection of the sphere because the plane reflects none
of the primaries in the sphere's pigment.
Cheers, PoD.
