POV-Ray : Newsgroups : povray.binaries.scene-files : Systema Metropolis: In the Wild Server Time
8 Jun 2026 23:38:37 EDT (-0400)
  Systema Metropolis: In the Wild (Message 11 to 20 of 20)
Subject: Re: Systema Metropolis: In the Wild
Date: 11 Feb 2008 23:14:41
Message: <47b11d31$1@news.povray.org>
Nicolas Alvarez wrote:
> POV-Tree manual recommends you should *always* save to that other
> format, and only export to mesh when you're done.
I created a few files that I actually couldn't open again because I
screwed something up, and quit trying. A poor excuse, I know.
> Well... can you send me the huge meshes, at least? :) I want to try
> rendering your scene!
The smallest I can squeeze it down to is 13 megs, and that's with the 7z
compression format--15 megs is still the best I can get out of zip. Do
you want me to try emailing it to you?
William Tracy
I'm sorry Dave, I'm afraid I can't do that.
     -- HAL 9000
Date: 11 Feb 2008 23:30:20
Message: <47b120dc$1@news.povray.org>
I have 7-zip; and even 20 megs would be acceptable, I can download at
70KB/s (now that my connection got back working correctly!).
Date: 12 Feb 2008 15:36:51
Message: <47b20363$1@news.povray.org>
Takes one whole minute to parse the meshes! I'm sure it's not the loops
on placeLandscape; I added debug statements before each #include. 60
seconds to parse loop-less code seems extreme :D
And rendering with +q2 and no area light takes 18 seconds. I would
really like to save the meshes in binary format so they can be loaded
instantly :(
Date: 12 Feb 2008 18:26:17
Message: <47b22b19@news.povray.org>
I'm planning to render the scene at a silly-high resolution. Stay tuned.
Date: 12 Feb 2008 19:10:08
Message: <47b23560$1@news.povray.org>
Render times between tiles vary way too much. I can't stand a 1m 14s
parse and 42 second render; but if I make tiles bigger, some may go up
to hours.
So, the idea of biggest-damn-render-you-have-ever-seen is suspended
until I get dynamic tiles to work.
Date: 12 Feb 2008 20:23:25
Message: <47b2468d$1@news.povray.org>
Wow--I still thought it was the loops that were taking all the time.
I need to see about cranking down the Pov-Tree mesh resolution, then.
William Tracy
ManyThings, and Nothing constructors
from a single ManyThings and a single
Nothing.
     -- Professor Keen, homework assignment 1, CSC 430
Date: 12 Feb 2008 20:24:53
Message: <47b246e5$1@news.povray.org>
The grass textures barely hold up as it is. :-P The rest of the scene
should look reasonable at higher resolutions, though.
Are you rendering the RSOCP, or the robots? :-)
William Tracy
Date: 12 Feb 2008 20:36:04
Message: <47b24984$1@news.povray.org>
I want to see a single f***ing tree being 600 pixels high. That should
give you an idea.
Date: 12 Feb 2008 23:04:48
Message: <47b26c60$1@news.povray.org>
> give you an idea.
Wow. I have no idea how it will look at that resolution. Even if the
full file is too big to share, I would definitely like to see some
details from it. :-)
I'm now playing with optimizing the scene for fast rendering, since I
want to re-use some of the code for an animation. I could share the
faster code with you when it's together, but I have no idea if my
"improvements" would introduce additional artifacts at that resolution.
William Tracy
    "I don't hink it helps to make analagies between the physical and
social worlds," Sax said primly.
    "Shut up, Sax. Go back to your virtual reality."
     -- Kim Stanley Robinson, _Red Mars_
Date: 13 Feb 2008 11:45:26
Message: <47b31ea6$1@news.povray.org>
In the usual tiling method (setting +w and +h to the full res, and using
+sc +ec +sr +er), I can't do it. POV-Ray crashes, because it still
attempts to allocate memory for the whole image. However, I successfully
managed huge tiled renders with zoomin.inc, where I set +w and +h to the
size of a single tile.
I'll post a 2048x1536 render on p.b.i. It's not too big, as I was just
testing, and rendering only on my machine.
